电子发烧友论坛|
AN-107Manual Soldering Technique For Z-COMM VCOsThis note describes common manufacturing methods used to solder Z-COMM surface mount and pinmount VCOs. Following the suggested practices will ensure optimum performance and repeatedproduct reliability.Surface Mount VCOsThe Mini, Sub-Mini, and S package devices can be soldered manually or through an automated process.Recommendations for both approaches are detailed below.Manual ProcessApply solder to the half-moon connections around the periphery of the VCO package (see FigureAN-107:1). Once the device's ground plane is heated, connection will normally require 5 seconds orless. For proper grounding, all of the contacts must be soldered. Care must be taken to ensure goodsolder connections without applying excess solder. Also, iron contact with VCO should be executedquickly to prevent heat damage.
1 个讨论
只有小组成员才能发言,加入小组>>
585个成员聚集在这个小组
加入小组Prolith和HyperLith主要用于mask-in-stepper lithography仿真、光刻设计
7037浏览 1评论
10113浏览 0评论
/9
GMT+8, 2025-12-14 07:37 , Processed in 0.713045 second(s), Total 53, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3526
