51.2 官方WIDGET_Multipage实例 官方的这个实例很好的演示了MULTIPAGE的使用,这个例子在模拟器中的位置:
源码如下(程序中进行了详细的注释):
- #include
- #include "GUI.h"
- #include "MULTIPAGE.h"
- * Static data
- * Dialog resource
- * These tables contain the information required to create the dialogs.
- * It has been created manually, but could also be created by the GUIBuilder.
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate1[] = {
- { WINDOW_CreateIndirect, "Dialog 1", 0, 0, 0, 260, 100, FRAMEWIN_CF_MOVEABLE },
- { BUTTON_CreateIndirect, "Button", GUI_ID_BUTTON0, 5, 30, 80, 20, 0},
- { TEXT_CreateIndirect, "Dialog 1", 0, 5, 10, 50, 20, TEXT_CF_LEFT }
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate2[] = {
- { WINDOW_CreateIndirect, "Dialog 2", 0, 0, 0, 260, 100, FRAMEWIN_CF_MOVEABLE },
- { CHECKBOX_CreateIndirect, "", GUI_ID_CHECK0, 5, 30, 0, 0, 0},
- { CHECKBOX_CreateIndirect, "", GUI_ID_CHECK1, 5, 50, 0, 0, 0},
- { TEXT_CreateIndirect, "Select 0", GUI_ID_TEXT0, 25, 30, 50, 15, TEXT_CF_LEFT },
- { TEXT_CreateIndirect, "Select 1", GUI_ID_TEXT1, 25, 50, 50, 15, TEXT_CF_LEFT },
- { TEXT_CreateIndirect, "Dialog 2", 0, 5, 10, 50, 20, TEXT_CF_LEFT }
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate3[] = {
- { WINDOW_CreateIndirect, "Dialog 3", 0, 0, 0, 260, 100, FRAMEWIN_CF_MOVEABLE },
- { RADIO_CreateIndirect, "", GUI_ID_RADIO0, 5, 30, 0, 0, 0, 3},
- { TEXT_CreateIndirect, "Option 1", GUI_ID_TEXT0, 25, 30, 50, 15, TEXT_CF_LEFT },
- { TEXT_CreateIndirect, "Option 2", GUI_ID_TEXT1, 25, 50, 50, 15, TEXT_CF_LEFT },
- { TEXT_CreateIndirect, "Option 3", GUI_ID_TEXT2, 25, 70, 50, 15, TEXT_CF_LEFT },
- { TEXT_CreateIndirect, "Dialog 3", 0, 5, 10, 50, 20, TEXT_CF_LEFT }
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate4[] = {
- { WINDOW_CreateIndirect, "Dialog 4", 0, 0, 0, 260, 100, FRAMEWIN_CF_MOVEABLE },
- { MULTIEDIT_CreateIndirect, "Text", GUI_ID_MULTIEDIT0, 5, 30, 200, 40 },
- { TEXT_CreateIndirect, "Dialog 4", 0, 5, 10, 50, 20, TEXT_CF_LEFT }
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate5[] = {
- { WINDOW_CreateIndirect, "Dialog 5", 0, 0, 0, 260, 100, FRAMEWIN_CF_MOVEABLE },
- { SLIDER_CreateIndirect, "", GUI_ID_SLIDER0, 5, 30, 200, 40 },
- { TEXT_CreateIndirect, "Dialog 5", 0, 5, 10, 50, 20, TEXT_CF_LEFT }
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate6[] = {
- { WINDOW_CreateIndirect, "Dialog 6", 0, 0, 0, 260, 100, FRAMEWIN_CF_MOVEABLE },
- { SCROLLBAR_CreateIndirect, "", GUI_ID_SCROLLBAR0, 5, 30, 200, 40 },
- { TEXT_CreateIndirect, "Dialog 6", 0, 5, 10, 50, 20, TEXT_CF_LEFT }
- * Static code
- * _cbDialog4
- static void _cbDialog4(WM_MESSAGE * pMsg) {
- WM_HWIN hItem;
- WM_HWIN hDlg;
- hDlg = pMsg->hWin;
- switch (pMsg->MsgId) {
- case WM_INIT_DIALOG:
- hItem = WM_GetDialogItem(hDlg, GUI_ID_MULTIEDIT0);
- MULTIEDIT_SetText(hItem, "MULTIEDIT widget");
- MULTIEDIT_SetInsertMode(hItem, 1);
- break;
- default:
- WM_DefaultProc(pMsg);
- * _cbBkWindow
- * 桌面窗口的回调函数,主要是重绘部分
- static void _cbBkWindow(WM_MESSAGE * pMsg) {
- case WM_PAINT:
- GUI_SetBkColor(GUI_BLUE);
- GUI_Clear();
- GUI_SetColor(GUI_WHITE);
- GUI_SetFont(&GUI_Font24_ASCII);
- GUI_DispStringHCenterAt("WIDGET_Multipage - Sample", 160, 5);
- break;
- default:
- * Public code
- * MainTask
- void MainTask(void) {
- WM_HWIN hMultiPage;
- WM_HWIN hFrameWin;
- WM_HWIN hDialog;
- // 使能窗口使用内存设备
- WM_SetCreateFlags(WM_CF_MEMDEV);
- GUI_Init();
- /* 设置桌面窗口的回调函数 */
- WM_SetCallback(WM_HBKWIN, _cbBkWindow);
- // 创建框架窗口
- hFrameWin = FRAMEWIN_Create("FrameWindow", NULL, WM_CF_SHOW, 40, 44, 240, 152);
- /* 设置窗口的属性 */
- FRAMEWIN_SetClientColor(hFrameWin, GUI_GREEN);
- FRAMEWIN_SetActive(hFrameWin, 1);
- FRAMEWIN_SetMoveable(hFrameWin, 1);
- // 在框架窗口上创建多页控件
- hMultiPage = MULTIPAGE_CreateEx(7, 6, 220, 120, WM_GetClientWindow(hFrameWin), WM_CF_SHOW, 0, 0);
- GUI_Delay(500);
- // 在多页控件的每页上面创建对话框,创建了对话框后,要通过函数MULTIPAGE_AddPage进行添加。
- hDialog = GUI_CreateDialogBox(_aDialogCreate1, GUI_COUNTOF(_aDialogCreate1), NULL, WM_UNATTACHED, 0, 0);
- MULTIPAGE_AddPage(hMultiPage, hDialog, "Page 1");
- GUI_Delay(500);
- hDialog = GUI_CreateDialogBox(_aDialogCreate2, GUI_COUNTOF(_aDialogCreate2), NULL, WM_UNATTACHED, 0, 0);
- MULTIPAGE_AddPage(hMultiPage, hDialog, "Page 2");
- GUI_Delay(500);
- hDialog = GUI_CreateDialogBox(_aDialogCreate3, GUI_COUNTOF(_aDialogCreate3), NULL, WM_UNATTACHED, 0, 0);
- MULTIPAGE_AddPage(hMultiPage, hDialog, "Page 3");
- GUI_Delay(500);
- hDialog = GUI_CreateDialogBox(_aDialogCreate4, GUI_COUNTOF(_aDialogCreate4), _cbDialog4, WM_UNATTACHED, 0, 0);
- MULTIPAGE_AddPage(hMultiPage, hDialog, "Page 4");
- GUI_Delay(500);
- hDialog = GUI_CreateDialogBox(_aDialogCreate5, GUI_COUNTOF(_aDialogCreate5), NULL, WM_UNATTACHED, 0, 0);
- MULTIPAGE_AddPage(hMultiPage, hDialog, "Page 5");
- GUI_Delay(500);
- hDialog = GUI_CreateDialogBox(_aDialogCreate6, GUI_COUNTOF(_aDialogCreate6), NULL, WM_UNATTACHED, 0, 0);
- MULTIPAGE_AddPage(hMultiPage, hDialog, "Page 6");
- GUI_Delay(500);
- // 通过函数MULTIPAGE_SetAlign设置对齐
- MULTIPAGE_SetAlign(hMultiPage, MULTIPAGE_ALIGN_RIGHT);
- GUI_Delay(500);
- MULTIPAGE_SetAlign(hMultiPage, MULTIPAGE_ALIGN_RIGHT | MULTIPAGE_ALIGN_BOTTOM);
- GUI_Delay(500);
- MULTIPAGE_SetAlign(hMultiPage, MULTIPAGE_ALIGN_LEFT | MULTIPAGE_ALIGN_BOTTOM);
- while (1) {
- GUI_Delay(100);
复制代码
这个例子给出了多页控件的基本使用方法,如果想使用多页控件的话,这个例子很有参考价值。实际显示效果如下: |
