扫一扫,分享给好友
各位FPGA的高手们,小弟再做一个FPGA二分频信号时,有一个很困惑的问题,一直搞不明白,具体要求如下硬件连接,编程要求图中电源电压VCC=3.3V,R1 = 1×(1±10%)KΩ,R2 = 1×(1±10%)KΩ,C1 = 30×(1±10%)pF。输入信号F0 = 1MHz,F1 = F0/2,F2 = F1/2,F3 = F2/2,F4 = F3/2,F5 = F4/2,F6 = F5/2,F7 = F6/2,F8 = F7/2,F9 = F8/2,F10 = F9/2,F11 = F10/2,F12 = F11/2,F13 = F12/2,F14 = F13/2,F15 = F14/2,F16 = F15/2, F17 = F16/2,FC0 = 500KHZ,CLK0输入时钟为50MHZ。 ![]() ![]() 现在 我的代码如下: module VDEE5M40( sys_clk, sys_rst, div_clk, cs, led ); input sys_clk; input sys_rst; output cs; output [16:0] div_clk; //地址信号 output [2:0] led; reg clk_2mhz; reg [16:0] clk_2mhz_count; reg [2:0] led; reg [16:0] s_div_clk; //二分频寄存器 reg [31:0] count; reg [31:0] count2; //绯荤粺鏃堕挓璁℃暟 reg [31:0] count3; //500khz璁℃暟 //reg address; reg cs; reg sys_clk500; assign div_clk = s_div_clk ; /*initial begin clk_2mhz_count <=1'b0; clk_2mhz <=1'b0; led <=3'hf8; cs <=1'b0; count <=32'h0000; count2 <=32'h0000; count3 <=19'h0000; end*/ always @(posedge sys_clk or negedge sys_rst)begin //1MHZ if(!sys_rst)begin clk_2mhz <= 1'b0; clk_2mhz_count <= 17'd0; end else begin if(clk_2mhz_count == 17'd24)begin clk_2mhz <= 1'b1; clk_2mhz_count <= 17'd0; end else begin clk_2mhz <= 1'b0; clk_2mhz_count <= clk_2mhz_count + 17'd1; end end end always @(posedge sys_clk or negedge sys_rst ) begin //系统时钟检测 LED[2] if(!sys_rst)begin count2 <= 32'h0000_0000; end else begin if(count2 ==32'd20000_000)begin led[2]<= ~led[2]; count2 <= 32'h0000_0000; end else begin count2 <= count2+1'b1; end end end always @(negedge sys_clk or negedge sys_rst ) begin //500KhZ给予cs端口信号,LED【1】检测 if(!sys_rst) begin sys_clk500 <=0; count3 <=32'h0000_0000; end else begin if(count3==100) begin sys_clk500 <= ~sys_clk500; led [1] <= ~led [1]; count3 <=32'h0000_0000; end else count3 <=count3+1'b1; end end always @(posedge sys_clk500 or negedge sys_rst ) begin //cs片选控制端口LED[0],检测片选信号 if(!sys_rst) begin cs <=1'b1; count <=32'h0000_0000; end else begin if(count <=32'd50000) begin if(count% 2 ==1'b1)begin cs <=~cs; led [0] <= ~led [0]; end else begin cs <=1'b1; end count <=count +1'b1; end else begin count <=32'h0000_0000; //led [0] <= ~led [0]; end end end always @(posedge clk_2mhz or negedge sys_rst)begin //1MHZ频率信号 if(!sys_rst)begin s_div_clk[0] <= 1'b0; end else begin s_div_clk[0] <= ~s_div_clk[0]; end end always @(posedge s_div_clk[0] or negedge sys_rst)begin //500khz棰戠巼 if(!sys_rst)begin s_div_clk[1] <= 1'b0; end else begin s_div_clk[1] <= ~s_div_clk[1]; end end always @(posedge s_div_clk[1] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[2] <= 1'b0; end else begin s_div_clk[2] <= ~s_div_clk[2]; end end always @(posedge s_div_clk[2] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[3] <= 1'b0; end else begin s_div_clk[3] <= ~s_div_clk[3]; end end always @(posedge s_div_clk[3] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[4] <= 1'b0; end else begin s_div_clk[4] <= ~s_div_clk[4]; end end always @(posedge s_div_clk[4] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[5] <= 1'b0; end else begin s_div_clk[5] <= ~s_div_clk[5]; end end always @(posedge s_div_clk[5] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[6] <= 1'b0; end else begin s_div_clk[6] <= ~s_div_clk[6]; end end always @(posedge s_div_clk[6] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[7] <= 1'b0; end else begin s_div_clk[7] <= ~s_div_clk[7]; end end always @(posedge s_div_clk[7] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[8] <= 1'b0; end else begin s_div_clk[8] <= ~s_div_clk[8]; end end always @(posedge s_div_clk[8] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[9] <= 1'b0; end else begin s_div_clk[9] <= ~s_div_clk[9]; end end always @(posedge s_div_clk[9] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[10] <= 1'b0; end else begin s_div_clk[10] <= ~s_div_clk[10]; end end always @(posedge s_div_clk[10] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[11] <= 1'b0; end else begin s_div_clk[11] <= ~s_div_clk[11]; end end always @(posedge s_div_clk[11] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[12] <= 1'b0; end else begin s_div_clk[12] <= ~s_div_clk[12]; end end always @(posedge s_div_clk[12] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[13] <= 1'b0; end else begin s_div_clk[13] <= ~s_div_clk[13]; end end always @(posedge s_div_clk[13] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[14] <= 1'b0; end else begin s_div_clk[14] <= ~s_div_clk[14]; end end always @(posedge s_div_clk[14] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[15] <= 1'b0; end else begin s_div_clk[15] <= ~s_div_clk[15]; end end always @(posedge s_div_clk[15] or negedge sys_rst)begin if(!sys_rst)begin s_div_clk[16] <= 1'b0; end else begin s_div_clk[16] <= ~s_div_clk[16]; end end endmodule 但我仿真图下面情况, ![]() 1.但我的仿真图里面的div_clk 信号没有出来,我在程序中用s_div_clk寄存器,存储地址线上的不同频率,让后把这个寄存器的值,赋值给输出端口div_clk,但仿真中div_clk信号没有出来,理论上div_clk上输出的就是整个二分频信号,现在我的地址线上都没有信号,有点搞不通。 2。还有lways @(posedge sys_clk or negedge sys_rst ) begin //50mhz晶振,LED2检测 if(!sys_rst)begin count2 <= 32'h0000_0000; end else begin if(count2 ==32'd20000_000)begin led[2]<= ~led[2]; count2 <= 32'h0000_0000; end 这个语句内,我加入复位信号后,LED2出现常亮,不闪烁。去除复位信号后,LED2 闪烁,不知道什么情况。 这个小程序,希望会FPGA的大神,能够指点一下,再次感激了,小弟不很会FPGA,在自学中有些语法规则不是很懂,希望大神能看看我的程序,谢谢
3个回答
为什么都没有人回答了
这样的程序,在实际应用来说等于是废的啊,看都不想看,
分频出来产生的这个data:s_div_clk直接作为时钟去作驱动,始终是不稳定,建议不要这样做,如果确实要的话,最好加个buf。至于led,没有仔细去看。 |
我这个只要产生一个这样一个信号,能把信号送出去就行,还加个缓存,哪有你想的这个复杂,基本没看有用的信息。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
求FPGA 驱动控制ltc2271 或者 ltc2180 或者 ltc2190或者 ltc2202 的代码
1264 浏览 0 评论
405 浏览 0 评论
求助:遇见诡异问题,FPGA模块A输出端口连接模块B输入后,模块A不能正常工作的
1418 浏览 1 评论
461 浏览 0 评论
1373 浏览 1 评论
4259 浏览 94 评论
GMT+8, 2024-8-15 16:21 , Processed in 0.609769 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
