扫一扫,分享给好友
补充一下,这是我的原理图(附件)和程序,PROTUES仿真完全按这个做的仿真成功了。
#include //#include"DS18B20_3.H" #include #include #define uint unsigned int #define uchar unsigned char #define wd 1 #define yh 0x80 #define er 0x80+0x40 0x40) ***it en=P2^7; ***it rw=P2^6; ***it rs=P2^5; ***it set=P3^0; //设置键 ***it add=P3^1; //加键 ***it dec=P3^2; //减键 //***it seeNL_NZ=P3^3; //查看农历/闹钟 ***it DQ=P3^7; // ***it buzzer=P2^0; //蜂鸣器,通过三极管8550驱动,端口低电平响 ***it led=P2^4; //LCD背光开关 bit led1=1; unsigned char temp_miao; unsigned char bltime; ***it IO=P1^1; ***it SCLK=P1^0; ***it RST=P1^2; uchar a,miao,shi,fen,ri,yue,nian,week,setn,temp; uint flag; bit c_moon; uchar nz_shi=12,nz_fen=0,nz_miao=0,setNZn; uchar shangyimiao,bsn,temp_hour; uchar T_NL_NZ; bit timerOn=0; bit baoshi=0; bit p_r=0; data uchar year_moon,month_moon,day_moon,week; ***it ACC0=ACC^0; ***it ACC7=ACC^7; /************************************************************ ACC累加器=A ACC.0=E0H ACC.0就是ACC的第0位。Acc可以位寻址。 累加器ACC是一个8位的存储单元,是用来放数据的。但是,这个存储单元有其特殊的地位, 是单片机中一个非常关键的单元,很多运算都要通过ACC来进行。以后在学习指令时, 常用A来表示累加器。但有一些地方例外,比如在PUSH指令中,就必须用ACC这样的名字。 一般的说法,A代表了累加器中的内容、而ACC代表的是累加器的地址。 ***************************************************************/ //********阳历转换阴历表************************************ code uchar year_code[597]={ 0x04,0xAe,0x53, //1901 0 0x0A,0x57,0x48, //1902 3 0x55,0x26,0xBd, //1903 6 0x0d,0x26,0x50, //1904 9 0x0d,0x95,0x44, //1905 12 0x46,0xAA,0xB9, //1906 15 0x05,0x6A,0x4d, //1907 18 0x09,0xAd,0x42, //1908 21 0x24,0xAe,0xB6, //1909 0x04,0xAe,0x4A, //1910 0x6A,0x4d,0xBe, //1911 0x0A,0x4d,0x52, //1912 0x0d,0x25,0x46, //1913 0x5d,0x52,0xBA, //1914 0x0B,0x54,0x4e, //1915 0x0d,0x6A,0x43, //1916 0x29,0x6d,0x37, //1917 0x09,0x5B,0x4B, //1918 0x74,0x9B,0xC1, //1919 0x04,0x97,0x54, //1920 0x0A,0x4B,0x48, //1921 0x5B,0x25,0xBC, //1922 0x06,0xA5,0x50, //1923 0x06,0xd4,0x45, //1924 0x4A,0xdA,0xB8, //1925 0x02,0xB6,0x4d, //1926 0x09,0x57,0x42, //1927 0x24,0x97,0xB7, //1928 0x04,0x97,0x4A, //1929 0x66,0x4B,0x3e, //1930 0x0d,0x4A,0x51, //1931 0x0e,0xA5,0x46, //1932 0x56,0xd4,0xBA, //1933 0x05,0xAd,0x4e, //1934 0x02,0xB6,0x44, //1935 0x39,0x37,0x38, //1936 0x09,0x2e,0x4B, //1937 0x7C,0x96,0xBf, //1938 0x0C,0x95,0x53, //1939 0x0d,0x4A,0x48, //1940 0x6d,0xA5,0x3B, //1941 0x0B,0x55,0x4f, //1942 0x05,0x6A,0x45, //1943 0x4A,0xAd,0xB9, //1944 0x02,0x5d,0x4d, //1945 0x09,0x2d,0x42, //1946 0x2C,0x95,0xB6, //1947 0x0A,0x95,0x4A, //1948 0x7B,0x4A,0xBd, //1949 0x06,0xCA,0x51, //1950 0x0B,0x55,0x46, //1951 0x55,0x5A,0xBB, //1952 0x04,0xdA,0x4e, //1953 0x0A,0x5B,0x43, //1954 0x35,0x2B,0xB8, //1955 0x05,0x2B,0x4C, //1956 0x8A,0x95,0x3f, //1957 0x0e,0x95,0x52, //1958 0x06,0xAA,0x48, //1959 0x7A,0xd5,0x3C, //1960 0x0A,0xB5,0x4f, //1961 0x04,0xB6,0x45, //1962 0x4A,0x57,0x39, //1963 0x0A,0x57,0x4d, //1964 0x05,0x26,0x42, //1965 0x3e,0x93,0x35, //1966 0x0d,0x95,0x49, //1967 0x75,0xAA,0xBe, //1968 0x05,0x6A,0x51, //1969 0x09,0x6d,0x46, //1970 0x54,0xAe,0xBB, //1971 0x04,0xAd,0x4f, //1972 0x0A,0x4d,0x43, //1973 0x4d,0x26,0xB7, //1974 0x0d,0x25,0x4B, //1975 0x8d,0x52,0xBf, //1976 0x0B,0x54,0x52, //1977 0x0B,0x6A,0x47, //1978 0x69,0x6d,0x3C, //1979 0x09,0x5B,0x50, //1980 0x04,0x9B,0x45, //1981 0x4A,0x4B,0xB9, //1982 0x0A,0x4B,0x4d, //1983 0xAB,0x25,0xC2, //1984 0x06,0xA5,0x54, //1985 0x06,0xd4,0x49, //1986 0x6A,0xdA,0x3d, //1987 0x0A,0xB6,0x51, //1988 0x09,0x37,0x46, //1989 0x54,0x97,0xBB, //1990 0x04,0x97,0x4f, //1991 0x06,0x4B,0x44, //1992 0x36,0xA5,0x37, //1993 0x0e,0xA5,0x4A, //1994 0x86,0xB2,0xBf, //1995 0x05,0xAC,0x53, //1996 0x0A,0xB6,0x47, //1997 0x59,0x36,0xBC, //1998 0x09,0x2e,0x50, //1999 294 0x0C,0x96,0x45, //2000 297 0x4d,0x4A,0xB8, //2001 0x0d,0x4A,0x4C, //2002 0x0d,0xA5,0x41, //2003 0x25,0xAA,0xB6, //2004 0x05,0x6A,0x49, //2005 0x7A,0xAd,0xBd, //2006 0x02,0x5d,0x52, //2007 0x09,0x2d,0x47, //2008 0x5C,0x95,0xBA, //2009 0x0A,0x95,0x4e, //2010 0x0B,0x4A,0x43, //2011 0x4B,0x55,0x37, //2012 0x0A,0xd5,0x4A, //2013 0x95,0x5A,0xBf, //2014 0x04,0xBA,0x53, //2015 0x0A,0x5B,0x48, //2016 0x65,0x2B,0xBC, //2017 0x05,0x2B,0x50, //2018 0x0A,0x93,0x45, //2019 0x47,0x4A,0xB9, //2020 0x06,0xAA,0x4C, //2021 0x0A,0xd5,0x41, //2022 0x24,0xdA,0xB6, //2023 0x04,0xB6,0x4A, //2024 0x69,0x57,0x3d, //2025 0x0A,0x4e,0x51, //2026 0x0d,0x26,0x46, //2027 0x5e,0x93,0x3A, //2028 0x0d,0x53,0x4d, //2029 0x05,0xAA,0x43, //2030 0x36,0xB5,0x37, //2031 0x09,0x6d,0x4B, //2032 0xB4,0xAe,0xBf, //2033 0x04,0xAd,0x53, //2034 0x0A,0x4d,0x48, //2035 0x6d,0x25,0xBC, //2036 0x0d,0x25,0x4f, //2037 0x0d,0x52,0x44, //2038 0x5d,0xAA,0x38, //2039 0x0B,0x5A,0x4C, //2040 0x05,0x6d,0x41, //2041 0x24,0xAd,0xB6, //2042 0x04,0x9B,0x4A, //2043 0x7A,0x4B,0xBe, //2044 0x0A,0x4B,0x51, //2045 0x0A,0xA5,0x46, //2046 0x5B,0x52,0xBA, //2047 0x06,0xd2,0x4e, //2048 0x0A,0xdA,0x42, //2049 0x35,0x5B,0x37, //2050 0x09,0x37,0x4B, //2051 0x84,0x97,0xC1, //2052 0x04,0x97,0x53, //2053 0x06,0x4B,0x48, //2054 0x66,0xA5,0x3C, //2055 0x0e,0xA5,0x4f, //2056 0x06,0xB2,0x44, //2057 0x4A,0xB6,0x38, //2058 0x0A,0xAe,0x4C, //2059 0x09,0x2e,0x42, //2060 0x3C,0x97,0x35, //2061 0x0C,0x96,0x49, //2062 0x7d,0x4A,0xBd, //2063 0x0d,0x4A,0x51, //2064 0x0d,0xA5,0x45, //2065 0x55,0xAA,0xBA, //2066 0x05,0x6A,0x4e, //2067 0x0A,0x6d,0x43, //2068 0x45,0x2e,0xB7, //2069 0x05,0x2d,0x4B, //2070 0x8A,0x95,0xBf, //2071 0x0A,0x95,0x53, //2072 0x0B,0x4A,0x47, //2073 0x6B,0x55,0x3B, //2074 0x0A,0xd5,0x4f, //2075 0x05,0x5A,0x45, //2076 0x4A,0x5d,0x38, //2077 0x0A,0x5B,0x4C, //2078 0x05,0x2B,0x42, //2079 0x3A,0x93,0xB6, //2080 0x06,0x93,0x49, //2081 0x77,0x29,0xBd, //2082 0x06,0xAA,0x51, //2083 0x0A,0xd5,0x46, //2084 0x54,0xdA,0xBA, //2085 0x04,0xB6,0x4e, //2086 0x0A,0x57,0x43, //2087 0x45,0x27,0x38, //2088 0x0d,0x26,0x4A, //2089 0x8e,0x93,0x3e, //2090 0x0d,0x52,0x52, //2091 0x0d,0xAA,0x47, //2092 0x66,0xB5,0x3B, //2093 0x05,0x6d,0x4f, //2094 0x04,0xAe,0x45, //2095 0x4A,0x4e,0xB9, //2096 0x0A,0x4d,0x4C, //2097 0x0d,0x15,0x41, //2098 0x2d,0x92,0xB5, //2099 }; ///月份数据表 code uchar day_code1[9]={0x0,0x1f,0x3b,0x5a,0x78,0x97,0xb5,0xd4,0xf3}; code uint day_code2[3]={0x111,0x130,0x14e}; /* 函数功能:输入BCD阳历数据,输出BCD阴历数据(只允许1901-2099年) 调用函数示例:Conversion(c_sun,year_sun,month_sun,day_sun) 如:计算2004年10月16日Conversion(0,0x4,0x10,0x16); c_sun,year_sun,month_sun,day_sun均为BCD数据,c_sun为世纪标志位,c_sun=0为21世 纪,c_sun=1为19世纪 调用函数后,原有数据不变,读c_moon,year_moon,month_moon,day_moon得出阴历BCD数据 */ bit c_moon; data uchar year_moon,month_moon,day_moon,week; //子函数,用于读取数据表中农历月的大月或小月,如果该月为大返回1,为小返回0 bit get_moon_day(uchar month_p,uint table_addr) { uchar temp; switch (month_p){ case 1:{temp=year_code[table_addr]&0x08; if (temp==0)return(0);else return(1);} case 2:{temp=year_code[table_addr]&0x04; if (temp==0)return(0);else return(1);} case 3:{temp=year_code[table_addr]&0x02; if (temp==0)return(0);else return(1);} case 4:{temp=year_code[table_addr]&0x01; if (temp==0)return(0);else return(1);} case 5:{temp=year_code[table_addr+1]&0x80; if (temp==0) return(0);else return(1);} case 6:{temp=year_code[table_addr+1]&0x40; if (temp==0)return(0);else return(1);} case 7:{temp=year_code[table_addr+1]&0x20; if (temp==0)return(0);else return(1);} case 8:{temp=year_code[table_addr+1]&0x10; if (temp==0)return(0);else return(1);} case 9:{temp=year_code[table_addr+1]&0x08; if (temp==0)return(0);else return(1);} case 10:{temp=year_code[table_addr+1]&0x04; if (temp==0)return(0);else return(1);} case 11:{temp=year_code[table_addr+1]&0x02; if (temp==0)return(0);else return(1);} case 12:{temp=year_code[table_addr+1]&0x01; if (temp==0)return(0);else return(1);} case 13:{temp=year_code[table_addr+2]&0x80; if (temp==0)return(0);else return(1);} } } /* 函数功能:输入BCD阳历数据,输出BCD阴历数据(只允许1901-2099年) 调用函数示例:Conversion(c_sun,year_sun,month_sun,day_sun) 如:计算2004年10月16日Conversion(0,0x4,0x10,0x16); c_sun,year_sun,month_sun,day_sun均为BCD数据,c_sun为世纪标志位,c_sun=0为21世 纪,c_sun=1为19世纪 调用函数后,原有数据不变,读c_moon,year_moon,month_moon,day_moon得出阴历BCD数据 */ void Conversion(bit c,uchar year,uchar month,uchar day) { //c=0 为21世纪,c=1 为19世纪 输入输出数据均为BCD数据 uchar temp1,temp2,temp3,month_p; uint temp4,table_addr; bit flag2,flag_y; temp1=year/16; //BCD->hex 先把数据转换为十六进制 temp2=year%16; // year=temp1*10+temp2; year=temp1*16+temp2; temp1=month/16; temp2=month%16; //month=temp1*10+temp2; month=temp1*16+temp2; temp1=day/16; temp2=day%16; //day=temp1*10+temp2; day=temp1*16+temp2; //定位数据表地址 if(c==0){ table_addr=(year+0x64-1)*0x3; } else { table_addr=(year-1)*0x3; } //定位数据表地址完成 //取当年春节所在的公历月份 temp1=year_code[table_addr+2]&0x60; temp1=_cror_(temp1,5); //取当年春节所在的公历月份完成 //取当年春节所在的公历日 temp2=year_code[table_addr+2]&0x1f; //取当年春节所在的公历日完成 // 计算当年春年离当年元旦的天数,春节只会在公历1月或2月 if(temp1==0x1){ temp3=temp2-1; } else{ temp3=temp2+0x1f-1; } // 计算当年春年离当年元旦的天数完成 //计算公历日离当年元旦的天数,为了减少运算,用了两个表 //day_code1[9],day_code2[3] //如果公历月在九月或前,天数会少于0xff,用表day_code1[9], //在九月后,天数大于0xff,用表day_code2[3] //如输入公历日为8月10日,则公历日离元旦天数为day_code1[8-1]+10-1 //如输入公历日为11月10日,则公历日离元旦天数为day_code2[11-10]+10-1 if (month<10){ temp4=day_code1[month-1]+day-1; } else{ temp4=day_code2[month-10]+day-1; } if ((month>0x2)&&(year%0x4==0)){ //如果公历月大于2月并且该年的2月为闰月,天数加1 temp4+=1; } //计算公历日离当年元旦的天数完成 //判断公历日在春节前还是春节后 if (temp4>=temp3){ //公历日在春节后或就是春节当日使用下面代码进行运算 temp4-=temp3; month=0x1; month_p=0x1; //month_p为月份指向,公历日在春节前或就是春节当日month_p指向首月 flag2=get_moon_day(month_p,table_addr); //检查该农历月为大小还是小月,大月返回1,小月返回0 flag_y=0; if(flag2==0)temp1=0x1d; //小月29天 else temp1=0x1e; //大小30天 temp2=year_code[table_addr]&0xf0; temp2=_cror_(temp2,4); //从数据表中取该年的闰月月份,如为0则该年无闰月 while(temp4>=temp1){ temp4-=temp1; month_p+=1; if(month==temp2){ flag_y=~flag_y; if(flag_y==0)month+=1; } else month+=1; flag2=get_moon_day(month_p,table_addr); if(flag2==0)temp1=0x1d; else temp1=0x1e; } day=temp4+1; } else{ //公历日在春节前使用下面代码进行运算 temp3-=temp4; if (year==0x0){year=0x63;c=1;} else year-=1; table_addr-=0x3; month=0xc; temp2=year_code[table_addr]&0xf0; temp2=_cror_(temp2,4); if (temp2==0) month_p=0xc; else month_p=0xd; // //month_p为月份指向,如果当年有闰月,一年有十三个月,月指向13,无闰月指向12 flag_y=0; flag2=get_moon_day(month_p,table_addr); if(flag2==0)temp1=0x1d; else temp1=0x1e; while(temp3>temp1){ temp3-=temp1; month_p-=1; if(flag_y==0)month-=1; if(month==temp2)flag_y=~flag_y; flag2=get_moon_day(month_p,table_addr); if(flag2==0)temp1=0x1d; else temp1=0x1e; } day=temp1-temp3+1; } c_moon=c; //HEX->BCD ,运算结束后,把数据转换为BCD数据 temp1=year/10; temp1=_crol_(temp1,4); temp2=year%10; year_moon=temp1|temp2; temp1=month/10; temp1=_crol_(temp1,4); temp2=month%10; month_moon=temp1|temp2; temp1=day/10; temp1=_crol_(temp1,4); temp2=day%10; day_moon=temp1|temp2; } /* 函数功能:输入BCD阳历数据,输出BCD星期数据(只允许1901-2099年) 调用函数示例:Conver_week(c_sun,year_sun,month_sun,day_sun) 如:计算2004年10月16日Conversion(0,0x4,0x10,0x16); c_sun,year_sun,month_sun,day_sun均为BCD数据,c_sun为世纪标志位,c_sun=0为21世 纪,c_sun=1为19世纪 调用函数后,原有数据不变,读week得出阴历BCD数据 */ code uchar table_week[12]={0,3,3,6,1,4,6,2,5,0,3,5}; //月修正数据表 /* 算法:日期+年份+所过闰年数+月较正数之和除7 的余数就是星期但如果是在 闰年又不到3 月份上述之和要减一天再除7 星期数为0 */ void Conver_week(uchar year,uchar month,uchar day) {//c=0 为21世纪,c=1 为19世纪 输入输出数据均为BCD数据 uchar p1,p2; year+=0x64; //如果为21世纪,年份数加100 p1=year/0x4; //所过闰年数只算1900年之后的 p2=year+p1; p2=p2%0x7; //为节省资源,先进行一次取余,避免数大于0xff,避免使用整型数据 p2=p2+day+table_week[month-1]; if (year%0x4==0&&month<3)p2-=1; week=p2%0x7; } /**************************************************************/ uchar code tab1[]={"20 - - "}; //年显示的固定字符 uchar code tab2[]={" : : "}; //时间显示的固定字符 uchar code nlp[]={"NL: - - PING"}; //农历平年显示 uchar code nlr[]={"NL: - - RUN "}; //农历润年显示 uchar code NZd[]={"timer: - - "}; //显示闹钟固定点 uchar code qk[]= {" "}; //清空显示 uchar code tm[]= {"time"}; //=====================DS18B20============================================= //****************************************************************************** void Delayns(int num)//延时函数 { while(num--); } //****************************************************************************** void Init_DS18B20(void)//初始化ds1820 { unsigned char x=0; DQ = 1; //DQ复位 Delayns(8); //稍做延时 DQ = 0; //单片机将DQ拉低 Delayns(80); //精确延时 大于 480us DQ = 1; //拉高总线 Delayns(14); x=DQ; //稍做延时后 如果x=0则初始化成功 x=1则初始化失败 Delayns(20); } //****************************************************************************** unsigned char ReadOneChar(void)//读一个字节 { unsigned char i=0; unsigned char dat = 0; for (i=8;i>0;i--) { DQ = 0; // 给脉冲信号 dat>>=1; DQ = 1; // 给脉冲信号 if(DQ) dat|=0x80; Delayns(4); } return(dat); } //****************************************************************************** void WriteOneChar(unsigned char dat)//写一个字节 { unsigned char i=0; for (i=8; i>0; i--) { DQ = 0; DQ = dat&0x01; Delayns(5); DQ = 1; dat>>=1; } } //****************************************************************************** unsigned int ReadTemperature(void)//读取温度 { unsigned char a=0; unsigned char b=0; unsigned int t=0; float tt=0; Init_DS18B20(); WriteOneChar(0xCC); // 跳过读序号列号的操作 WriteOneChar(0x44); // 启动温度转换 Init_DS18B20(); WriteOneChar(0xCC); //跳过读序号列号的操作 WriteOneChar(0xBE); //读取温度寄存器 a=ReadOneChar(); //读低8位 b=ReadOneChar(); //读高8位 t=b; t<<=8; t=t|a; tt=t*0.0625; t= tt*10+0.5; //放大10倍输出并四舍五入 return(t); } //***************************************************************************** //延时函数,后面经常调用 void delay(uint xms)//延时函数,有参函数 { uint x,y; for(x=xms;x>0;x--) for(y=110;y>0;y--); } /********液晶写入指令函数与写入数据函数,以后可调用**************/ /*在这个程序中,液晶写入有关函数会在DS1302的函数中调用,所以液晶程序要放在前面*/ write_1602com(uchar com)//****液晶写入指令函数**** { rs=0;//数据/指令选择置为指令 rw=0; //读写选择置为写 P0=com;//送入数据 delay(1); en=1;//拉高使能端,为制造有效的下降沿做准备 delay(1); en=0;//en由高变低,产生下降沿,液晶执行命令 } write_1602dat(uchar dat)//***液晶写入数据函数**** { rs=1;//数据/指令选择置为数据 rw=0; //读写选择置为写 P0=dat;//送入数据 delay(1); en=1; //en置高电平,为制造下降沿做准备 delay(1); en=0; //en由高变低,产生下降沿,液晶执行命令 } lcd_init()//***液晶初始化函数**** { write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据 write_1602com(0x0c);//开显示不显示光标 write_1602com(0x06);//整屏不移动,光标自动右移 write_1602com(0x01);//清显示 write_1602com(yh+1);//日历显示固定符号从第一行第1个位置之后开始显示 for(a=0;a<14;a++) { write_1602dat(tab1[a]);//向液晶屏写日历显示的固定符号部分 //delay(3); } write_1602com(er);//时间显示固定符号写入位置,从第2个位置后开始显示 for(a=0;a<8;a++) { write_1602dat(tab2[a]);//写显示时间固定符号,两个冒号 //delay(3); } } /*********************over***********************/ /***************DS1302有关子函数********************/ void write_byte(uchar dat)//写一个字节 { ACC=dat; RST=1; for(a=8;a>0;a--) { IO=ACC0; SCLK=0; SCLK=1; ACC=ACC>>1; } } uchar read_byte()//读一个字节 { RST=1; for(a=8;a>0;a--) { ACC7=IO; SCLK=1; SCLK=0; ACC=ACC>>1; } return (ACC); } //---------------------------------------- void write_1302(uchar add,uchar dat)//向1302芯片写函数,指定写入地址,数据 { RST=0; SCLK=0; RST=1; write_byte(add); write_byte(dat); SCLK=1; RST=0; } uchar read_1302(uchar add)//从1302读数据函数,指定读取数据来源地址 { uchar temp; RST=0; SCLK=0; RST=1; write_byte(add); temp=read_byte(); SCLK=1; RST=0; return(temp); } uchar BCD_Decimal(uchar bcd)//BCD码转十进制函数,输入BCD,返回十进制 { uchar Decimal; Decimal=bcd>>4; return(Decimal=Decimal*10+(bcd&=0x0F)); } //-------------------------------------- void ds1302_init() //1302芯片初始化子函数(2010-01-07,12:00:00,week4) { RST=0; SCLK=0; write_1302(0x8e,0x00); //允许写,禁止写保护 //write_1302(0x80,0x00); //向DS1302内写秒寄存器80H写入初始秒数据00 //write_1302(0x82,0x00);//向DS1302内写分寄存器82H写入初始分数据00 //write_1302(0x84,0x12);//向DS1302内写小时寄存器84H写入初始小时数据12 //write_1302(0x8a,0x04);//向DS1302内写周寄存器8aH写入初始周数据4 //write_1302(0x86,0x07);//向DS1302内写日期寄存器86H写入初始日期数据07 //write_1302(0x88,0x01);//向DS1302内写月份寄存器88H写入初始月份数据01 //write_1302(0x8c,0x10);//向DS1302内写年份寄存器8cH写入初始年份数据10 write_1302(0x8e,0x80); //打开写保护 } //------------------------------------ //温度显示子函数 void write_temp(uchar add,uint dat)//向LCD写温度数据,并指定显示位置 { uint gw,sw,bw; bw=dat/100;//取得百位 sw=dat%100/10;//取得十位数字 gw=dat%10;//取得个位数字 write_1602com(er+add);//er是头文件规定的值0x80+0x40 write_1602dat(0x30+bw); write_1602dat(0x30+sw);//数字+30得到该数字的LCD1602显示码 write_1602dat('.'); write_1602dat(0x30+gw);//数字+30得到该数字的LCD1602显示码 write_1602dat(0xdf);//显示温度的小圆圈符号,0xdf是液晶屏字符库的该符号地址码 write_1602dat(0x43); //显示"C"符号,0x43是液晶屏字符库里大写C的地址码 } //------------------------------------ //时分秒显示子函数 void write_sfm(uchar add,uchar dat)//向LCD写时分秒,有显示位置加、现示数据,两个参数 { uchar gw,sw; gw=dat%10;//取得个位数字 sw=dat/10;//取得十位数字 write_1602com(er+add);//er是头文件规定的值0x80+0x40 write_1602dat(0x30+sw);//数字+30得到该数字的LCD1602显示码 write_1602dat(0x30+gw);//数字+30得到该数字的LCD1602显示码 } //------------------------------------- //年月日显示子函数 void write_nyr(uchar add,uchar dat)//向LCD写年月日,有显示位置加数、显示数据,两个参数 { uchar gw,sw; gw=dat%10;//取得个位数字 sw=dat/10;//取得十位数字 write_1602com(yh+add);//设定显示位置为第一个位置+add write_1602dat(0x30+sw);//数字+30得到该数字的LCD1602显示码 write_1602dat(0x30+gw);//数字+30得到该数字的LCD1602显示码 } //------------------------------------ //农历显示子函数 void write_nl(uchar add,uchar dat)//向LCD写时分秒,有显示位置加、现示数据,两个参数 { uchar gw,sw; //gw=dat%10;//取得个位数字 //sw=dat/10;//取得十位数字 gw=dat%16;//取得个位数字 sw=dat/16;//取得十位数字 write_1602com(er+add);//er是头文件规定的值0x80+0x40 // write_1602dat(0x30+sw);//数字+30得到该数字的LCD1602显示码 // write_1602dat(0x30+gw);//数字+30得到该数字的LCD1602显示码 write_1602dat('0'+sw);//数字+30得到该数字的LCD1602显示码 write_1602dat('0'+gw);//数字+30得到该数字的LCD1602显示码 } //------------------------------------------- void write_week(uchar week)//写星期函数 { write_1602com(yh+0x0c);//星期字符的显示位置 switch(week) { case 1:write_1602dat('M');//星期数为1时,显示 write_1602dat('O'); write_1602dat('N'); break; case 2:write_1602dat('T');//星期数据为2时显示 write_1602dat('U'); write_1602dat('E'); break; case 3:write_1602dat('W');//星期数据为3时显示 write_1602dat('E'); write_1602dat('D'); break; case 4:write_1602dat('T');//星期数据为4是显示 write_1602dat('H'); write_1602dat('U'); break; case 5:write_1602dat('F');//星期数据为5时显示 write_1602dat('R'); write_1602dat('I'); break; case 6:write_1602dat('S');//星期数据为6时显示 write_1602dat('T'); write_1602dat('A'); break; case 0:write_1602dat('S');//星期数据为7时显示 write_1602dat('U'); write_1602dat('N'); break; } } //****************键盘扫描有关函数********************** void keyscan() { if(seeNL_NZ==0) { delay(9); if(seeNL_NZ==0) { led1=0; bltime=0; if((setn==0)&&(setNZn==0)) //在没有进入调时模式时才可按动 { buzzer=0;//蜂鸣器短响一次 delay(20); buzzer=1; if(TR1==1) { TR1=0; } else { T_NL_NZ++; if(T_NL_NZ==3) { setn=0; setNZn=0; T_NL_NZ=0; } } } while(seeNL_NZ==0); } } if(set==0)//---------------set为功能键(设置键)-------------------- { delay(9);//延时,用于消抖动 if(set==0)//延时后再次确认按键按下 { led1=0; bltime=0; buzzer=0;//蜂鸣器短响一次 delay(20); buzzer=1; while(!set); if(T_NL_NZ==0x02) //证明是对闹钟进行设置 { setNZn++; if(setNZn==4) //闹钟设定成功,退回到正常显示并开启闹钟 { setNZn=0; setn=0; timerOn=1; } switch(setNZn) { case 0: //正常显示日期时间 write_1602com(0x0c); //柚霉獗瓴簧了? write_1602com(er); //时间显示固定符号写入位置? for(a=0;a<16;a++) write_1602dat(NZd[a]); //写显示时间固定符号,两个冒号 write_sfm(8,nz_shi); //闹钟 时 write_sfm(11,nz_fen); //闹钟 分 write_sfm(14,nz_miao); //闹钟 秒 break; case 1: //闹钟秒光标闪烁 write_1602com(er+15); //设置按键按动一次,秒位置显示光标 //er+0x09; write_1602com(0x0f); //设置光标为闪烁 break; case 2: //闹钟分光标闪烁 write_1602com(er+12); //设置按键按动一次,秒位置显示光标 //er+0x09; write_1602com(0x0f); //设置光标为闪烁 break; case 3: //闹钟时光标闪烁 write_1602com(er+9); //设置按键按动一次,秒位置显示光标 //er+0x09; write_1602com(0x0f); //设置光标为闪烁 break; } } else //证明是对时间及日期进行设置 { if(T_NL_NZ==0) { setn++; if(setn==7) setn=0; //设置按键共有秒、分、时、星期、日、月、年、返回,8个功能循环 switch(setn) { case 1: TR0=0;//关闭定时器 //TR1=0; write_1602com(er+7);//设置按键按动一次,秒位置显示光标 //er+0x09; write_1602com(0x0f);//设置光标为闪烁 temp=(miao)/10*16+(miao)%10;//秒数据写入DS1302 write_1302(0x8e,0x00); write_1302(0x80,0x80|temp);//miao write_1302(0x8e,0x80); break; case 2: write_1602com(er+4); //按2次fen位置显示光标 //er+0x06 //write_1602com(0x0f); break; case 3: write_1602com(er+1); //按动3次,shi //write_1602com(0x0f); break; // case 4: write_1602com(yh+0x0e);//按动4次,week //write_1602com(0x0f); // break; case 4: write_1602com(yh+0x0a);//按动4次,ri //write_1602com(0x0f); break; case 5: write_1602com(yh+0x07);//按动5次,yue //write_1602com(0x0f); break; case 6: write_1602com(yh+0x04);//按动6次,nian //write_1602com(0x0f); break; case 0: write_1602com(0x0c);//按动到第7次,设置光标不闪烁 TR0=1;//打开定时器 temp=(miao)/10*16+(miao)%10; write_1302(0x8e,0x00); write_1302(0x80,0x00|temp);//miao数据写入DS1302 write_1302(0x8e,0x80); break; } } } } } //------------------------------加键add---------------------------- if((setn!=0)&&(setNZn==0))//当set按下以下。再按以下键才有效(按键次数不等于零) { if(add==0) //上调键 { delay(10); if(add==0) { led1=0; bltime=0; buzzer=0;//蜂鸣器短响一次 delay(20); buzzer=1; while(!add); switch(setn) { case 1:miao++;//设置键按动1次,调秒 if(miao==60) miao=0;//秒超过59,再加1,就归零 write_sfm(0x06,miao);//令LCD在正确位置显示"加"设定好的秒数 temp=(miao)/10*16+(miao)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00); //允许写,禁止写保护 write_1302(0x80,temp); //向DS1302内写秒寄存器80H写入调整后的秒数据BCD码 write_1302(0x8e,0x80); //打开写保护 write_1602com(er+7);//因为设置液晶的模式是写入数据后,光标自动右移,所以要指定返回 //write_1602com(0x0b); break; case 2:fen++; if(fen==60) fen=0; write_sfm(0x03,fen);//令LCD在正确位置显示"加"设定好的分数据 temp=(fen)/10*16+(fen)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x82,temp);//向DS1302内写分寄存器82H写入调整后的分数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(er+4);//因为设置液晶的模式是写入数据后,指针自动加一,在这里是写回原来的位置 break; case 3:shi++; if(shi==24) shi=0; write_sfm(0x00,shi);//令LCD在正确的位置显示"加"设定好的小时数据 temp=(shi)/10*16+(shi)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x84,temp);//向DS1302内写小时寄存器84H写入调整后的小时数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(er+1);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; /* case 4:week++; if(week==8) week=1; write_1602com(yh+0x0C);//指定'加'后的周数据显示位置 write_week(week);//指定周数据显示内容 temp=(week)/10*16+(week)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x8a,temp);//向DS1302内写周寄存器8aH写入调整后的周数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(yh+0x0e);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; */ case 4:ri++; if(ri==32) ri=1; Conver_week(nian,yue,ri); write_week(week); write_nyr(9,ri);//令LCD在正确的位置显示"加"设定好的日期数据 temp=(ri)/10*16+(ri)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x86,temp);//向DS1302内写日期寄存器86H写入调整后的日期数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(yh+10);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; case 5:yue++; if(yue==13) yue=1; Conver_week(nian,yue,ri); write_week(week); write_nyr(6,yue);//令LCD在正确的位置显示"加"设定好的月份数据 temp=(yue)/10*16+(yue)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x88,temp);//向DS1302内写月份寄存器88H写入调整后的月份数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(yh+7);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; case 6:nian++; if(nian==100) nian=0; Conver_week(nian,yue,ri); write_week(week); write_nyr(3,nian);//令LCD在正确的位置显示"加"设定好的年份数据 temp=(nian)/10*16+(nian)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x8c,temp);//向DS1302内写年份寄存器8cH写入调整后的年份数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(yh+4);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; } } } //------------------减键dec,各句功能参照'加键'注释--------------- if(dec==0) { delay(10);//调延时,消抖动 if(dec==0) { led1=0; bltime=0; buzzer=0;//蜂鸣器短响一次 delay(20); buzzer=1; while(!dec); switch(setn) { case 1: miao--; if(miao==-1) miao=59;//秒数据减到-1时自动变成59 write_sfm(0x06,miao);//在LCD的正确位置显示改变后新的秒数 temp=(miao)/10*16+(miao)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00); //允许写,禁止写保护 write_1302(0x80,temp); //向DS1302内写秒寄存器80H写入调整后的秒数据BCD码 write_1302(0x8e,0x80); //打开写保护 write_1602com(er+7);//因为设置液晶的模式是写入数据后,指针自动加一,在这里是写回原来的位置 //write_1602com(0x0b); break; case 2: fen--; if(fen==-1) fen=59; write_sfm(3,fen); temp=(fen)/10*16+(fen)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x82,temp);//向DS1302内写分寄存器82H写入调整后的分数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(er+4);//因为设置液晶的模式是写入数据后,指针自动加一,在这里是写回原来的位置 break; case 3: shi--; if(shi==-1) shi=23; write_sfm(0,shi); temp=(shi)/10*16+(shi)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x84,temp);//向DS1302内写小时寄存器84H写入调整后的小时数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(er+1);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; /* case 4:week--; if(week==0) week=7; write_1602com(yh+0x0C);//指定'加'后的周数据显示位置 write_week(week);//指定周数据显示内容 temp=(week)/10*16+(week)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x8a,temp);//向DS1302内写周寄存器8aH写入调整后的周数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(yh+0x0e);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; */ case 4: ri--; if(ri==0) ri=31; Conver_week(nian,yue,ri); write_week(week); write_nyr(9,ri); temp=(ri)/10*16+(ri)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x86,temp);//向DS1302内写日期寄存器86H写入调整后的日期数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(yh+10);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; case 5: yue--; if(yue==0) yue=12; Conver_week(nian,yue,ri); write_week(week); write_nyr(6,yue); temp=(yue)/10*16+(yue)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x88,temp);//向DS1302内写月份寄存器88H写入调整后的月份数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(yh+7);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; case 6: nian--; if(nian==-1) nian=99; Conver_week(nian,yue,ri); write_week(week); write_nyr(3,nian); temp=(nian)/10*16+(nian)%10;//十进制转换成DS1302要求的DCB码 write_1302(0x8e,0x00);//允许写,禁止写保护 write_1302(0x8c,temp);//向DS1302内写年份寄存器8cH写入调整后的年份数据BCD码 write_1302(0x8e,0x80);//打开写保护 write_1602com(yh+4);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; } } } } if((setNZn!=0)&&(setn==0)) { if(add==0) //上调键 { delay(10); if(add==0) { led1=0; bltime=0; buzzer=0;//蜂鸣器短响一次 delay(20); buzzer=1; while(!add); switch(setNZn) { case 1: nz_miao++; //设置键按动1次,调秒 if(nz_miao==60) nz_miao=0;//秒超过59,再加1,就归零 write_sfm(14,nz_miao);//令LCD在正确位置显示"加"设定好的秒数 write_1602com(er+15);//因为设置液晶的模式是写入数据后,光标自动右移,所以要指定返回 break; case 2: nz_fen++; if(nz_fen==60) nz_fen=0; write_sfm(11,nz_fen);//令LCD在正确位置显示"加"设定好的分数据 write_1602com(er+12);//因为设置液晶的模式是写入数据后,指针自动加一,在这里是写回原来的位置 break; case 3: nz_shi++; if(nz_shi==24) nz_shi=0; write_sfm(8,nz_shi);//令LCD在正确的位置显示"加"设定好的小时数据 write_1602com(er+9);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; } } } //------------------减键dec,各句功能参照'加键'注释--------------- if(dec==0) { delay(10);//调延时,消抖动 if(dec==0) { led1=0; bltime=0; buzzer=0;//蜂鸣器短响一次 delay(20); buzzer=1; while(!dec); switch(setNZn) { case 1: nz_miao--; if(nz_miao==-1) nz_miao=59;//秒数据减到-1时自动变成59 write_sfm(14,nz_miao);//在LCD的正确位置显示改变后新的秒数 write_1602com(er+15); break; case 2: nz_fen--; if(nz_fen==-1) nz_fen=59; write_sfm(11,nz_fen); write_1602com(er+12);//因为设置液晶的模式是写入数据后,指针自动加一,在这里是写回原来的位置 break; case 3: nz_shi--; if(nz_shi==-1) nz_shi=23; write_sfm(8,nz_shi); write_1602com(er+9);//因为设置液晶的模式是写入数据后,指针自动加一,所以需要光标回位 break; } } } } } //------------------------------- void init(void) //定时器、计数器设置函数 { TMOD=0x11; //指定定时/计数器的工作方式为3 TH0=0; //定时器T0的高四位=0 TL0=0; //定时器T0的低四位=0 TH1=0x3C; TL1=0xB0; EA=1; //系统允许有开放的中断 ET0=1; //允许T0中断 ET1=1; IT1=1; IT0=0; TR0=1; //开启中断,启动定时器 TR1=0; } void alarm(void) { if((shi==nz_shi)&&(fen==nz_fen)&&(miao==0)) { TR1=1; } if((shi==nz_shi)&&(fen==(nz_fen+1))) { TR1=0; buzzer=1; } } void ZD_baoshi(void) { buzzer=0; delay(5); buzzer=1; bsn++; if(bsn==temp_hour) { baoshi=0; } } //*******************主函数************************** //*************************************************** void main() { P1=0xff; lcd_init(); //调用液晶屏初始化子函数 ds1302_init(); //调用DS1302时钟的初始化子函数 init(); //调用定时计数器的设置子函数 led=1; //打开LCD的背光电源 buzzer=0; //蜂鸣器长响一次 delay(80); buzzer=1; while(1) //无限循环下面的语句: { keyscan(); //调用键盘扫描子函数 led=led1; if(timerOn==1) alarm(); //闹钟输出 if((fen==0)&&(miao==0)) { if(shi>12) temp_hour=shi-12; else { if(shi==0) temp_hour=12; else temp_hour=shi; } shangyimiao=miao; baoshi=1; } if(baoshi==1) { ZD_baoshi(); do keyscan(); while(shangyimiao==miao); shangyimiao=miao; } } } void timer0() interrupt 1 //取得并显示日历和时间 { //Init_DS18B20();//温度传感器DS18b2初始化子函数,在头文件中 // flag=ReadTemperature();//将18b2头文件运行返回的函数结果送到变量FLAG中,用于显示 //读取秒时分周日月年七个数据(DS1302的读寄存器与写寄存器不一样): miao = BCD_Decimal(read_1302(0x81)); fen = BCD_Decimal(read_1302(0x83)); shi = BCD_Decimal(read_1302(0x85)); ri = BCD_Decimal(read_1302(0x87)); yue = BCD_Decimal(read_1302(0x89)); nian=BCD_Decimal(read_1302(0x8d)); //week=BCD_Decimal(read_1302(0x8b)); //不读取,直接通过日期计算得到 if((led1==0)) { if(temp_miao!=miao) { temp_miao=miao; bltime++; } if(bltime==10) { led1=1; bltime=0; } } if(T_NL_NZ==1) //显示农历 { uint nian_temp,temp; temp=nian; nian_temp=2000+(temp&0xF0)*10+temp&0x0F; if((nian_temp%400==0)||((nian_temp%100!=0)&&(nian_temp%4==0))) //判断是否为闰年 p_r=1; else p_r=0; Conversion(0,nian,yue,ri); write_1602com(er);//时间显示固定符号写入位置? for(a=0;a<16;a++) { if(p_r==0) write_1602dat(nlp[a]);//写显示时间固定符号,两个冒号 else write_1602dat(nlr[a]); } write_nl(3,year_moon);//农历 年 write_nl(6,month_moon);//农历 月 write_nl(9,day_moon);//农历 日 do keyscan(); while(T_NL_NZ==1); write_1602com(er);//时间显示固定符号写入位置,从第2个位置后开始显示 for(a=0;a<16;a++) { write_1602dat(qk[a]);//写显示时间固定符号,两个冒号 } write_1602com(er);//时间显示固定符号写入位置,从第2个位置后开始显示 for(a=0;a<8;a++) { write_1602dat(tab2[a]);//写显示时间固定符号,两个冒号 } } if(T_NL_NZ==2) //显示闹钟时间, { write_1602com(er);//时间显示固定符号写入位置? for(a=0;a<16;a++) write_1602dat(NZd[a]);//写显示时间固定符号,两个冒号 write_sfm(8,nz_shi);//农历 年 write_sfm(11,nz_fen);//农历 月 write_sfm(14,nz_miao);//农历 日 do keyscan(); while(T_NL_NZ==2); write_1602com(er);//时间显示固定符号写入位置,从第2个位置后开始显示 for(a=0;a<16;a++) { write_1602dat(qk[a]);//写显示时间固定符号,两个冒号 } write_1602com(er);//时间显示固定符号写入位置,从第2个位置后开始显示 for(a=0;a<8;a++) { write_1602dat(tab2[a]);//写显示时间固定符号,两个冒号 } } else { //显示温度、秒、时、分数据: if(wd) { flag=ReadTemperature()-5; write_temp(10,flag);//显示温度,从第二行第12个字符后开始显示 } else { write_1602com(er+12); for(a=0;a<4;a++) { write_1602dat(tm[a]); } } write_sfm(6,miao);//秒,从第二行第8个字后开始显示(调用时分秒显示子函数) write_sfm(3,fen);//分,从第二行第5个字符后开始显示 write_sfm(0,shi);//小时,从第二行第2个字符后开始显示 } //显示日、月、年数据: write_nyr(9,ri);//日期,从第二行第9个字符后开始显示 write_nyr(6,yue);//月份,从第二行第6个字符后开始显示 write_nyr(3,nian);//年,从第二行第3个字符后开始显示 Conver_week(nian,yue,ri); write_week(week); } unsigned char count1; void timer1() interrupt 3 //取得并显示日历和时间 { TH1=0x3C; TL1=0xB0; TR1=1; count1++; if(count1==10) { count1=0; buzzer=!buzzer; }
送数据和写的时候delay时间长点试试,我也遇到过类似的问题,时间加长点就好了,不过还要检查你硬件连接的对不对
硬件连接检查了很多遍应该没有问题了 不好意思,请问具体要改哪些DELAY,加长到多少呢?? 非常感谢,可以加一下你的qq吗?我的是531398001 |
LCD1602上的A和K接错没?
不错的资料,顶一下
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
528 浏览 0 评论
654 浏览 0 评论
858 浏览 0 评论
837 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
770 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17061 浏览 31 评论
/9
GMT+8, 2025-12-14 21:10 , Processed in 1.240161 second(s), Total 83, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7015
