环境:win11 使用代理服务器上网,网络访问正常
版本:2.2.6
构建ID:202211231640
第一次启动失败,提示err_name_not_resolved错误
改为直连宽带上网,可以正常启动了,都没问题
再改为公司网络,可以启动,但首页上提示网络连接错误,见下图
安装路径下的debug.log内容如下:
- [0221/135253.111:INFO:CONSOLE(10)] "Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/less.min.js (10)
- [0221/135253.125:INFO:CONSOLE(10)] "Rendered file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/static/theme.less successfully.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/less.min.js (10)
- [0221/135253.125:INFO:CONSOLE(10)] "CSS for file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/static/theme.less generated in 16ms", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/less.min.js (10)
- [0221/135253.127:INFO:CONSOLE(10)] "Less has finished. CSS generated in 16ms", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/less.min.js (10)
- [0221/135253.205:INFO:CONSOLE(10)] "Rendered file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/static/theme.less successfully.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/less.min.js (10)
- [0221/135253.205:INFO:CONSOLE(10)] "CSS for file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/static/theme.less generated in 4ms", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/less.min.js (10)
- [0221/135253.205:INFO:CONSOLE(10)] "Less has finished. CSS generated in 4ms", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/less.min.js (10)
- [0221/135428.220:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
- [0221/171110.761:INFO:CONSOLE(2)] "Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/common/js/jquery.js (2)
- [0221/171110.962:INFO:CONSOLE(177)] "[object Object]", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/js/index.js (177)
- [0221/174926.215:INFO:CONSOLE(1)] "Uncaught (in promise) Error: Network Error", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/axios.min.js (1)
- [0221/174927.714:INFO:CONSOLE(1)] "Uncaught (in promise) Error: Network Error", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/axios.min.js (1)
- [0221/174927.740:INFO:CONSOLE(1)] "Uncaught (in promise) Error: Network Error", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/axios.min.js (1)
- [0221/174927.757:INFO:CONSOLE(1)] "Uncaught (in promise) Error: Network Error", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/axios.min.js (1)
- [0221/174927.811:INFO:CONSOLE(1)] "Uncaught (in promise) Error: Network Error", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/axios.min.js (1)
- [0221/174927.840:INFO:CONSOLE(1)] "Uncaught (in promise) Error: Network Error", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/axios.min.js (1)
- [0221/174927.978:INFO:CONSOLE(1)] "Uncaught (in promise) Error: Network Error", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.kconfig.pkg_1.0.26/web/dist/thirdParty/axios.min.js (1)
- [0221/181512.518:INFO:CONSOLE(2)] "Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/common/js/jquery.js (2)
- [0221/181512.797:INFO:CONSOLE(177)] "[object Object]", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/js/index.js (177)
- [0221/181711.533:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
- [0221/183828.199:INFO:CONSOLE(2)] "Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/common/js/jquery.js (2)
- [0221/183828.389:INFO:CONSOLE(177)] "[object Object]", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/js/index.js (177)
- [0222/090109.851:INFO:CONSOLE(2)] "Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/common/js/jquery.js (2)
- [0222/090110.110:INFO:CONSOLE(177)] "[object Object]", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/js/index.js (177)
- [0222/090143.337:INFO:CONSOLE(2)] "Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/common/js/jquery.js (2)
- [0222/090143.348:INFO:CONSOLE(177)] "[object Object]", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/js/index.js (177)
- [0222/090308.624:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
- [0222/090608.478:INFO:CONSOLE(2)] "Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/common/js/jquery.js (2)
- [0222/090608.548:INFO:CONSOLE(177)] "[object Object]", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/js/index.js (177)
- [0222/091302.866:INFO:CONSOLE(2)] "Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/common/js/jquery.js (2)
- [0222/091302.945:INFO:CONSOLE(177)] "[object Object]", source: file:///C:/RT-ThreadStudio//plugins/org.rt-thread.studio.project.ui.web_1.0.5/welcome/js/index.js (177)
- [0222/091502.007:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
1个回答
