扫一扫,分享给好友
#include
#include #define uchar unsigned char #define uint unsigned int ***it ds = P2^2; ***it dula = P2^6; ***it wela = P2^7; ***it beep = P2^3; bit flag; uint temp; uchar num; uint tmp1; uint i = 0; uint a,b; uchar baie,shie,gee; uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d, 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; uchar code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd, 0x87,0xff,0xef}; void UART_init() { TMOD = 0x20; //T1工作模式2 8位自动重装 TH1 = 0xfd; TL1 = 0xfd; //比特率9600 TR1 = 1; //启动T1定时器 SM0 = 0; SM1 = 1; //串口工作方式1 10位异步 REN = 1; //串口允许接收 EA = 1; //开总中断 ES = 1; //串口中断打开 } void TempDelay(uchar us) { while(us--); //6.51us } void delay(int z) { uint x,y; for(x=z;x>0;x--) for(y=115;y>0;y--); } void display(uint temp) { uchar bai,shi,ge; bai=temp/100; shi=temp%100/10; ge=temp%100%10; dula=1; P0=table[bai]; dula=0; P0=0xff; wela=1; P0=0xfe; wela=0; delay(3); dula=1; P0=table1[shi]; dula=0; P0=0xff; wela=1; P0=0xfd; wela=0; delay(3); dula=1; P0=table[ge]; dula=0; P0=0xff; wela=1; P0=0xfb; wela=0; delay(3); } void ds_reset() { ds=1; _nop_(); ds=0; TempDelay(80);//520us ds=1; TempDelay(5); if(ds==0) flag=1; else flag=0; TempDelay(20); ds=1; } bit ds_read_bit() { bit dat; ds=0; _nop_(); _nop_(); ds=1; _nop_(); dat=ds; TempDelay(12); return dat; } uchar ds_read_byte() { uchar i,j,value; for(i=0;i<8;i++) { j=ds_read_bit(); value=(j<<7)|(value>>1); } return value; } void ds_write_byte(uchar dat) { uchar i,onebit; for(i=0;i<8;i++) { onebit=dat&0x01; if(onebit) //写1 { ds=0; TempDelay(1); ds=1; _nop_(); } else //写0 { ds=0; TempDelay(11); ds=1; _nop_(); } dat>>=1; } } void ds_change() { ds_reset(); ds_write_byte(0xcc); ds_write_byte(0x44); } uint get_temperature() { float temperature; ds_reset(); ds_write_byte(0xcc); ds_write_byte(0xbe); a=ds_read_byte(); b=ds_read_byte(); temp=b; temp<<=8; temp|=a; temperature=temp*0.0625; temp=temperature*10+0.5; return temp; } void main() { UART_init(); //串口初始化 // while(1); ds_change(); delay(1000); while(1) { display(get_temperature()); ds_change(); // if(get_temperature()>350)//35度蜂鸣器发声 // beep=0; // else // beep=1; } } void UART() interrupt 4 { if(RI) //检测是否接收完成 { num = SBUF; //num 取出接收缓存器的值 P1 = num; RI = 0; tmp1 = get_temperature(); baie=tmp1/100; shie=tmp1%100/10; gee=tmp1%100%10; // if(num ==238) // { // SBUF = gee; // } //// else if (num ==0xff) // { // SBUF = shie; // } // else if(num ==0x00) // { SBUF = baie; // } RI = 0; //清除接收标志位,以便于下次接收 } while(!ti); TI = 0; } 这是51单片机的代码 通过串口发送大于255的数值到上位机
1个回答
楼主,为什么我用蓝牙接收数据,手机收不到
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
749 浏览 0 评论
595 浏览 0 评论
647 浏览 0 评论
890 浏览 0 评论
980 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17098 浏览 31 评论
/9
GMT+8, 2025-12-17 20:12 , Processed in 0.638379 second(s), Total 75, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2975
