硬件环境为蜂鸟实验板和调试器。修改e203的代码,然后综合生成*.mcs文件,下载至开发板,然后编写软件代码下载到开发板时出现如下现象。起初下载软件程序至开发板,upload成功,screen打印出结果。但多下载几次或者断电后重新下载软件代码至开发板,出现错误,错误如下:
Info : Exposing additional CSR 3067 Info : Exposing additional CSR 3068 Info : Exposing additional CSR 3069 Info : Exposing additional CSR 3070 Info : Exposing additional CSR 3071 Error: Timed out waiting for debug int to clear.Increase timeout with riscv set_command_timeout_sec. Error: Debug interrupt didn't clear. Error: Debug RAM 0x0: 0xfff04493 Error: Debug RAM 0x1: 0x01f4d493 Error: Debug RAM 0x2: 0x40902023 Error: Debug RAM 0x3: 0x01f4d493 Error: Debug RAM 0x4: 0x40902223 Error: Debug RAM 0x5: 0x3f00006f Error: Debug RAM 0x6: 0x060c1218 Error: Debug RAM 0x7: 0x00000000 Error: Debug RAM 0x8: 0x00000000 Error: Debug RAM 0x9: 0x00000000 Error: Debug RAM 0xa: 0x00000000 Error: Debug RAM 0xb: 0x00000000 Error: Debug RAM 0xc: 0x00000000 Error: Debug RAM 0xd: 0x00000000 Error: Debug RAM 0xe: 0x00000000 Error: Debug RAM 0xf: 0x00000000 Error: Timed out waiting for debug int to clear.Increase timeout with riscv set_command_timeout_sec. Error: Debug interrupt didn't clear. Error: Debug RAM 0x0: 0xfff04493 Error: Debug RAM 0x1: 0x01f4d493 Error: Debug RAM 0x2: 0x40902023 Error: Debug RAM 0x3: 0x01f4d493 Error: Debug RAM 0x4: 0x40902223 Error: Debug RAM 0x5: 0x3f00006f Error: Debug RAM 0x6: 0x060c1218 Error: Debug RAM 0x7: 0x00000000 Error: Debug RAM 0x8: 0x00000000 Error: Debug RAM 0x9: 0x00000000 Error: Debug RAM 0xa: 0x00000000 Error: Debug RAM 0xb: 0x00000000 Error: Debug RAM 0xc: 0x00000000 Error: Debug RAM 0xd: 0x00000000 Error: Debug RAM 0xe: 0x00000000 Error: Debug RAM 0xf: 0x00000000 Error: Failed to discover xlen; word0=0xfff04493, word1=0x1f4d493, exception=0x60c1218 Error: Debug RAM 0x0: 0xfff04493 Error: Debug RAM 0x1: 0x01f4d493 Error: Debug RAM 0x2: 0x40902023 Error: Debug RAM 0x3: 0x01f4d493 Error: Debug RAM 0x4: 0x40902223 Error: Debug RAM 0x5: 0x3f00006f Error: Debug RAM 0x6: 0x060c1218 Error: Debug RAM 0x7: 0x00000000 Error: Debug RAM 0x8: 0x00000000 Error: Debug RAM 0x9: 0x00000000 Error: Debug RAM 0xa: 0x00000000 Error: Debug RAM 0xb: 0x00000000 Error: Debug RAM 0xc: 0x00000000 Error: Debug RAM 0xd: 0x00000000 Error: Debug RAM 0xe: 0x00000000 Error: Debug RAM 0xf: 0x00000000 Info : Listening on port 3333 for gdb connections Error: Target not examined yet Warn : Flash driver of my_first_flash does not support free_driver_priv() localhost:3333: Connection timed out. "monitor" command not supported by this target. "monitor" command not supported by this target. You can't do that when your target is `exec' |
1个回答
针对您在使用蜂鸟实验板(基于E203内核)时遇到的 问题根源分析
解决方案(逐步操作)1. 增加OpenOCD超时时间修改OpenOCD配置文件(如
2. 强制复位开发板在执行
3. 清理调试器状态在下载失败后,执行以下步骤:
4. 检查电源与接线
5. 启用OpenOCD详细日志在OpenOCD配置中添加: 分析日志 6. 修改E203调试逻辑(进阶)如果上述步骤无效,检查E203的调试模块代码:
7. 更新工具链
操作流程示例预防措施
通过以上步骤,90%以上的类似问题可被解决。若仍失败,请提供 OpenOCD日志 和 硬件连接图 进一步分析! |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【作品合集】玄铁BPI-CanMV-K230D-Zero开发板测评
3030 浏览 0 评论
【作品合集】玄铁Banana Pi BPI-RV2开发板测评
1679 浏览 0 评论
27298 浏览 0 评论
【作品合集】矽速科技Sipeed MaixCAM Pro开发板测评
33636 浏览 0 评论
【作品合集】赛昉科技VisionFive 2单板计算机开发板测评
36189 浏览 0 评论
/9
GMT+8, 2025-12-2 01:10 , Processed in 0.491308 second(s), Total 45, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
315
