48.2 官方WIDGET_Menu实例 官方的这个实例很好的演示了Header的使用,这个例子在模拟器中的位置:
源码如下(程序中进行了详细的注释):
- File : WIDGET_Menu.c
- Purpose : Shows how to work with menu widget
- Requirements: WindowManager - (x)
- MemoryDevices - (x)
- AntiAliasing - ( )
- VNC-Server - ( )
- PNG-Library - ( )
- TrueTypeFonts - ( )
- #include
- #include "GUI.h"
- #include "DIALOG.h"
- #include "MENU.h"
- #include "MESSAGEBOX.h"
- * Defines
- #define ID_MENU (GUI_ID_USER + 0)
- #define ID_MENU_FILE_NEW (GUI_ID_USER + 1)
- #define ID_MENU_FILE_OPEN (GUI_ID_USER + 2)
- #define ID_MENU_FILE_CLOSE (GUI_ID_USER + 3)
- #define ID_MENU_FILE_EXIT (GUI_ID_USER + 4)
- #define ID_MENU_FILE_RECENT (GUI_ID_USER + 5)
- #define ID_MENU_RECENT_0 (GUI_ID_USER + 6)
- #define ID_MENU_RECENT_1 (GUI_ID_USER + 7)
- #define ID_MENU_RECENT_2 (GUI_ID_USER + 8)
- #define ID_MENU_RECENT_3 (GUI_ID_USER + 9)
- #define ID_MENU_EDIT_UNDO (GUI_ID_USER + 10)
- #define ID_MENU_EDIT_REDO (GUI_ID_USER + 11)
- #define ID_MENU_EDIT_COPY (GUI_ID_USER + 12)
- #define ID_MENU_EDIT_PASTE (GUI_ID_USER + 13)
- #define ID_MENU_EDIT_DELETE (GUI_ID_USER + 14)
- #define ID_MENU_HELP_ABOUT (GUI_ID_USER + 15)
- * Static data
- static WM_HWIN _hMenu;
- static WM_HWIN _hText;
- static WM_HWIN _hFrame;
- static char * _paDescription[] = {
- "Creates a new file",
- "Opens an existing file",
- "Closes the file",
- "Quits the application",
- "Opens file 1",
- "Opens file 2",
- "Opens file 3",
- "Opens file 4",
- "Undoes the last action",
- "Redoes the previously undone action",
- "Copies to clipboard",
- "Inserts contents of clipboard",
- "Deletes the selection",
- "Displays program information"
- * Static code
- * _AddMenuItem
- static void _AddMenuItem(MENU_Handle hMenu, MENU_Handle hSubmenu, const char* pText, U16 Id, U16 Flags) {
- MENU_ITEM_DATA Item;
- Item.pText = pText;
- Item.hSubmenu = hSubmenu;
- Item.Flags = Flags;
- Item.Id = Id;
- MENU_AddItem(hMenu, &Item);
- * _CreateMenu
- * 创建菜单控件
- static WM_HWIN _CreateMenu(WM_HWIN hParent) {
- MENU_Handle hMenu;
- MENU_Handle hMenuFile;
- MENU_Handle hMenuEdit;
- MENU_Handle hMenuHelp;
- MENU_Handle hMenuRecent;
- // Create main menu
- hMenu = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_HORIZONTAL, ID_MENU);
- // Create sub menus
- hMenuFile = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_VERTICAL, 0);
- hMenuEdit = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_VERTICAL, 0);
- hMenuHelp = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_VERTICAL, 0);
- hMenuRecent = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_VERTICAL, 0);
- // Add menu items to menu 'Recent'
- _AddMenuItem(hMenuRecent, 0, "File 1", ID_MENU_RECENT_0, 0);
- _AddMenuItem(hMenuRecent, 0, "File 2", ID_MENU_RECENT_1, 0);
- _AddMenuItem(hMenuRecent, 0, "File 3", ID_MENU_RECENT_2, 0);
- _AddMenuItem(hMenuRecent, 0, "File 4", ID_MENU_RECENT_3, 0);
- // Add menu items to menu 'File'
- _AddMenuItem(hMenuFile, 0, "New", ID_MENU_FILE_NEW, 0);
- _AddMenuItem(hMenuFile, 0, "Open", ID_MENU_FILE_OPEN, 0);
- _AddMenuItem(hMenuFile, 0, "Close", ID_MENU_FILE_CLOSE, MENU_IF_DISABLED);
- _AddMenuItem(hMenuFile, 0, 0, 0, MENU_IF_SEPARATOR);
- _AddMenuItem(hMenuFile, hMenuRecent, "Files...", ID_MENU_FILE_RECENT, 0);
- _AddMenuItem(hMenuFile, 0, "Exit", ID_MENU_FILE_EXIT, 0);
- // Add menu items to menu 'Edit'
- _AddMenuItem(hMenuEdit, 0, "Undo", ID_MENU_EDIT_UNDO, 0);
- _AddMenuItem(hMenuEdit, 0, "Redo", ID_MENU_EDIT_REDO, 0);
- _AddMenuItem(hMenuEdit, 0, 0, 0, MENU_IF_SEPARATOR);
- _AddMenuItem(hMenuEdit, 0, "Copy", ID_MENU_EDIT_COPY, 0);
- _AddMenuItem(hMenuEdit, 0, "Paste", ID_MENU_EDIT_PASTE, 0);
- _AddMenuItem(hMenuEdit, 0, "Delete", ID_MENU_EDIT_DELETE, 0);
- // Add menu items to menu 'Help'
- _AddMenuItem(hMenuHelp, 0, "About", ID_MENU_HELP_ABOUT, 0);
- // Add menu items to main menu
- _AddMenuItem(hMenu, hMenuFile, "File", 0, 0);
- _AddMenuItem(hMenu, hMenuEdit, "Edit", 0, 0);
- _AddMenuItem(hMenu, hMenuHelp, "Help", 0, 0);
- // Attach menu to parent window
- FRAMEWIN_AddMenu(hParent, hMenu);
- return hMenu;
- * _DrawGradientV
- * 实现垂直的颜色梯度
- static void _DrawGradientV(int x0, int y0, int x1, int y1, GUI_COLOR Color0, GUI_COLOR Color1) {
- int r0;
- int g0;
- int b0;
- int r1;
- int g1;
- int b1;
- int y;
- int ySize;
- int r;
- int g;
- I32 b;
- int Diff;
- ySize = y1 - y0 + 1;
- r0 = (Color0 >> 0) & 0x000000ff;
- g0 = (Color0 >> 8) & 0x000000ff;
- b0 = (Color0 >> 16) & 0x000000ff;
- r1 = (Color1 >> 0) & 0x000000ff;
- g1 = (Color1 >> 8) & 0x000000ff;
- b1 = (Color1 >> 16) & 0x000000ff;
- for (y = y0; y <= y1; y++) {
- GUI_COLOR Color;
- Diff = y - y0;
- r = r0 + (r1 - r0) * Diff / ySize;
- g = g0 + (g1 - g0) * Diff / ySize;
- b = b0 + (b1 - b0) * Diff / ySize;
- Color = r | (g << 8) | (b << 16);
- GUI_SetColor(Color);
- GUI_DrawHLine(y, x0, x1);
- * _MessageBox
- * 创建并执行模态的消息框
- static void _MessageBox(const char * pText, const char * pCaption) {
- WM_HWIN hBox;
- hBox = MESSAGEBOX_Create(pText, pCaption, GUI_MESSAGEBOX_CF_MODAL | GUI_MESSAGEBOX_CF_MOVEABLE);
- WM_SetStayOnTop(hBox, 1);
- WM_BringToTop(hBox);
- GUI_ExecCreatedDialog(hBox);
- WM_SetFocus(_hMenu);
- MENU_SetSel(_hMenu, -1);
- * _cbClient
- * 框架窗口的回调函数
- static void _cbClient(WM_MESSAGE * pMsg) {
- char acBuffer[50];
- int Index;
- int xSize;
- int ySize;
- int xPos;
- int yPos;
- WM_HWIN hWin;
- WM_HWIN hClient;
- MENU_MSG_DATA * pData;
- MENU_ITEM_DATA Data;
- hWin = pMsg->hWin;
- hClient = WM_GetClientWindow(hWin);
- xSize = WM_GetWindowSizeX(hClient);
- ySize = WM_GetWindowSizeY(hClient);
- switch (pMsg->MsgId) {
- case WM_SIZE:
- // 如果改变窗口控件大小的话,这里是重新设置文本控件的位置。
- xPos = WM_GetWindowOrgX(hClient);
- yPos = WM_GetWindowOrgY(hClient);
- WM_SetWindowPos(_hText, xPos + 4, yPos + ySize - 10, xSize, 10);
- WM_SetWindowPos(_hMenu, xPos , yPos , xSize, WM_GetWindowSizeY(_hMenu));
- TEXT_SetText(_hText, "Ready");
- break;
- case WM_PAINT:
- // 绘制框架窗口中用户区部分的背景
- _DrawGradientV(0, 0, xSize - 1, ySize - 12 - 1, GUI_WHITE, GUI_LIGHTBLUE);
- GUI_SetColor(GUI_LIGHTGRAY);
- GUI_FillRect(0, ySize - 12, xSize - 1, ySize - 1);
- GUI_SetTextMode(GUI_TM_TRANS);
- GUI_SetColor(GUI_BLACK);
- GUI_SetFont(&GUI_Font24B_ASCII);
- GUI_DispStringHCenterAt(
- "MENU widget sample"
- , xSize / 2, 40);
- GUI_SetFont(&GUI_Font16B_ASCII);
- "The sample shows how to use the MENUn"
- "widget. Use the keyboard or the pointern"
- "input device for playing with the widget.n"
- "On highlighting a menu item the statusn"
- "bar shows a small description. On selectingn"
- "a menu item a message box will be shown."
- , xSize / 2, 70);
- break;
- case WM_MENU:
- pData = (MENU_MSG_DATA*)pMsg->Data.p;
- switch (pData->MsgType) {
- case MENU_ON_ITEMPRESSED:
- //按下菜单项之后,将发送此消息给小工具的所有者窗口。对于
- //已禁用的菜单项,也将发送此消息
- MENU_GetItem(pMsg->hWinSrc, pData->ItemId, &Data);
- if (Data.Flags & MENU_IF_DISABLED) {
- _MessageBox("The pressed item was disabled", "Message");
- break;
- case MENU_ON_ITEMACTIVATE:
- // 菜单项被高亮显示之后,菜单的所有者窗口将收到此消息。将
- // 子菜单高亮显示之后,则不会发送此消息
- Index = pData->ItemId - ID_MENU_FILE_NEW;
- if (Index >= 0) {
- TEXT_SetText(_hText, _paDescription[pData->ItemId - ID_MENU_FILE_NEW]);
- } else {
- break;
- case MENU_ON_ITEMSELECT:
- // 选择菜单项之后将立即发送此消息给菜单的所有者。ItemId
- // 元素包含已按下的菜单项的Id。
- sprintf(acBuffer, "ID of the selectednitem is 0x%X", pData->ItemId);
- _MessageBox(acBuffer, "Message");
- break;
- WM_DefaultProc(pMsg);
- * Public code
- * MainTask
- void MainTask(void) {
- int xSize;
- int ySize;
- WM_HWIN hClient;
- GUI_Init();
- // 通过下面两个函数使能所有窗口使用内存设备
- #if GUI_SUPPORT_MEMDEV
- WM_SetCreateFlags(WM_CF_MEMDEV);
- WM_EnableMemdev(WM_HBKWIN);
- #endif
- WM_SetDesktopColor(GUI_BLACK);
- MENU_SetDefaultEffect(&WIDGET_Effect_3D1L);
- // 创建框架窗口
- _hFrame = FRAMEWIN_CreateEx(10, 10, 300, 220, WM_HBKWIN, WM_CF_SHOW, FRAMEWIN_CF_MOVEABLE, 0, "Application with menu", _cbClient);
- FRAMEWIN_SetFont(_hFrame, &GUI_Font13_ASCII);
- FRAMEWIN_AddMaxButton(_hFrame, FRAMEWIN_BUTTON_RIGHT, 0); /* 添加框架窗口最大化按钮 */
- FRAMEWIN_AddMinButton(_hFrame, FRAMEWIN_BUTTON_RIGHT, 2); /* 添加框架窗口最小化按钮 */
- // 创建菜单控件
- _hMenu = _CreateMenu(_hFrame);
- // 创建文本控件
- hClient = WM_GetClientWindow(_hFrame);
- _hText = TEXT_CreateEx(4, ySize - 10, xSize, 10, hClient, WM_CF_SHOW, 0, GUI_ID_TEXT0, "Ready");
- TEXT_SetFont(_hText, &GUI_Font8_ASCII);
- // 创建菜单控件
- while (1) {
- GUI_Delay(100);
复制代码
例子的实际显示效果如下: |
