这个编码器模式可以检测出电机旋转方向,比如我下面这段程序,首先对CNT计数器清零,10ms检测一下CNT计数器,来判断接收到的编码盘的脉冲数,那么在向下计数的时候,因为一开始CNT计数器被清零,那么CNT就为-1,-2,,,关键计数器不能为赋值啊!但是下面的程序却能返回赋值,说是补码什么的,不太理解求解释!
//读计数个数 int tiM2_Encoder_Read(void) { TIM2_Encoder_Write(0); //计数器清0 delay_ms(10); //检测时间,可调节 return (int)((s16)(TIM2->CNT)); //数据类型转换 //记录边沿变化次数(几个栅格被记录4次) } |
4个回答
这是图片 |
#include "TIME2.h"
void TIM2_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; NVIC_InitTypeDef NVIC_InitStructure; // TIM_ICInitTypeDef TIM2_ICInitStructure; /* 设置TIM3CLK 为 72MHZ */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); /* GPIOA and GPIOB clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE); //中断分组初始化 NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; //TIM4中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //先占优先级2级 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //从优先级0级 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能 NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器 /*GPIOA Configuration: TIM2 channel 1 and 2 as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; // 浮空输入模式 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化定时器2 TIM2 TIM_TimeBaseStructure.TIM_Period = 10000; //设定计数器自动重装值 TIM_TimeBaseStructure.TIM_Prescaler = 0x0; //预分频器 TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式 TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位 //初始化TIM4输入捕获参数 // TIM2_ICInitStructure.TIM_Channel = TIM_Channel_1; //CC1S=01 选择输入端 IC1映射到TI1上 // TIM2_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获 // TIM2_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI1上 // TIM2_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频 // TIM2_ICInitStructure.TIM_ICFilter = 6;//IC1F=0000 配置输入滤波器 不滤波 // TIM_ICInit(TIM2, &TIM2_ICInitStructure); // TIM_EncoderInterfaceConfig(TIM2,TIM_EncoderMode_TI12,TIM_ICPolarity_Rising, TIM_ICPolarity_Rising);//编码器模式,中断里计算圈数 TIM_ClearFlag(TIM2, TIM_FLAG_Update); TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE); TIM_SetCounter(TIM2, 0); TIM_Cmd(TIM2, ENABLE); } *********************************/ void TIM2_IRQHandler(void) //TIM2中断 { if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //检查指定的TIM中断发生与否:TIM 中断源 { if((TIM2 -> CNT) == 10000) Zhouqi2--; else if((TIM2 -> CNT) == 0) Zhouqi2 ++; TIM_ClearITPendingBit(TIM2, TIM_IT_Update ); //清除TIMx的中断待处理位:TIM 中断源 } } |
最小值减一为最大值。0 减一后 为 65535,不过65535的二进制形式如果理解为负数,因为负数是补码表示的,-1的补码二进制和65535的二进制是一样的,都是 0xFFFF
dragon7799 发表于 2015-9-3 16:46 是不是这个补码存在CNT计数器里面呢?然后发生下溢,CNT计数器更新为ARR的重载值?然后继续向下计数? |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 03:25 , Processed in 0.635557 second(s), Total 52, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3761
