情况是这样的:我想给PD2(即INT0)引脚一个PWM信号,触发外部中断,然后用T0去算PWM的高电平部分的脉宽,但是出了以下问题:T0不工作,计数器TCNT0不累加,也不进入T0溢出中断;但可以进去外部中断(上升沿和下降沿都可以进去)。用的是外部晶振8Mhz,CKSEL=1111,SUT=00。编程熔丝为0xD9CF。 求大神高手帮帮忙,小弟新手~帮帮忙~ 程序如下: #include #include #include #include #define tiMER0OVERFLOW_INT_ENABLE TIMSK |= 0x01 //T0溢出中断使能 #define TIMER0OVERFLOW_INT_DISABLE TIMSK &= ~0x01 //T0溢出中断禁能 #define TIMER1OVERFLOW_INT_ENABLE TIMSK |= 0x04 //T1溢出中断使能 #define TIMER1OVERFLOW_INT_DISABLE TIMSK &= ~0x04 //T1溢出中断禁能 #define TIMER2OVERFLOW_INT_ENABLE TIMSK |= 0x40 //T2溢出中断使能 #define TIMER2OVERFLOW_INT_DISABLE TIMSK &= ~0x40 //T2溢出中断禁能 #define INT0_INT_ENABLE GICR |= 0x40 //INT0外部中断使能 #define INT0_INT_DISABLE GICR &= ~0x40 //INT0外部中断禁能 #define INT0_FALL_ENABLE MCUCR |= 0x02 //INT0引脚上下降沿引发INT0中断 #define INT0_FALL_DISABLE MCUCR &= ~0x02 #define INT0_RISE_ENABLE MCUCR |= 0x03 //INT0引脚上上升沿引发INT0中断 #define INT0_RISE_DISABLE MCUCR &= ~0x03 #define CLR_INT0_FLAG GIFR &= ~0x40 //INT0电平发生跳变中断标志清0 unsigned char Timer0Overflow; volatile unsigned int PPM_Signal = 0; volatile unsigned char fall_time = 0,rise_time = 0; unsigned int aaa; void Timer0_Init(void) { TCCR0 = 0x01; TIMER0OVERFLOW_INT_ENABLE; //T0溢出中断使能 } void PPM_Init(voi //PPM初始化,INT0设置 { INT0_RISE_ENABLE; INT0_INT_ENABLE; //INT0外部中断使能 CLR_INT0_FLAG; //INT0电平发生跳变中断标志清0 } SIGNAL(SIG_INTERRUPT0) //INT0引脚产生跳变,中断请求 { static unsigned int ppm; static unsigned char count0_value; CLR_INT0_FLAG; if(MCUCR & (1< { INT0_RISE_DISABLE; INT0_FALL_ENABLE; count0_value=TCNT0; rise_time++; } else { INT0_FALL_DISABLE; INT0_RISE_ENABLE; ppm= TCNT0 - count0_value + Timer0Overflow * 256; PPM_Signal=ppm; fall_time++; }} SIGNAL(SIG_OVERFLOW0) //T0溢出中断服务程序 { Timer0Overflow++; //T0溢出中断次数 } int main(void) { cli(); DDRC = 0xFF; PORTC = 0xE0; DDRD = 0xFB; PORTD = 0xFB; DDRB = 0xFF; PORTB = 0xFF; Timer0_Init(); PPM_Init(); sei(); while(1) { if(PPM_Signal < 80) PORTC |=0x01; if(fall_time > 100) PORTC |=0x02; if(rise_time > 100) PORTC |=0x04; } } |
3个回答
允许T0开启了吗?~
GCC的IDE啊,ICC能看懂~~~~~
楼主要做PPM模块吗?
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
stm32f407+ksz8863rlli概率性ping不通
698 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-常见网络服务搭建之NFS服务搭建
374 浏览 0 评论
求助:辉芒微芯片 FDM B11GBMH 的信息及开发环境安装
375 浏览 0 评论
918 浏览 0 评论
嵌入式 学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之输入输出重定向
774 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11306 浏览 31 评论
GMT+8, 2024-9-29 05:09 , Processed in 0.747694 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
