扫一扫,分享给好友
STM32 printf问题
怎么老是出现idenfier "FILE is Undefined",问题出在哪啊?望指教,谢谢! 我程序代码配置如下: #include "stm32f10x.h" #include "stm32_eval.h" #include #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ int main(void) { SystemInit(); /* Enable GPIOA and USART1 clocks */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1, ENABLE); USART1_GPIO_Configuration(); USART1_Configuration(); printf("The is a example!" ); } /*********************************配置USART1的GPIO口*************************************/ void USART1_GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; // Configure USART1_Tx as alternate function push-pull GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); // Configure USART1_Rx as input floating GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); } /************************************配置串口1参数***********************************/ void USART1_Configuration(void) { USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate =115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No ; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); } PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(USART1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET) {} return ch; } ======================================== 因printf()之类的函数,使用了半主机模式。使用标准库会导致程序无法运行,以下是解决方法: 方法1.使用微库,因为使用微库的话,不会使用半主机模式. 方法2.仍然使用标准库,在主程序添加下面代码: #pragma import(__use_no_semihosting) _sys_exit(int x) { x = x; } struct __FILE { int handle; /* Whatever you require here. If the only file you are using is */ /* standard output using printf() for debugging, no file handling */ /* is required. */ }; /* FILE is typedef’ d in stdio.h. */ FILE __stdout; 这个方法确实解决问题。 首先要加上这句:#include 然后加入以下代码: ///////使用标准printf的串口字节发送重定义/////////// //第一步: #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ //第二步: #pragma import(__use_no_semihosting) _sys_exit(int x) { x = x; } struct __FILE { int handle; /* Whatever you require here. If the only file you are using is */ /* standard output using printf() for debugging, no file handling */ /* is required. */ }; /* FILE is typedef’ d in stdio.h. */ FILE __stdout; //第三步: //默认使用COM1 /** * @brief Retargets the C library printf function to the USART. * @param None * @retval None */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ /* Loop until the end of transmission */ while (USART_GetFlagStatus(USART_COM1, USART_FLAG_TC) == RESET) {} USART_SendData(USART_COM1, (uint8_t) ch); return ch; } //////////////////////////////////////////////////// |
2个回答
主要是由于fil没有定义 只要包含含有flil定义的函数就可以了
http://home.eeworld.com.cn/my/space-uid-320632-blogid-112464.html这是我之前参考的一个例程,printf重定向,可以参考下,具体可能不太一样
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 05:21 , Processed in 0.623411 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2636
