扫一扫,分享给好友
手上有两个nrf,可以发送数据就是不能接收,大家说说是什么问题啊?如果有完整的收发程序,麻烦发上来!谢谢大家!请大家帮帮忙 |
2个回答
发送函数:
#include #include ***it MISO =P1^5; ***it MOSI =P1^4; ***it SCK =P1^3; ***it CE =P1^1; ***it CSN =P1^2; ***it IRQ =P1^6; ***it LED2 =P0^5; ***it LED1 =P0^4; ***it LED3 =P0^6; ***it KEY1 =P3^0; ***it KEY2 =P3^1; #define TX_ADR_WIDTH 5 // 5 bytes TX address width #define RX_ADR_WIDTH 5 // 5 bytes RX address width #define TX_PLOAD_WIDTH 20 // 20 bytes TX payload #define RX_PLOAD_WIDTH 20 // 20 bytes TX payload typedef unsigned char BYTE; typedef unsigned char uchar; //****************************************************************// // SPI(nRF24L01) commands #define READ_REG 0x00 // Define read command to register #define WRITE_REG 0x20 // Define write command to register #define RD_RX_PLOAD 0x61 // Define RX payload register address #define WR_TX_PLOAD 0xA0 // Define TX payload register address #define FLUSH_TX 0xE1 // Define flush TX register command #define FLUSH_RX 0xE2 // Define flush RX register command #define REUSE_TX_PL 0xE3 // Define reuse TX payload register command #define NOP 0xFF // Define No Operation, might be used to read status register //***************************************************// // SPI(nRF24L01) registers(addresses) #define CONFIG 0x00 // 'Config' register address #define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address #define EN_RXADDR 0x02 // 'Enabled RX addresses' register address #define SETUP_AW 0x03 // 'Setup address width' register address #define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address #define RF_CH 0x05 // 'RF channel' register address #define RF_SETUP 0x06 // 'RF setup' register address #define STATUS 0x07 // 'Status' register address #define OBSERVE_TX 0x08 // 'Observe TX' register address #define CD 0x09 // 'Carrier Detect' register address #define RX_ADDR_P0 0x0A // 'RX address pipe0' register address #define RX_ADDR_P1 0x0B // 'RX address pipe1' register address #define RX_ADDR_P2 0x0C // 'RX address pipe2' register address #define RX_ADDR_P3 0x0D // 'RX address pipe3' register address #define RX_ADDR_P4 0x0E // 'RX address pipe4' register address #define RX_ADDR_P5 0x0F // 'RX address pipe5' register address #define TX_ADDR 0x10 // 'TX address' register address #define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address #define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address #define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address #define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address #define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address #define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address #define FIFO_STATUS 0x17 // 'FIFO Status Register' register address //***************************************************************// // FUNCTION's PROTOTYPES // /****************************************************************/ // void SPI_Init(BYTE Mode); // Init HW or SW SPI BYTE SPI_RW(BYTE byte); // Single SPI read/write BYTE SPI_Read(BYTE reg); // Read one byte from nRF24L01 BYTE SPI_RW_Reg(BYTE reg, BYTE byte); // Write one byte to register 'reg' BYTE SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Writes multiply bytes to one register BYTE SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Read multiply bytes from one register //*****************************************************************/ void inerDelay_us(unsigned char n); void init_io(void) ; void SetRX_Mode(void); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); extern uchar const TX_ADDRESS[TX_ADR_WIDTH];//TX address extern uchar const RX_ADDRESS[RX_ADR_WIDTH];//;RX address uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static TX address uchar const RX_ADDRESS[RX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static RX address uchar bdata sta; ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } void init_io(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB发送 } /************************************************** Function: SPI_RW(); Description: Writes one byte to nRF24L01, and return the byte read from nRF24L01 during write, according to SPI protocol /**************************************************/ uchar SPI_RW(uchar byte) { uchar bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (byte & 0x80); // output 'byte', MSB to MOSI byte = (byte << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. byte |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(byte); // return read byte } /**************************************************/ /************************************************** Function: SPI_RW_Reg(); Description: Writes value 'value' to register 'reg' /**************************************************/ uchar SPI_RW_Reg(BYTE reg, BYTE value) { uchar status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status byte } /**************************************************/ /************************************************** Function: SPI_Read(); Description: Read one byte from nRF24L01 register, 'reg' /**************************************************/ BYTE SPI_Read(BYTE reg) { BYTE reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /**************************************************/ /************************************************** Function: SPI_Read_Buf(); Description: /**************************************************/ uchar SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes) { uchar status,byte_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status byte for(byte_ctr=0;byte_ctr CSN = 1; return(status); // return nRF24L01 status byte } /**************************************************/ /************************************************** Function: SPI_Write_Buf(); Description: Writes contents of buffer '*pBuf' to nRF24L01 Typically used to write TX payload, Rx/Tx address /**************************************************/ uchar SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes) { uchar status,byte_ctr; CSN = 0; status = SPI_RW(reg); for(byte_ctr=0; byte_ctr CSN = 1; return(status); } /**************************************************/ /************************************************** Function: RX_Mode(); Description: /**************************************************/ void SetRX_Mode(void) { CE=0; SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 CE = 1; inerDelay_us(130); } /**************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) { unsigned char revale=0; sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况 if(RX_DR) // 判断是否接收到数据 { LED3=0; CE = 0; //SPI使能 SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1; //读取数据完成标志 } SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志 return revale; } /************************************************** Function: nRF24L01_TxPacket(); Description: This function initializes one nRF24L01 device to TX mode, set TX address, set RX address for auto.ack, fill TX payload, select RF channel, datarate & TX pwr. PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX. ToDo: One high pulse(>10us) on CE will now send this packet and expext an acknowledgment from the RX device. /**************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 CE=1; //置高CE,激发数据发送 LED1=0; LED2=0; inerDelay_us(10); } void Delay(unsigned int s) { unsigned int i; for(i=0; i void main(void) { unsigned char a; unsigned char leng =0; unsigned char tf =0; unsigned char TxBuf[20]={0}; // unsigned char RxBuf[20]={0}; init_io() ; while(1) { TxBuf[1] = 0x01; TxBuf[2] = 0x02; nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data TxBuf[1] = 0x00; TxBuf[2] = 0x00; Delay(1000); LED1 = 1; LED2 = 1; Delay(100000); } } |
接收函数:
#include #include //hard pin mapping ***it MISO =P1^5; ***it MOSI =P1^4; ***it SCK =P1^3; ***it CE =P1^1; ***it CSN =P1^2; ***it IRQ =P1^6; ***it LED3 =P0^6; ***it LED2 =P0^5; ***it LED1 =P0^4; ***it KEY1 =P3^0; ***it KEY2 =P3^1; #define TX_ADR_WIDTH 5 // 5 bytes TX address width #define RX_ADR_WIDTH 5 // 5 bytes RX address width #define TX_PLOAD_WIDTH 20 // 20 bytes TX payload #define RX_PLOAD_WIDTH 20 // 20 bytes TX payload typedef unsigned char BYTE; typedef unsigned char uchar; //****************************************************************// // SPI(nRF24L01) commands #define READ_REG 0x00 // Define read command to register #define WRITE_REG 0x20 // Define write command to register #define RD_RX_PLOAD 0x61 // Define RX payload register address #define WR_TX_PLOAD 0xA0 // Define TX payload register address #define FLUSH_TX 0xE1 // Define flush TX register command #define FLUSH_RX 0xE2 // Define flush RX register command #define REUSE_TX_PL 0xE3 // Define reuse TX payload register command #define NOP 0xFF // Define No Operation, might be used to read status register //***************************************************// // SPI(nRF24L01) registers(addresses) #define CONFIG 0x00 // 'Config' register address #define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address #define EN_RXADDR 0x02 // 'Enabled RX addresses' register address #define SETUP_AW 0x03 // 'Setup address width' register address #define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address #define RF_CH 0x05 // 'RF channel' register address #define RF_SETUP 0x06 // 'RF setup' register address #define STATUS 0x07 // 'Status' register address #define OBSERVE_TX 0x08 // 'Observe TX' register address #define CD 0x09 // 'Carrier Detect' register address #define RX_ADDR_P0 0x0A // 'RX address pipe0' register address #define RX_ADDR_P1 0x0B // 'RX address pipe1' register address #define RX_ADDR_P2 0x0C // 'RX address pipe2' register address #define RX_ADDR_P3 0x0D // 'RX address pipe3' register address #define RX_ADDR_P4 0x0E // 'RX address pipe4' register address #define RX_ADDR_P5 0x0F // 'RX address pipe5' register address #define TX_ADDR 0x10 // 'TX address' register address #define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address #define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address #define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address #define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address #define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address #define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address #define FIFO_STATUS 0x17 // 'FIFO Status Register' register address //***************************************************************// // FUNCTION's PROTOTYPES // /****************************************************************/ // void SPI_Init(BYTE Mode); // Init HW or SW SPI BYTE SPI_RW(BYTE byte); // Single SPI read/write BYTE SPI_Read(BYTE reg); // Read one byte from nRF24L01 BYTE SPI_RW_Reg(BYTE reg, BYTE byte); // Write one byte to register 'reg' BYTE SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Writes multiply bytes to one register BYTE SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes); // Read multiply bytes from one register //*****************************************************************/ void inerDelay_us(unsigned char n); void init_io(void) ; void SetRX_Mode(void); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); extern uchar const TX_ADDRESS[TX_ADR_WIDTH];//TX address extern uchar const RX_ADDRESS[RX_ADR_WIDTH];//;RX address uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static TX address uchar const RX_ADDRESS[RX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static RX address uchar bdata sta; ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } void init_io(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // Spi clock line init high SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 } /************************************************** Function: SPI_RW(); Description: Writes one byte to nRF24L01, and return the byte read from nRF24L01 during write, according to SPI protocol /**************************************************/ uchar SPI_RW(uchar byte) { uchar bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (byte & 0x80); // output 'byte', MSB to MOSI byte = (byte << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. byte |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(byte); // return read byte } /**************************************************/ /************************************************** Function: SPI_RW_Reg(); Description: Writes value 'value' to register 'reg' /**************************************************/ uchar SPI_RW_Reg(BYTE reg, BYTE value) { uchar status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status byte } /**************************************************/ /************************************************** Function: SPI_Read(); Description: Read one byte from nRF24L01 register, 'reg' /**************************************************/ BYTE SPI_Read(BYTE reg) { BYTE reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /**************************************************/ /************************************************** Function: SPI_Read_Buf(); Description: /**************************************************/ uchar SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes) { uchar status,byte_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status byte for(byte_ctr=0;byte_ctr CSN = 1; return(status); // return nRF24L01 status byte } /**************************************************/ /************************************************** Function: SPI_Write_Buf(); Description: Writes contents of buffer '*pBuf' to nRF24L01 Typically used to write TX payload, Rx/Tx address /**************************************************/ uchar SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes) { uchar status,byte_ctr; CSN = 0; status = SPI_RW(reg); for(byte_ctr=0; byte_ctr CSN = 1; // Set CSN high again return(status); // } /**************************************************/ /************************************************** Function: RX_Mode(); Description: /**************************************************/ void SetRX_Mode(void) { CE=0; inerDelay_us(130); SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 CE = 1; inerDelay_us(130); } /**************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) { unsigned char revale=0; //SetRX_Mode(); sta=SPI_Read(STATUS); // read register STATUS's value LED3=0; if(RX_DR) // if receive data ready (RX_DR) interrupt { CE = 0; SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1;//we have receive data LED1=0; LED2=0; } SPI_RW_Reg(WRITE_REG+STATUS,sta);// clear RX_DR or TX_DS or MAX_RT interrupt flag return revale; } /************************************************** Function: nRF24L01_TxPacket(); Description: This function initializes one nRF24L01 device to TX mode, set TX address, set RX address for auto.ack, fill TX payload, select RF channel, datarate & TX pwr. PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX. ToDo: One high pulse(>10us) on CE will now send this packet and expext an acknowledgment from the RX device. /**************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 CE=1; //置高CE,激发数据发送 inerDelay_us(10); } void Delay(unsigned int s) { unsigned int i; for(i=0; i void initcom () { TMOD=0x20; PCON=0x00; SCON=0x50; TH1=0xFd;//波特率9600 TL1=0xFd; TR1=1; } void comm (int len) { SBUF=len; while(!TI); TI=0; } void main(void) { unsigned char a,b; unsigned char leng =0; unsigned char tf =0; unsigned char TxBuf[20]={0}; // unsigned char RxBuf[20]={0}; init_io() ; initcom (); while(1) { SetRX_Mode(); if(nRF24L01_RxPacket(RxBuf)) { comm(RxBuf[1]); comm(RxBuf[2]); Delay(1000); LED1=1; LED2=1; } RxBuf[1] = 0x00; RxBuf[2] = 0x00; a=SPI_Read(); comm(a); //串口一直显示STATUS是0x0f } } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 16:22 , Processed in 0.681899 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2098
