#include
#include // typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 无符号8位整型变量 */ typedef signed char S8; /* defined for signed 8-bits integer variable 有符号8位整型变量 */ typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 无符号16位整型变量 */ typedef signed int S16; /* defined for signed 16-bits integer variable 有符号16位整型变量 */ typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 无符号32位整型变量 */ typedef signed long S32; /* defined for signed 32-bits integer variable 有符号32位整型变量 */ typedef float F32; /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */ typedef double F64; /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */ // #define uchar unsigned char #define uint unsigned int #define Data_0_time 4 //----------------------------------------------// //----------------IO口定义区--------------------// //----------------------------------------------// ***it P2_0 = P2^0 ; //----------------------------------------------// //----------------定义区--------------------// //----------------------------------------------// U8 U8FLAG,k; U8 U8count,U8temp; U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata; U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp; U8 U8comdata; U8 outdata[5]; //定义发送的字节数 U8 indata[5]; U8 count, count_r=0; U8 str[5]={"RS232"}; U16 U16temp1,U16temp2; SendData(U8 *a) { outdata[0] = a[0]; outdata[1] = a[1]; outdata[2] = a[2]; outdata[3] = a[3]; outdata[4] = a[4]; count = 1; // SBUF=outdata[0]; // } void Delay(U16 j) { U8 i; for(;j>0;j--) { for(i=0;i<27;i++); } } void Delay_10us(void) { U8 i; i--; i--; i--; i--; i--; i--; } void COM(void) { U8 i; for(i=0;i<8;i++) { while((P2_0)&&U8FLAG++); U8FLAG=2; while((!P2_0)&&U8FLAG++); Delay_10us(); Delay_10us(); Delay_10us(); U8temp=0; if(P2_0)U8temp=1; U8FLAG=2; //超时则跳出for循环 if(U8FLAG==1)break; //判断数据位是0还是1 // 如果高电平高过预定0高电平值则数据位为 1 U8comdata<<=1; U8comdata|=U8temp; //0 }//rof } //-------------------------------- //-----湿度读取子程序 ------------ //-------------------------------- //----以下变量均为全局变量-------- //----温度高8位== U8T_data_H------ //----温度低8位== U8T_data_L------ //----湿度高8位== U8RH_data_H----- //----湿度低8位== U8RH_data_L----- //----校验 8位 == U8checkdata----- //----调用相关子程序如下---------- //---- Delay();, Delay_10us();,COM(); //-------------------------------- void RH(void) { //主机拉低18ms P2_0=0; Delay(180); P2_0=1; //总线由上拉电阻拉高 主机延时20us Delay_10us(); Delay_10us(); Delay_10us(); Delay_10us(); //主机设为输入 判断从机响应信号 P2_0=1; //判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行 if(!P2_0) //T ! { U8FLAG=2; //判断从机是否发出 80us 的低电平响应信号是否结束 while((!P2_0)&&U8FLAG++); U8FLAG=2; //判断从机是否发出 80us 的高电平,如发出则进入数据接收状态 while((P2_0)&&U8FLAG++); //数据接收状态 COM(); U8RH_data_H_temp=U8comdata; COM(); U8RH_data_L_temp=U8comdata; COM(); U8T_data_H_temp=U8comdata; COM(); U8T_data_L_temp=U8comdata; COM(); U8checkdata_temp=U8comdata; P2_0=1; //数据校验 U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp); if(U8temp==U8checkdata_temp) { U8RH_data_H=U8RH_data_H_temp; U8RH_data_L=U8RH_data_L_temp; U8T_data_H=U8T_data_H_temp; U8T_data_L=U8T_data_L_temp; U8checkdata=U8checkdata_temp; }//fi }//fi } //---------------------------------------------- //main()功能描述: AT89C51 11.0592MHz 串口发 //送温湿度数据,波特率 9600 //---------------------------------------------- void main() { U8 i,j; uchar str[6]={"RS232"}; /* 系统初始化 */ TMOD = 0x20; //定时器T1使用工作方式2 TH1 = 253; // 设置初值 TL1 = 253; TR1 = 1; // 开始计时 SCON = 0x50; //工作方式1,波特率9600bps,允许接收 ES = 1; EA = 1; // 打开所以中断 TI = 0; RI = 0; SendData(str) ; //发送到串口 Delay(1); //延时100US(12M晶振) while(1) { //------------------------ //调用温湿度读取子程序 RH(); //串口显示程序 //-------------------------- str[0]=U8RH_data_H; str[1]=U8RH_data_L; str[2]=U8T_data_H; str[3]=U8T_data_L; str[4]=U8checkdata; SendData(str) ; //发送到串口 //读取模块数据周期不易小于 2S Delay(20000); }//elihw }// main void RSINTR() interrupt 4 using 2 { U8 InPut3; if(TI==1) //发送中断 { TI=0; if(count!=5) //发送完5位数据 { SBUF= outdata[count]; count++; } } if(RI==1) //接收中断 { InPut3=SBUF; indata[count_r]=InPut3; count_r++; RI=0; if (count_r==5)//接收完4位数据 { //数据接收完毕处理。 count_r=0; str[0]=indata[0]; str[1]=indata[1]; str[2]=indata[2]; str[3]=indata[3]; str[4]=indata[4]; P0=0; } } } 有没有大神能帮我看一眼上位机为什么接收到的是乱码 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
飞凌嵌入式-ELFBOARD 解决PCB布线时无法捕捉到焊盘中心的问题
176 浏览 0 评论
Openharmony软件评估指南-米尔瑞芯微RK3568开发板
700 浏览 0 评论
STM32CUBEMX(7)--移植雅特力AT32F403AVGT(兼容STM32F103VGT6),DAC输出电压
1097 浏览 0 评论
【RA-Eco-RA0E1-32PIN-V1.0开发板试用】开发板简介与上电测试
1004 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之传参
555 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11048 浏览 31 评论
GMT+8, 2024-9-11 04:59 , Processed in 0.581006 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
