如题, 报错日志如下 [param.c][rk_param_init]:g_ini_path_ is /oem/usr/share/rkipc-300w.ini rockit log path (null), log_size = 0, can use export rt_log_path=, export rt_log_size= change log_file = (nil) RTVersion 09:09:53-523 {dump :064} --------------------------------------------------------- RTVersion 09:09:53-523 {dump :065} rockit version: git-4720dc10a Tue Apr 30 15:47:55 2024 +0800 RTVersion 09:09:53-523 {dump :066} rockit building: built- 2024-04-30 15:53:43 RTVersion 09:09:53-523 {dump :067} --------------------------------------------------------- (null) 09:09:53-523 {log_level_init :207} please use echo name=level > /tmp/rt_log_level set log level name: all cmpi mb sys vdec venc rgn vpss vgs tde avs wbc vo vi ai ao aenc adec log_level: 0 1 2 3 4 5 6 rockit default level 4, can use export rt_log_level=x, x=0,1,2,3,4,5,6 change (null) 09:09:53-523 {read_log_level :098} text is all=4 (null) 09:09:53-524 {read_log_level :100} module is all, log_level is 4 [audio.c][rkipc_ai_init]:aiAttr.u8CardName is hw:0,0 RKAiChn 09:09:53-527 {prepareGraph :213} check enabled - file_read:0 vqe:0 aed:0 bcd:0 buz:0 gbs:0 (null) 09:09:53-529 {monitor_log_level :149} #Start monitor_log_level thread, arg:(nil) [audio.c][rkipc_ao_init]:aoAttr.u8CardName is hw:0,0 cannot set hw params: Invalid argument TinyAlsaHardWare 09:09:53-658 {tinyalsa_pcm_get_e:052} fail to tinyalsa_open_snd, error:cannot set hw params: Invalid argument RTTaskNodeBase 09:09:53-658 {prepareForRun :485} task node 0 open failed! RTTaskGraph 09:09:53-658 {prepareNodeForRun :295} failed to prepareNodeForRun(id=0)! interrupt running RTTaskGraph 09:09:53-658 {prepare :364} task graph prepare for run failed!, ret=-10 [audio.c][rkipc_ao_init]:RK_MPI_AO_EnableChn fail 0xa00b8010 u32Channels 1 u32SampleRate 8000 enBitwidth 1cmpi 09:09:53-659 {ao_enable_resample:298} Not found channel(dev 0, chn 0) cmpi 09:09:53-659 {rkipc_ao_init :583} ao enable channel fail, reason = a00b8002, aoChn = 0 =======rkipc_adec_init======= [audio.c][rkipc_audio_init]:RK_MPI_SYS_Bind fail ffffffff cmpi 09:09:53-664 {ao_get_chn_info :679} Not found channel(dev 0, chn 0) Bind ADEC[0] to AO[0] failed! ret=-1610448888 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1265 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
6401 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2076 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2616 浏览 0 评论
2615 浏览 0 评论
/9
GMT+8, 2025-12-11 11:23 , Processed in 0.495322 second(s), Total 40, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
481
