扫一扫,分享给好友
那位大哥帮忙看下这个编译警告怎样解决啊;谢谢了!
Warning (10631): VHDL Process Statement warning at action.vhd(163): inferring latch(es) for signal or variable "data1", which holds its previous value in one or more paths through the process |
8个回答
代码贴上来,IO信号接得有问题
p2: process(cnt,see_temp)
begin if see_temp='0' then data1 <=30000; data2 <=40000; data3 <=50000; data4 <=60000; data5 <=70000; data6 <=80000; data7 <=90000; data8 <=100000; data9 <=110000; data10<=120000; else case cnt is --The robot perform actions data when 0 => data1 <=30000; data2 <=40000; data3 <=50000; data4 <=60000; data5 <=70000; data6 <=80000; data7 <=90000; data8 <=100000; data9 <=110000; data10<=120000; when 1 => data1 <=30000; data2 <=40000; data3 <=50000; data4 <=60000; data5 <=70000; data6 <=80000; data7 <=90000; data8 <=100000; data9 <=110000; data10<=120000; when 2 => data1 <=30000; data2 <=40000; data3 <=50000; data4 <=60000; data5 <=70000; data6 <=80000; data7 <=90000; data8 <=100000; data9 <=110000; data10<=120000; when 3 => data1 <=30000; data2 <=40000; data3 <=50000; data4 <=60000; data5 <=70000; data6 <=80000; data7 <=90000; data8 <=100000; data9 <=110000; data10<=120000; when 4 => data1 <=30000; data2 <=40000; data3 <=50000; data4 <=60000; data5 <=70000; data6 <=80000; data7 <=90000; data8 <=100000; data9 <=110000; data10<=120000; when 5 => data1 <=30000; data2 <=40000; data3 <=50000; data4 <=60000; data5 <=70000; data6 <=80000; data7 <=90000; data8 <=100000; data9 <=110000; data10<=120000; when 6 => -- data1 <=30000; -- data2 <=40000; -- data3 <=50000; -- data4 <=60000; -- data5 <=70000; -- data6 <=80000; -- data7 <=90000; -- data8 <=100000; -- data9 <=110000; -- data10<=120000; -- when 7 => -- data1 <=30000; -- data2 <=40000; -- data3 <=50000; -- data4 <=60000; -- data5 <=70000; -- data6 <=80000; -- data7 <=90000; -- data8 <=100000; -- data9 <=110000; -- data10<=120000; -- when 8 => -- data1 <=30000; -- data2 <=40000; -- data3 <=50000; -- data4 <=60000; -- data5 <=70000; -- data6 <=80000; -- data7 <=90000; -- data8 <=100000; -- data9 <=110000; -- data10<=120000; -- when 9 => -- data1 <=30000; -- data2 <=40000; -- data3 <=50000; -- data4 <=60000; -- data5 <=70000; -- data6 <=80000; -- data7 <=90000; -- data8 <=100000; -- data9 <=110000; -- data10<=120000; when others=> data1 <=30000; data2 <=40000; data3 <=50000; data4 <=60000; data5 <=70000; data6 <=80000; data7 <=90000; data8 <=100000; data9 <=110000; data10<=120000; end case; end if; end process p2; |
data1,data2,data3.......data10都是数据,see_temp是使能信号
data1,data2,data3.......data10都是输出端口,see_temp是使能信号
明显data1....是信号,不能直接赋整数值.只能是二进制,8进制,16进制的字符串.也就是说<=两边的数据类型不匹配啊.
例如:data1<="010101",或者data1<=O"176",或者data1<=x"AD0"等.
我输出定义的是integer型啊
哦,我理解错了,呵呵.
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
862 浏览 0 评论
426 浏览 0 评论
求FPGA 驱动控制ltc2271 或者 ltc2180 或者 ltc2190或者 ltc2202 的代码
1821 浏览 0 评论
491 浏览 0 评论
求助:遇见诡异问题,FPGA模块A输出端口连接模块B输入后,模块A不能正常工作的
1934 浏览 1 评论
4658 浏览 104 评论
GMT+8, 2024-9-1 05:53 , Processed in 0.570505 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
