41.2 官方WIDGET_CheckBox实例 官方的这个例子做的很好,充分的演示了复选框的各个状态。这个例子在模拟器中的位置:
源代码如下(主要看WIDGET_Checkbox中的代码):
- #include
- #include "GUI.h"
- #include "DIALOG.h"
- #include "Main.h"
- * Static data
- // Dialog resource
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {(1)
- { FRAMEWIN_CreateIndirect, "Check box sample", 0, 10, 10, 300, 220, FRAMEWIN_CF_MOVEABLE},
- { TEXT_CreateIndirect, "Enabled:", 0, 5, 10, 120, 0 },
- { CHECKBOX_CreateIndirect, 0, GUI_ID_CHECK0, 5, 30, 120, 0 },
- { CHECKBOX_CreateIndirect, 0, GUI_ID_CHECK1, 5, 60, 120, 0 },
- { CHECKBOX_CreateIndirect, 0, GUI_ID_CHECK2, 5, 90, 120, 20 },
- { CHECKBOX_CreateIndirect, 0, GUI_ID_CHECK3, 5, 125, 120, 26 },
- { TEXT_CreateIndirect, "Disabled:", 0, 150, 10, 120, 0 },
- { CHECKBOX_CreateIndirect, 0, GUI_ID_CHECK4, 150, 30, 120, 0 },
- { CHECKBOX_CreateIndirect, 0, GUI_ID_CHECK5, 150, 60, 120, 0 },
- { CHECKBOX_CreateIndirect, 0, GUI_ID_CHECK6, 150, 90, 120, 26 },
- { CHECKBOX_CreateIndirect, 0, GUI_ID_CHECK7, 150, 125, 120, 26 },
- { BUTTON_CreateIndirect, "OK", GUI_ID_OK, 10, 170, 60, 20 },
- { BUTTON_CreateIndirect, "Cancel", GUI_ID_CANCEL, 225, 170, 60, 20 },
- // Check box text
- static const char * _apLabel[] = {(2)
- "Default",
- "3 States",
- "Box XL",
- "Box XXL"
- * Static code
- * _cbCallback
- static void _cbCallback(WM_MESSAGE * pMsg) {
- WM_HWIN hDlg;
- WM_HWIN hItem;
- int i;
- int NCode;
- int Id;
- hDlg = pMsg->hWin;
- switch (pMsg->MsgId) {
- case WM_INIT_DIALOG:
- WM_GetDialogItem(hDlg, GUI_ID_CHECK0);
- for (i = 0; i < 8; i++) {(3)
- int Index = i % 4;
- hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK0 + i); // Get the handle of the desired checkbox
- CHECKBOX_SetText(hItem, _apLabel[Index]); // Set the check box text(4)
- switch (Index) {
- case 1:(5)
- // Set the number of possible states to 3
- CHECKBOX_SetNumStates(hItem, 3);(6)
- // Use user defined bitmaps for the third state
- //(7)
- CHECKBOX_SetImage(hItem, &_abmBar[0], CHECKBOX_BI_INACTIV_3STATE); // Used if widget is disabled
- CHECKBOX_SetImage(hItem, &_abmBar[1], CHECKBOX_BI_ACTIV_3STATE); // Used if widget is enabled
- CHECKBOX_SetState(hItem, 2);(8)
- break;
- case 2:(9)
- CHECKBOX_SetState(hItem, 1);
- // Use user defined bitmaps for the 'checked' state
- CHECKBOX_SetImage(hItem, &_abmXL[0], CHECKBOX_BI_INACTIV_CHECKED); // Used if widget is disabled
- CHECKBOX_SetImage(hItem, &_abmXL[1], CHECKBOX_BI_ACTIV_CHECKED); // Used if widget is enabled
- CHECKBOX_SetFont(hItem, &GUI_FontComic18B_ASCII);
- break;
- case 3:(10)
- CHECKBOX_SetImage(hItem, &_abmXXL[0], CHECKBOX_BI_INACTIV_CHECKED); // Used if widget is disabled
- CHECKBOX_SetImage(hItem, &_abmXXL[1], CHECKBOX_BI_ACTIV_CHECKED); // Used if widget is enabled
- CHECKBOX_SetFont(hItem, &GUI_FontComic24B_ASCII);
- break;
- // Disable all check boxes shown on the right side of the dialog
- if (i >= 4) {(11)
- WM_DisableWindow(hItem);
- break;
- case WM_NOTIFY_PARENT:
- Id = WM_GetId(pMsg->hWinSrc); // Id of widget
- NCode = pMsg->Data.v; // Notification code
- switch (NCode) {
- case WM_NOTIFICATION_RELEASED: // React only if released
- if (Id == GUI_ID_OK) { // OK Button
- GUI_EndDialog(hDlg, 0);
- if (Id == GUI_ID_CANCEL) { // Cancel Button
- GUI_EndDialog(hDlg, 1);
- break;
- break;
- default:
- WM_DefaultProc(pMsg);
- * Public code
- * MainTask
- void MainTask(void) {
- #if GUI_SUPPORT_MEMDEV
- WM_SetCreateFlags(WM_CF_MEMDEV);
- #endif
- GUI_Init();
- WM_SetDesktopColor(GUI_BLACK);
- while (1) {
- GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
- GUI_Delay(500);
复制代码
1. 对话框中控件的资源表,具体每个控件的参数,看前面38.6.1的介绍。 2. 复选框要显示的文本。 3. 循环8次,为8个复选框进行设置。 4. 函数CHECKBOX_SetText用于设置复选框旁边的可选文本。 5. 确切的说这里的case 1应该算是显示的第二种情况,为了方便起见,我们讲起称之为第一种情况,因为前面已经显示了一种情况。也就是i%4 = 0的情况。 6. 函数CHECKBOX_SetNumStates用于设置复选框可能的状态个数,默认情况下,复选框支持2种状态:选中(1)和未选中(0)。如果复选框要支持第三种状态,可将可能状态增加到3种。 7. 函数CHECKBOX_SetImage用于设置复选框被选中后显示的图像。图像必须填充复选框的整个内部区域。使用此函数时,要确保用于创建小工具的复选框的尺寸足以显示位图和 (可选的)文本。 8. 函数CHECKBOX_SetState用于设置复选框的状态,支持三种状态的显示,可以是选中,取消选中和第三种状态。 9. 情况二,显示一种稍大点的复选框。 10. 情况三,显示一种再大点的复选框。 11. 通过这个函数来禁止右侧复选框的状态。 实际的显示效果如下: |
