当网口配置完,并且ping通后,当使用netu tils的tftp文件传输功能时,就报以下错误,有没有大佬可以解释一下
- In file included from D:git111rtt_ysh7_controllerrt-threadcomponentsnetsal_socketincludedfs_netsys_select/sys/select.h:14:0,
- from d:rt-threadstudiorepoextracttoolchain_support_packagesarmgnu_tools_for_arm_embedded_processors5.4.1arm-none-eabiincludesystypes.h:68,
- from d:rt-threadstudiorepoextracttoolchain_support_packagesarmgnu_tools_for_arm_embedded_processors5.4.1arm-none-eabiincludetime.h:28,
- from d:rt-threadstudiorepoextracttoolchain_support_packagesarmgnu_tools_for_arm_embedded_processors5.4.1arm-none-eabiincludesysstat.h:9,
- from D:git111rtt_ysh7_controllerrt-threadinclude/libc/libc_stat.h:14,
- from D:git111rtt_ysh7_controllerrt-threadinclude/rtlibc.h:15,
- from D:git111rtt_ysh7_controllerrt-threadinclude/rtdef.h:1103,
- from D:git111rtt_ysh7_controllerrt-threadinclude/rtthread.h:24,
- from D:git111rtt_ysh7_controllerrt-threadinclude/rthw.h:20,
- from ../rt-thread/src/clock.c:19:
- D:git111rtt_ysh7_controllerrt-threadcomponentsdfsinclude/dfs_select.h:19:22: error: unknown type name 'fd_set'
- int select(int nfds, fd_set *readfds, fd_set *writefds, fd_set *exceptfds, struct timeval *timeout);
- D:git111rtt_ysh7_controllerrt-threadcomponentsdfsinclude/dfs_select.h:19:39: error: unknown type name 'fd_set'
- D:git111rtt_ysh7_controllerrt-threadcomponentsdfsinclude/dfs_select.h:19:57: error: unknown type name 'fd_set'
- make: *** [rt-thread/src/subdir.mk:57: rt-thread/src/clock.o] Error 1
- make: *** Waiting for unfinished jobs....
- from ../rt-thread/src/components.c:20:
- make: *** [rt-thread/src/subdir.mk:57: rt-thread/src/components.o] Error 1
- from ../rt-thread/src/device.c:17:
- make: *** [rt-thread/src/subdir.mk:57: rt-thread/src/device.o] Error 1
- from ../rt-thread/src/idle.c:20:
- make: *** [rt-thread/src/subdir.mk:57: rt-thread/src/idle.o] Error 1
- from ../rt-thread/src/ipc.c:42:
- make: *** [rt-thread/src/subdir.mk:57: rt-thread/src/ipc.o] Error 1
- "make -j32 all" terminated with exit code 2. Build might be incomplete.
- 10:59:49 Build Failed. 21 errors, 0 warnings. (took 1s.666ms)
1个回答
