`/*******************附代码************************/ #include #define ON 1 #define OFF 0 #define scan_delay 20 #define button_delay 50 unsigned char code LED[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; unsigned char n=0;//表示状态的变化 unsigned char sec,min,hour;//秒,分,时 unsigned char min_0,min_1,hour_0,hour_1;//分,时 个位,十位 unsigned char key; ***it D1=P0^3;***it D2=P0^2;***it D3=P0^1;***it D4=P0^0; //段选 ***it set=P1^0;***it plus=P1^1;***it minus=P1^2;//按键 void delay(unsigned int a)//延迟函数 { for(;a!=0;a--); } void scan_min_0()// 分 个位 { P2=0;delay(scan_delay);P2=LED[min%10];delay(scan_delay);D4=ON; delay(scan_delay);D4=OFF;delay(scan_delay); } void scan_min_1()// 分 十位 { P2=0;delay(scan_delay);P2=LED[min/10];delay(scan_delay);D3=ON; delay(scan_delay);D3=OFF; delay(scan_delay); } void scan_hour_0()// 时 个位 { P2=0;delay(scan_delay);P2=LED[hour%10];delay(scan_delay);D2=ON; delay(scan_delay);D2=OFF;delay(scan_delay); } void scan_hour_1()// 时 十位 { P2=0;delay(scan_delay);P2=LED[hour/10];delay(scan_delay);D1=ON; delay(scan_delay);D1=OFF; delay(scan_delay); } void scan_LED()// 总扫描函数 { if(n==0) { scan_min_0(); scan_min_1(); scan_hour_0(); scan_hour_1(); } else if(n==1) { if(n>=10)scan_min_0(); scan_min_1(); scan_hour_0(); scan_hour_1(); } else if(n==2) { scan_min_0(); if(n>=10)scan_min_1(); scan_hour_0(); scan_hour_1(); } else if(n==3) { scan_min_0(); scan_min_1(); if(n>=10)scan_hour_0(); scan_hour_1(); } else if(n==4) { scan_min_0(); scan_min_1(); scan_hour_0(); if(n>=10)scan_hour_1(); } } void button() { // set按键设置 if(set==1) { delay(button_delay); if(set==1) { while(set==1) scan_LED(); n++; n=n%5; } } // 加一键的设置 if(plus==1) { delay(button_delay); if(plus==1) { while(plus==1) scan_LED(); key=1; } } // 减一键的设置 if(minus==1) { delay(button_delay); if(minus==1) { while(plus==1) scan_LED(); key=2; } } } void status_0() // 状态0 { scan_LED(); } void status_1() // 状态1 { scan_LED(); if(n==1) { min_0++; min_0=min_0%10; } else if(n==2) { min_0--; if(min_0>9)min=9; } } void status_2() // 状态2 { scan_LED(); if(n==1) { min_1++; min_1=min_1%6; } else if(n==2) { min_0--; if(min_0>5)min=5; } } void status_3() // 状态3 { scan_LED(); if(n==1) { hour_0++; hour_0=hour_0%10; } else if(n==2) { hour_0--; if(hour_0>9)hour=9; } } void status_4() // 状态4 { scan_LED(); if(n==1) { hour_1++; hour_1=hour_1%3; } else if(n==2) { hour_1--; if(hour_1>2)hour=2; } } void status() { min_0=min%10; //将 分时 的个位十位提取出来 min_1=min/10; hour_0=hour%10; hour_1=hour/10; if(n==0) status_0(); else if(n==1) status_1(); else if(n==2) status_2(); else if(n==3) status_3(); else if(n==4) status_4(); min=min_0+min_1*10; hour=hour_0+hour_1*10; if(hour>=24)hour=23; } void main() { EA=1; ET0=1; TMOD=1; TH0=(65535-50000)/256; TL0=(65535-50000)%256; TR0=1; while(1) { button(); status(); } } void time() interrupt 1 //计时器中断 { TH0=(65535-50000)/256; TL0=(65535-50000)%256; n++; if(n==20) { n=0; sec++; if(sec==60) { sec=0; min++; if(min==60) { min=0; hour++; hour=hour%24; } } } } /***************************************仿真*****************************/ ` ![]() |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2024年上海海思MCU开发者体验官招募,手机/MatePad大奖等你拿!
1144 浏览 0 评论
【xG24 Matter开发套件试用体验】蓝牙控制板载LED
890 浏览 0 评论
1066 浏览 0 评论
电赛:mspm0l1306的开发板可以烧录程序,但是程序运行不了,怎么解决这个问题?
1117 浏览 1 评论
【xG24 Matter开发套件试用体验】Silicon Labs 基于 EFR32MG24 Explorer Kit 开发板 开箱试用体验
872 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
10546 浏览 31 评论
GMT+8, 2024-8-8 01:20 , Processed in 0.549190 second(s), Total 70, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
