扫一扫,分享给好友
stc15f2k60s2与DHT11 将DHT11采集到的温湿度通过串口发送 为什么是乱码 程序如下
#include #include #include typedef unsigned char BYTE; typedef unsigned int WORD; typedef unsigned char u8; #define uint unsigned int #define uchar unsigned char #define FOSC 11059200L // #define BAUD 115200 // ***it io=P2^0; bit busy; u8 datas=0; uchar data_byte; uchar RH,TH,RL,TL,T_H,T_L,R_H,R_L,check,num_check,flag,a,R,T; void delay(uchar ms) { uchar i; while(ms--) for(i=0;i<100;i++); } void delay1() { uchar i; for(i=0;i<1;i++); } void start() { io=1; delay1(); io=0; delay(25); io=1; delay1(); delay1(); delay1(); } uchar receive_byte() { uchar i,temp; for(i=0;i<8;i++) { while(!io); delay1(); delay1(); delay1(); temp=0; if(io==1) temp=1; while(io); data_byte<<=1; data_byte|=temp; } return data_byte; } u8 receive() { uchar i; start(); io=1; if(!io) { while(!io); while(io); R_H=receive_byte(); R_L=receive_byte(); T_H=receive_byte(); T_L=receive_byte(); check=receive_byte(); io=0; for(i=0;i<7;i++) delay1(); io=1; num_check=R_H+R_L+T_H+T_L; if(num_check==check) { RH=R_H; RL=R_L; R=RH+RL; TH=T_H; TL=T_L; T=TH+TL; check=num_check; } } return RH; } u8 receive1() { uchar i; start(); io=1; if(!io) { while(!io); while(io); R_H=receive_byte(); R_L=receive_byte(); T_H=receive_byte(); T_L=receive_byte(); check=receive_byte(); io=0; for(i=0;i<7;i++) delay1(); io=1; num_check=R_H+R_L+T_H+T_L; if(num_check==check) { RH=R_H; RL=R_L; R=RH+RL; TH=T_H; TL=T_L; T=TH+TL; check=num_check; } } return TH; } void init() { AUXR = 0x40; TMOD = 0x20; TL1 = (65536- (FOSC/32/BAUD)); TH1 = (65536 - (FOSC/32/BAUD)); TR1 = 1; ES = 1; EA = 1; } void main() { init();//串口初始化 io = 1; while(1) { datas=receive(); datas=T; SendData(datas%100/10+'0');//十位 SendData(datas%10+'0'); //个位 datas=receive1(); datas=R; SendData(datas%100/10+'0');//十位 SendData(datas%10+'0'); //个位 } } void Uart() interrupt 4 using 1 { if (RI) { RI = 0; //清除RI位 P0 = SBUF; //P0显示串口数据 P22 = RB8; //P2.2显示校验位 } if (ti) { TI = 0; //清除TI位 //清忙标志 } } |
1个回答
时序是对的吗?有可能时序不对会导致收到乱码,还有就是发送是先发高位还是低位?
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16899 浏览 31 评论
/9
GMT+8, 2025-12-1 19:43 , Processed in 0.635557 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1267
