按照这个博客中的资料,我自制了XILINX的下载线。 http://comm.chinaaet.com/adi/blogdetail/34431.html 板子焊接完了,EEPROM固件程序也已成功下载,电脑能够识别下载线,设备管理器中显示xilinx USB cable。如下图
但在使用IMPCT更新CPLD固件的时候遇到了问题,如下图
IMPCT的console中错误信息如下图
有人遇到过这样的问题吗?请留言帮助,不胜感激! 以下附console的全部日志内容 Welcome to iMPACT iMPACT Version: 13.4 // *** BATCH CMD : setMode -bs // *** BATCH CMD : setMode -bs // *** BATCH CMD : setMode -bs // *** BATCH CMD : setMode -bs GUI --- Auto connect to cable... // *** BATCH CMD : setCable -port auto AutoDetecting cable. Please wait. PROGRESS_START - Starting Operation. Connecting to cable (U*** Port - USB21). Checking cable driver. Driver file xu***dfwu.sys found. Driver version: src=1027, dest=1027. Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021. Cable PID = 0008. Max current requested during enumeration is 74 mA. Type = 0x0004. Cable Type = 3, Revision = 0. Setting cable speed to 6 MHz. write cmdbuffer failed 20000015. Error reading reference voltage level. Cable connection failed. Connecting to cable (Parallel Port - LPT1). Checking cable driver. Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021. Cable connection failed. Connecting to cable (Parallel Port - LPT2). Checking cable driver. Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021. Cable connection failed. Connecting to cable (Parallel Port - LPT3). Checking cable driver. Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021. Cable connection failed. Connecting to cable (Parallel Port - LPT4). Checking cable driver. Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021. Cable connection failed. PROGRESS_END - End Operation. Elapsed time = 12 sec. Cable autodetection failed. WARNING:iMPACT:923 - Can not find cable, check cable setup ! |
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计51:主要功能测试结果与分析3 nvmePCIe高速存储 PCIe高速存储
447 浏览 0 评论
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
403 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1521 浏览 0 评论
959 浏览 0 评论
900 浏览 0 评论
4439 浏览 63 评论
/9
GMT+8, 2025-12-3 20:03 , Processed in 0.582098 second(s), Total 55, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
25231
