电子发烧友论坛|
下面两种调用摄像头显示图像的代码,第一种方法直接绑定摄像头到Video层可以正常流畅的显示摄像头的画面,第二种方法用Show_img方法显示画面,在画面移动的时候会有严重的画面撕裂
第一种(正常显示) import sys,uosimport timefrom media.sensor import *from media.display import *from media.media import *if __name__ == "__main__": try: sensor = Sensor(width=1270,height=960) # sensor reset sensor.reset() # set chn1 output format sensor.set_framesize(width = 640, height = 480, chn = CAM_CHN_ID_1)# sensor.set_pixformat(Sensor.RGB565, chn = CAM_CHN_ID_1) sensor.set_pixformat(PIXEL_FORMAT_YUV_SEMIPLANAR_420, chn = CAM_CHN_ID_1) sensor_bind_info = sensor.bind_info(x = 0, y = 0, chn = CAM_CHN_ID_1) Display.bind_layer(**sensor_bind_info, layer = Display.LAYER_VIDEO1) # use lcd as display output Display.init(Display.ST7701,width=640,height=480,to_ide = True) # init media manager MediaManager.init() # sensor start run sensor.run() while True: print("1")# img = sensor.snapshot(chn = CAM_CHN_ID_1)# Display.show_image(img) except KeyboardInterrupt as e: print(f"user stop") except BaseException as e: print(f"Exception '{e}'") finally: # sensor stop run if isinstance(sensor, Sensor): sensor.stop() # deinit display Display.deinit() os.exitpoint(os.EXITPOINT_ENABLE_SLEEP) time.sleep_ms(100) # release media buffer MediaManager.deinit()第二种(画面撕裂) import sys,uosimport timefrom media.sensor import *from media.display import *from media.media import *if __name__ == "__main__": try: sensor = Sensor(width=1270,height=960) # sensor reset sensor.reset() # set chn1 output format sensor.set_framesize(width = 640, height = 480, chn = CAM_CHN_ID_1) sensor.set_pixformat(Sensor.RGB565, chn = CAM_CHN_ID_1)# sensor.set_pixformat(PIXEL_FORMAT_YUV_SEMIPLANAR_420, chn = CAM_CHN_ID_1) # sensor_bind_info = sensor.bind_info(x = 0, y = 0, chn = CAM_CHN_ID_1)# Display.bind_layer(**sensor_bind_info, layer = Display.LAYER_VIDEO1) # use lcd as display output Display.init(Display.ST7701,width=640,height=480,to_ide = True) # init media manager MediaManager.init() # sensor start run sensor.run() while True:# print("1") img = sensor.snapshot(chn = CAM_CHN_ID_1) Display.show_image(img) except KeyboardInterrupt as e: print(f"user stop") except BaseException as e: print(f"Exception '{e}'") finally: # sensor stop run if isinstance(sensor, Sensor): sensor.stop() # deinit display Display.deinit() os.exitpoint(os.EXITPOINT_ENABLE_SLEEP) time.sleep_ms(100) # release media buffer MediaManager.deinit()请问这是什么原因? |
1个回答
屏幕画面出现割裂现象可能是由于多种原因导致的,包括硬件问题、软件问题、驱动问题等。在您提供的两种调用摄像头显示图像的代码中,第一种方法直接绑定摄像头到Video层可以正常流畅的显示摄像头的画面,而第二种方法用Show_img方法显示画面,在画面移动的时候会有严重的画面撕裂。这种现象可能是由于以下几个原因导致的:
1. 缓冲区管理问题:第二种方法可能没有正确管理缓冲区,导致画面数据在传输过程中出现延迟或丢失,从而引发画面撕裂现象。 2. 帧率问题:第二种方法可能没有正确设置帧率,导致画面更新速度跟不上摄像头捕获画面的速度,从而引发画面撕裂现象。 3. 线程同步问题:第二种方法可能没有正确处理线程同步问题,导致画面数据在多个线程之间传输时出现冲突,从而引发画面撕裂现象。 4. 显示设备性能问题:第二种方法可能对显示设备的性能要求较高,而您的显示设备性能不足,导致画面撕裂现象。 为了解决这个问题,您可以尝试以下方法: 1. 优化缓冲区管理:确保画面数据在传输过程中不会出现延迟或丢失。 2. 设置合适的帧率:根据摄像头捕获画面的速度,设置合适的帧率,以保证画面更新速度。 3. 处理线程同步问题:确保画面数据在多个线程之间传输时不会出现冲突。 4. 提升显示设备性能:如果可能的话,尝试升级显示设备,以满足第二种方法的性能要求。 5. 尝试使用第一种方法:如果第二种方法无法解决画面撕裂问题,您可以尝试使用第一种方法,因为它可以正常流畅地显示摄像头的画面。 |
只有小组成员才能发言,加入小组>>
AI_cube训练模型得到了npy文件,没有kmodel文件
770 浏览 0 评论
请问K230 V3.0版本烧录固件和使用IDE到底是烧录哪个啊?
735 浏览 0 评论
443浏览 4评论
AI Cube进行yolov8n模型训练,创建项目目标检测时显示数据集目录下存在除标注和图片外的其他目录如何处理?
462浏览 3评论
autodl算力云在.pt转换onnx文件时正常,但onnx转.kmodel文件时报错,为什么?
552浏览 2评论
如何在大核rtt上把kd_mpi_vicap_start_stream三个摄像头各自出的流拼成一个流呢?
164浏览 2评论
564浏览 2评论
/9
GMT+8, 2025-12-2 05:53 , Processed in 0.611793 second(s), Total 94, Slave 77 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
684
