扫一扫,分享给好友
想有PA8产生500K方波,外部告诉晶振25M 为什么没有波形输出 程序如下: int main(void) { SystemInit(); tiM1_PWM_Init(); // while(1) { } } void TIM1_PWM_Init() { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); //使能GPIO外设和AFIO复用功能模块时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); //使能定时器3时钟 GPIO_PinAFConfig(GPIOA,GPIO_PinSource8,GPIO_AF_TIM1); //Timer1部分重映射 TIM1_CH2->PA8 //RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); //设置该引脚为复用输出功能,输出TIM1 CH1的PWM脉冲波形 GPIOA.8 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //TIM1_CH1 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIO //初始化TIM3 TIM_TimeBaseStructure.TIM_Period = 999; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值 TIM_TimeBaseStructure.TIM_Prescaler =50; //设置用来作为TIMx时钟频率除数的预分频值 TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式 TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位 //初始化TIM3 Channel2 PWM模式 TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //选择定时器模式:TIM脉冲宽度调制模式1 TIM_OCInitStructure.TIM_Pulse = 120; TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能 TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高 TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; TIM_OC1Init(TIM1, &TIM_OCInitStructure); //根据T指定的参数初始化外设TIM1 OC1 TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); //使能TIM1在CCR2上的预装载寄存器 TIM_ARRPreloadConfig(TIM1, ENABLE); TIM_ClearFlag(TIM1, TIM_FLAG_Update); TIM_ITConfig(TIM1, TIM_IT_Update, ENABLE); TIM_Cmd(TIM1, ENABLE); //使能TIM3 TIM_CtrlPWMOutputs(TIM1, ENABLE); } |
5个回答
缺少,tim1初始化,有两部分,TIM1_PWM_Init;TIM1_Init,也就是说定时器,没有设置开启,,你只设计了pwm功能。PWM实现是通过定时器来实现的。
你的定时器没有启动 ,你程序缺少了 。
定时器没有启动 。。。。
问大神一个问题 我有个类似的代码 在stm32103系列中可以使用 没有TIME_Init这一说 波形可以实现 输出 到了stm322xx波形不能输出 代码和这个类似 我不知道怎么去设置TIM_Init ,下面是放在一个platform.c中的代码 void OUTGPIO_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; OUTGPIO_CLK_INIT(OUTGPIO_CLK, ENABLE); GPIO_InitStructure.GPIO_Pin = OUTGPIO_PIN; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(OUTGPIO_PORT, &GPIO_InitStructure); } void TIM_Config(uint16_t Channel2Pulse)//, uint16_t Channel3Pulse { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; /* TIM4 clock enable */ TIME4_CLK_INIT(TIME4_CLK, ENABLE); /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = 999; //1KHz TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //TIM2Ô¤·ÖƵÉèÖÃ:1MHZ,APB1·ÖƵϵÊý2£¬ÊäÈëµ½TIM3ʱÖÓΪ36MHzx2 = 72MHz TIM_PrescalerConfig(TIM4,50, TIM_PSCReloadMode_Immediate); /* Channel 2 and 3 Configuration in PWM mode */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; TIM_OCInitStructure.TIM_Pulse = Channel2Pulse; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; TIM_OC2Init(TIM4, &TIM_OCInitStructure); // TIM_OCInitStructure.TIM_Pulse = Channel3Pulse; // TIM_OC3Init(TIM2, &TIM_OCInitStructure); //ʹÄÜTIM2¶¨Ê±¼ÆÊýÆ÷ TIM_Cmd(TIM4, ENABLE); //ʹÄÜTIM2 PWMÊä³öģʽ TIM_CtrlPWMOutputs(TIM4, ENABLE); printf("maoxiann"); } 我在main中直接引用的 硬件部分宏定义了 也声明了 按照你的说法 我是不是也没有开启时钟 谢谢 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1016 浏览 2 评论
763 浏览 0 评论
嵌入式开发 Win11安装ST-Link 提示 设备描述符请求失败 怎么处理?
889 浏览 0 评论
1176 浏览 1 评论
求助:STM32F407串口控制外设无效,用电脑串口助手有效
2054 浏览 3 评论
浏览过的版块 |
GMT+8, 2024-8-4 08:19 , Processed in 0.666799 second(s), Total 83, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
