第一行能显示出来,第二行就不行。程序有点长求大家帮我看看,万分感谢!! #include ***it rs=P2^0; ***it lcden=P2^1; int num; unsigned char code table[]="The pressure is:"; //第一行 unsigned char code table1[]="100Pa"; //第二行 void delay(unsigned int t) //延时tms { unsigned int i,j; for(i=5;i>0;i--) for(j=82*t;j>0;j--); } void write_command(unsigned char command) //写命令 { rs=0; P0=command; delay(5); lcden=0; delay(5); lcden=1; } void write_dat(unsigned char dat) //写数据 { rs=1; P0=dat; delay(5); lcden=0; delay(5); lcden=1; } void init() //初始化 { lcden=0; write_command(0x38); write_command(0x0f); write_command(0x06); write_command(0x01); } void main() { init(); delay(200); write_command(0x80); for(num=0;num<16;num++) //只能显示第一行 { write_dat(table[num]); delay(5); } write_command(0x80+0x40); //第二行显示不了 for(num=0;num<5;num++) { write_dat(table1[num]); delay(5); } while(1); }
