电子发烧友论坛|
处理器:STM32MP135D (单核CA7)
问题现象:操作 DDR 过慢。 一秒才能画(进行)大约 200000~300000 个点(次写操作,尺度为 uint16_t)。速度大约 ??kB/s,但正常情况应该是 ?? MB/s(吧?)。 应用背景:LTDC.LAYER + DDR 例程参考 :STM32Cube_FW_MP13_V1.1.0 映射地址:0xC000'0000 使用DDR:NT5CC256M16EP-EKI DDR3(L) 4Gb SDRAM CL-TRCD-TRP{13-13-13} 手册要求 933MHz Clock但是STM32MP13x 最高给 DDRC 频率 533MHz 其他外设 LTDC频率 33MHz CL-TRCD-TRP 为{7-7-7},这个参数不知道怎么配置。以下为本人时钟树配置信息: using namespace RCCReg; RCC.canMode(); PWR.setDBP(true); RCC[BDCR].maset(_IMM(_BDCR::LSEDRV), 2, 0b10); // OSC PART: Order: HSE HSI CSI LSI LSE PLL uni::RCC.HSE.setMode(false);// no-bypass uni::RCC.HSI.setMode(0, 0);// DIV1 and Cali(0x0) uni::RCC.CSI.setMode(0x10); uni::RCC.LSI.setMode(); uni::RCC.LSE.setMode(false);// no-bypass if (!RCC.PLL1.setModePLL12(PLLMode::Fractional, PLL1Source::HSE, .m=3, .n=81, .p=1, .q=2, .r=2, .frac=0x800)) erro(); if (!RCC.PLL2.setModePLL12(PLLMode::Fractional, PLL2Source::HSE, .m=3, .n=66, .p=2, .q=2, .r=1, .frac=5120)) erro();// for 533M DDR bool if_range3 = true; if (!RCC.PLL3.setModePLL34(PLLMode::Fractional, PLL3Source::HSE, if_range3, .m=2, .n=34, .p=2, .q=17, .r=2, .frac=0x1a04)) erro(); bool if_range4 = true; if (!RCC.PLL4.setModePLL34(PLLMode::Fractional, PLL4Source::HSE, if_range4, .m=2, .n=38, .p=12, .q=14, .r=6, .frac=4096)) erro();// 33M for LTDC bool state = true; // BUS PART: Order: MPU ACLK HCLK PCLK4 PCLK5 PCLK1 PCLK2 PCLK3 PCLK6 asserv(state) = RCC.Sysclock.setMode(SysclkSource::PLL1, 1);// PLL1 DIV2 else erro(); asserv(state) = RCC.AXIS.setMode(AxisSource::PLL2, 1);// PLL2 DIV1 else erro(); asserv(state) = RCC.MLAHB.setMode(MLAHBSource::PLL3, 0);// PLL3 DIV1 else erro(); // APBs RCC.APB4.setMode(1);// PCLK4 RCC_APB4_DIV2 RCC.APB5.setMode(2);// PCLK5 RCC_APB5_DIV4 RCC.APB1.setMode(1);// PCLK1 RCC_APB1_DIV2 RCC.APB2.setMode(1);// PCLK2 RCC_APB2_DIV2 RCC.APB3.setMode(1);// PCLK3 RCC_APB3_DIV2 RCC.APB6.setMode(1);// PCLK6 RCC_APB6_DIV2初始化代码 __HAL_RCC_CSI_ENABLE() ; __HAL_RCC_SYSCFG_CLK_ENABLE() ; #if (USE_STPMIC1x) && !defined(USE_DDR) BSP_PMIC_Init(); BSP_PMIC_InitRegulators(); #endif /*##-1- Enable MCE ####################*/ __HAL_RCC_MCE_CLK_ENABLE(); /*##-2- TZC configuration ####################*/ __HAL_RCC_TZC_CLK_ENABLE(); /* Configure TZC to allow DDR Region0 R/W non secure for all IDs */ TZC->GATE_KEEPER =0; TZC->REG_ID_ACCESSO=0xFFFFFFFF; //Allow DDR Region0 R/W non secure for all IDs TZC->REG_ATTRIBUTESO = 0xC0000001; TZC->GATE_KEEPER |=1; //Enable the access in secure Mode // filter 0 request close /*##-3- Enable ETZPC & BACKUP SRAM for security ####################*/ __HAL_RCC_ETZPC_CLK_ENABLE(); __HAL_RCC_BKPSRAM_CLK_ENABLE(); /*##-4- Unlock debugger ####################*/ BSEC->BSEC_DENABLE = 0x47f; /*##-5- Init DDR ####################*/ hddr.wakeup_from_standby = false; hddr.self_refresh = false; hddr.zdata = 0; hddr.clear_bkp = false; if (HAL_DDR_Init(&hddr) != HAL_OK) { while(1); }对应配置文件亦有修改: #ifndef STM32MP13XX_DDR3_4GBIT_H#define STM32MP13XX_DDR3_4GBIT_H#define DDR_MEM_NAME "DDR3-1066 bin F 1x4Gb 533MHz v1.53"#define DDR_MEM_SPEED 533000U#define DDR_MEM_SIZE (256*1024*1024)//0x20000000U...#define DDR_DFITMG0 0x02050105U// 不知道这个需不需要change...#define DDR_ADDRMAP6 0x0F0F0707//0x0F070707U...#define DDR_MR0 0x00000830U求助家人们怎么解决这个问题。 |
1个回答
针对你描述的 STM32MP135D 操作 DDR 过慢的问题,以下是一些可能的原因和解决方案: 1. DDR 时钟频率配置
2. DDR 时序参数配置
3. DDR 初始化配置
4. LTDC 与 DDR 的带宽瓶颈
5. DDR 访问优化
6. Cache 配置
7. 性能测试与优化
8. 硬件设计检查
9. 参考例程与工具
10. 总结
如果以上方法仍无法解决问题,建议联系 ST 官方技术支持,获取更详细的帮助。 |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 21:28 , Processed in 0.549826 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
643
