51单片机存储16位数据,用5110显示,但是我存的是1234,显示是1279,哪位高手给指导一下,非常感谢#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
***it LCD_RST=P1^0; // N5110 的复位信号引脚,
***it LCD_CE=P1^1 ;// N5110 的片选信号引脚,
***it LCD_DC=P1^2; // N5110 的数据/命令选择引脚,
***it LCD_CLK=P1^3; // N5110 的同步时钟信号输入引脚,
***it LCD_DIN=P1^4;// N5110 的数据输入引脚
***it LCD_BL=P1^5; // N5110 的背光灯控制引脚,
***it SDA=P2^0;
***it SCL=P2^1;
uint a=1234;
int i,j;
uchar shuzhi[]={0};
code unsigned char ascii_dot[] = // ASCII 表
0x00,0x00,0x00,0x00,0x00, // - -
0x00,0x00,0x5F,0x00,0x00, // -!-
0x00,0x07,0x00,0x07,0x00, // -"-
0x14,0x7F,0x14,0x7F,0x14, // -#-
0x24,0x2E,0x7B,0x2A,0x12, // -$-
0x23,0x13,0x08,0x64,0x62, // -%-
0x36,0x49,0x56,0x20,0x50, // -&-
0x00,0x04,0x03,0x01,0x00, // -'-
0x00,0x1C,0x22,0x41,0x00, // -(-
0x00,0x41,0x22,0x1C,0x00, // -)-
0x22,0x14,0x7F,0x14,0x22, // -*-
0x08,0x08,0x7F,0x08,0x08, // -+-
0x40,0x30,0x10,0x00,0x00, // -,-
0x08,0x08,0x08,0x08,0x08, // ---
0x00,0x60,0x60,0x00,0x00, // -.-
0x20,0x10,0x08,0x04,0x02, // -/-
0x3E,0x51,0x49,0x45,0x3E, // -0-
0x00,0x42,0x7F,0x40,0x00, // -1-
0x62,0x51,0x49,0x49,0x46, // -2-
0x21,0x41,0x49,0x4D,0x33, // -3-
0x18,0x14,0x12,0x7F,0x10, // -4-
0x27,0x45,0x45,0x45,0x39, // -5-
0x3C,0x4A,0x49,0x49,0x31, // -6-
0x01,0x71,0x09,0x05,0x03, // -7-
0x36,0x49,0x49,0x49,0x36, // -8-
0x46,0x49,0x49,0x29,0x1E, // -9-
0x00,0x36,0x36,0x00,0x00, // -:-
0x40,0x36,0x36,0x00,0x00, // -;-
0x08,0x14,0x22,0x41,0x00, // -<-
0x14,0x14,0x14,0x14,0x14, // -=-
0x00,0x41,0x22,0x14,0x08, // ->-
0x02,0x01,0x59,0x05,0x02, // -?-
0x3E,0x41,0x5D,0x55,0x5E, // -@-
0x7C,0x12,0x11,0x12,0x7C, // -A-
0x7F,0x49,0x49,0x49,0x36, // -B-
0x3E,0x41,0x41,0x41,0x22, // -C-
0x7F,0x41,0x41,0x41,0x3E, // -D-
0x7F,0x49,0x49,0x49,0x41, // -E-
0x7F,0x09,0x09,0x09,0x01, // -F-
0x3E,0x41,0x51,0x51,0x72, // -G-
0x7F,0x08,0x08,0x08,0x7F, // -H-
0x00,0x41,0x7F,0x41,0x00, // -I-
0x20,0x40,0x41,0x3F,0x01, // -J-
0x7F,0x08,0x14,0x22,0x41, // -K-
0x7F,0x40,0x40,0x40,0x40, // -L-
0x7F,0x02,0x0C,0x02,0x7F, // -M-
0x7F,0x04,0x08,0x10,0x7F, // -N-
0x3E,0x41,0x41,0x41,0x3E, // -O-
0x7F,0x09,0x09,0x09,0x06, // -P-
0x3E,0x41,0x51,0x21,0x5E, // -Q-
0x7F,0x09,0x19,0x29,0x46, // -R-
0x26,0x49,0x49,0x49,0x32, // -S-
0x01,0x01,0x7F,0x01,0x01, // -T-
0x3F,0x40,0x40,0x40,0x3F, // -U-
0x1F,0x20,0x40,0x20,0x1F, // -V-
0x7F,0x20,0x18,0x20,0x7F, // -W-
0x63,0x14,0x08,0x14,0x63, // -X-
0x03,0x04,0x78,0x04,0x03, // -Y-
0x61,0x51,0x49,0x45,0x43, // -Z-
0x7F,0x7F,0x41,0x41,0x00, // -[-
0x02,0x04,0x08,0x10,0x20, // --
0x00,0x41,0x41,0x7F,0x7F, // -]-
0x04,0x02,0x7F,0x02,0x04, // -^-
0x08,0x1C,0x2A,0x08,0x08, // -_-
0x00,0x00,0x01,0x02,0x04, // -`-
0x24,0x54,0x54,0x38,0x40, // -a-
0x7F,0x28,0x44,0x44,0x38, // -b-
0x38,0x44,0x44,0x44,0x08, // -c-
0x38,0x44,0x44,0x28,0x7F, // -d-
0x38,0x54,0x54,0x54,0x08, // -e-
0x08,0x7E,0x09,0x09,0x02, // -f
0x98,0xA4,0xA4,0xA4,0x78,// -g-
0x7F,0x08,0x04,0x04,0x78, // -h-
0x00,0x00,0x79,0x00,0x00, // -i-
0x00,0x80,0x88,0x79,0x00, // -j-
0x7F,0x10,0x28,0x44,0x40, // -k-
0x00,0x41,0x7F,0x40,0x00, // -l-
0x78,0x04,0x78,0x04,0x78, // -m-
0x04,0x78,0x04,0x04,0x78, // -n-
0x38,0x44,0x44,0x44,0x38, // -o-
0xFC,0x24,0x24,0x24,0x18, // -p-
0x18,0x24,0x24,0x24,0xFC, // -q-
0x04,0x78,0x04,0x04,0x08, // -r-
0x48,0x54,0x54,0x54,0x24, // -s-
0x04,0x3F,0x44,0x44,0x24, // -t-
0x3C,0x40,0x40,0x3C,0x40, // -u-
0x1C,0x20,0x40,0x20,0x1C, // -v-
0x3C,0x40,0x3C,0x40,0x3C, // -w-
0x44,0x28,0x10,0x28,0x44, // -x-
0x9C,0xA0,0xA0,0x90,0x7C, // -y-
0x44,0x64,0x54,0x4C,0x44, // -z-
0x08,0x36,0x41,0x00,0x00, // -{-
0x00,0x00,0x77,0x00,0x00, // -|-
0x00,0x00,0x41,0x36,0x08, // -}-
0x06,0x09,0x09,0x06,0x00, // -°-
0x08,0x04,0x08,0x10,0x08, // -~-
0x55,0x2A,0x55,0x2A,0x55, // - -
void LCD_write_byte(unsigned char dat, unsigned char command) //读取串口数据
unsigned char i;
LCD_CE = 0;
if (command == 0)
LCD_DC = 0; // 0 命令
else
LCD_DC = 1; //1 数据
for(i=0;i<8;i++)
if(dat&0x80) //取数据的最高位,1 或0
LCD_DIN = 1; //(串行数据输入)
else
LCD_DIN= 0;
LCD_CLK = 0;
dat = dat << 1; //左移,依次将数据读入
LCD_CLK = 1;
LCD_CE = 1; //关闭液晶屏
void LCD_set_XY(unsigned char X, unsigned char Y)
LCD_write_byte(0x80|X,0); // row 行
LCD_write_byte(0x40|Y,0); // column 列
/*******清屏函数**********/
void LCD_clear(void)
unsigned int i ;
LCD_set_XY(0,0); // 设置初始坐标为0,0
for(i=0;i<504;i++) // 写84*6 组0x00 数据完成清屏
LCD_write_byte(0x00,1);
/*******初始化函数**********/
// N5110 写一个字符函数
void Write_Char(char ascii)
unsigned int i,coord;
coord=(ascii-' ')*5 ; // 计算该字符的模在ASCII 码表的位置
for(i=0;i<5;i++) // 依次写入模值
LCD_write_byte(ascii_dot[coord+i],1);
// N5110 写一个字符串函数
void Write_String(char *string)
while(*string != 0x00) // 输出直到遇到0x00
Write_Char(*string) ;
string++ ;
void LCD_Init(void) //初始化液晶屏,用八位的二进制数控制各引脚
LCD_RST=0; //低电平,复位
_nop_(); //空循环一个机器周期
LCD_RST=1;
LCD_CE=1; //// 初始不选通N5110 芯片
LCD_write_byte(0x21, 0);// 使用扩展命令设置LCD 模式
LCD_write_byte(0xbb, 0); // 设置偏置电压
LCD_write_byte(0x06, 0); // 温度校正
LCD_write_byte(0x13, 0); // 1:48
LCD_write_byte(0x20, 0); // 使用基本命令
// 清屏
LCD_write_byte(0x0c, 0);// 设定显示模式,正常显示
LCD_clear();
void delay(){
void delayms(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void start() //开始信号
SDA=1;
delay();
SCL=1;
delay();
SDA=0;
delay();
void stop() //停止
SDA=0;
delay();
SCL=1;
delay();
SDA=1;
delay();
void respons() //应答
uchar i;
SCL=1;
delay();
while((SDA==1)&&(i<250))i++;
SCL=0;
delay();
void c02init()
SDA=1;
delay();
SCL=1;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
SCL=0;
delay();
SDA=CY;
delay();
SCL=1;
delay();
SCL=0;
delay();
SDA=1;
delay();
uchar read_byte()
uchar i,k;
SCL=0;
delay();
SDA=1;
delay();
for(i=0;i<8;i++)
SCL=1;
delay();
k=(k<<1)|SDA;
SCL=0;
delay();
return k;
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
void main()
LCD_Init();
c02init();
/* i=a/256;
j=a%256;
write_add(0,i);
write_add(1,j); */ //这段用于先存入数据,存的过程中,把下面的屏蔽
i=read_add(0); // 这段用于读出数据显示
j=read_add(1);
a=((i*256)|j);
LCD_set_XY(0,0);
sprintf(shuzhi,"%d",a);
Write_String(shuzhi);
while(1);
