电子发烧友论坛|
https://www.kendryte.com/k230_canmv/zh/main/zh/ai_dev_doc.html#id11 根据这个里面的例程(windows)修改文件地址后报错如下
C:InstallAnaconda3envsYOLOpython.exe C:AllPycharmProjectsyolov11toK230models_compare.py Traceback (most recent call last): File "C:AllPycharmProjectsyolov11toK230models_compare.py", line 119, in nncase_results = kmodel_inference(kmodel_path,kmodel_input_data,model_input_size) File "C:AllPycharmProjectsyolov11toK230models_compare.py", line 76, in kmodel_inference sim.load_model(kmodel)RuntimeError进程已结束,退出代码为 1测试了kmodel应该是没有问题的,如下: import oskmodel_path = "./models/numDetect_yolov5su.kmodel"print("kmodel_path:", kmodel_path)print("File exists:", os.path.exists(kmodel_path))with open(kmodel_path, 'rb') as f: kmodel = f.read()print("kmodel size:", len(kmodel))=============================================================================C:InstallAnaconda3envsYOLOpython.exe C:AllPycharmProjectsyolov11toK230test.py kmodel_path: ./models/numDetect_yolov5su.kmodelFile exists: Truekmodel size: 9768648进程已结束,退出代码为 0尝试了把nncase降级到2.8.3(原来是2.9.0)也没用 import osimport cv2import numpy as npimport onnxruntime as ortimport nncaseimport math# 参数定义IMG_PATH = "../numDetect/dataset/data/images/test/0_91.jpg"MEAN = [0, 0, 0]STD = [1, 1, 1]MODEL_INPUT_SIZE = [320, 320]ONNX_MODEL = "../numDetect/runs/detect/train/weights/best.onnx" # ONNX 模型文件KMODEL_PATH = "./models/yolov5su.kmodel" # kmodel 模型文件def get_onnx_input(img_path,mean,std,model_input_size): # 读取图片,图片数据一般是RGB三通道,颜色范围为[0, 255.0] image_fp32=cv2.imread(img_path) # 如果模型输入要求是RGB的,则转换为RGB格式,如果要求是BGR的,则不需要转换 image_fp32=cv2.cvtColor(image_fp32, cv2.COLOR_BGR2RGB) # 缩放成模型输入大小 image_fp32 = cv2.resize(image_fp32, (model_input_size[0], model_input_size[1])) # 数据类型为float32, image_fp32 = np.asarray(image_fp32, dtype=np.float32) # 数据标准化,先归一化到[0,1]范围内,然后减均值除方差 image_fp32/=255.0 for i in range(3): image_fp32[:, :, i] -= mean image_fp32[:, :, i] /= std # 按照模型输入要求处理成NCHW排布或者NHWC排布 image_fp32 = np.transpose(image_fp32, (2, 0, 1)) return image_fp32.copy()def get_kmodel_input(img_path,mean,std,model_input_size): # 读取图片,图片数据一般是RGB三通道,颜色范围为[0, 255.0] image_uint8=cv2.imread(img_path) # 如果模型输入要求是RGB的,则转换为RGB格式,如果要求是BGR的,则不需要转换 image_uint8=cv2.cvtColor(image_uint8, cv2.COLOR_BGR2RGB) # 缩放成模型输入大小 image_uint8 = cv2.resize(image_uint8, (model_input_size[0], model_input_size[1])) # 数据类型为uint8,因为转换kmodel的时候开启了预处理,并且设定了标准化参数,因此这里的输入就不需要实现标准化了 image_uint8 = np.asarray(image_uint8, dtype=np.uint8) # 按照模型输入要求处理成NCHW排布或者NHWC排布 image_uint8 = np.transpose(image_uint8, (2, 0, 1)) return image_uint8.copy()def onnx_inference(onnx_path,onnx_input_data): # 创建 ONNX 推理会话(加载模型) ort_session = ort.InferenceSession(onnx_path) # 获取模型输出名称列表,用于后续调用推理 output_names = [] model_outputs = ort_session.get_outputs() for i in range(len(model_outputs)): output_names.append(model_outputs.name) # 获取模型的输入信息 model_input = ort_session.get_inputs()[0] # 第一个输入(通常只有一个) model_input_name = model_input.name # 输入的名称(键) model_input_type = np.float32 # 输入数据类型,这里假设是 float32 model_input_shape = model_input.shape # 输入张量的形状(维度) # 处理输入数据,需确保和模型输入形状一致 model_input_data = onnx_input_data.astype(model_input_type).reshape(model_input_shape) # 执行推理,传入输入名称和数据,返回所有输出结果 onnx_results = ort_session.run(output_names, { model_input_name : model_input_data }) return onnx_resultsdef kmodel_inference(kmodel_path,kmodel_input_data,model_input_size): # 初始化nncase 模拟器 sim = nncase.Simulator() # 读取kmodel with open(kmodel_path, 'rb') as f: kmodel = f.read() # 加载kmodel sim.load_model(kmodel) # 读取输入数据 input_shape = [1, 3, model_input_size[1], model_input_size[0]] dtype = sim.get_input_desc(0).dtype # 处理输入数据,需确保和模型输入形状一致 kmodel_input = kmodel_input_data.astype(dtype).reshape(input_shape) # 设置模拟器输入tensor,此处为单输入 sim.set_input_tensor(0, nncase.RuntimeTensor.from_numpy(kmodel_input)) # 模拟器推理kmodel模型 sim.run() # 获取推理输出 kmodel_results = [] for i in range(sim.outputs_size): kmodel_result = sim.get_output_tensor(i).to_numpy() # 转换为numpy数组 kmodel_results.append(kmodel_result) # 保存到列表中 return kmodel_resultsdef cosine_similarity(onnx_results,kmodel_results): output_size=len(kmodel_results) # 将每个输出展成一维,然后计算余弦相似度 for i in range(output_size): onnx_i=np.reshape(onnx_results, (-1)) kmodel_i=np.reshape(kmodel_results, (-1)) cos = (onnx_i @ kmodel_i) / (np.linalg.norm(onnx_i, 2) * np.linalg.norm(kmodel_i, 2)) print('output {0} cosine similarity : {1}'.format(i, cos)) returnif __name__ == '__main__': img_path=IMG_PATH mean=MEAN std=STD model_input_size=MODEL_INPUT_SIZE # ONNX 模型文件 onnx_model = ONNX_MODEL # kmodel 模型文件 kmodel_path = KMODEL_PATH # 生成onnx模型输入数据 onnx_input_data = get_onnx_input(img_path,mean,std,model_input_size) # 生成kmodel模型输入数据 kmodel_input_data = get_kmodel_input(img_path,mean,std,model_input_size) # onnx模型推理 onnx_results = onnx_inference(onnx_model,onnx_input_data) # kmodel模型推理 nncase_results = kmodel_inference(kmodel_path,kmodel_input_data,model_input_size) # 计算输出相似度 cosine_similarity(onnx_results,nncase_results) 修改什么文件地址了 |
只有小组成员才能发言,加入小组>>
AI_cube训练模型得到了npy文件,没有kmodel文件
770 浏览 0 评论
请问K230 V3.0版本烧录固件和使用IDE到底是烧录哪个啊?
735 浏览 0 评论
443浏览 4评论
AI Cube进行yolov8n模型训练,创建项目目标检测时显示数据集目录下存在除标注和图片外的其他目录如何处理?
462浏览 3评论
autodl算力云在.pt转换onnx文件时正常,但onnx转.kmodel文件时报错,为什么?
552浏览 2评论
如何在大核rtt上把kd_mpi_vicap_start_stream三个摄像头各自出的流拼成一个流呢?
164浏览 2评论
564浏览 2评论
/9
GMT+8, 2025-12-1 22:06 , Processed in 0.449393 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
462
