I (0) cpu_start: App cpu up.
I (583) esp_psram: SPI SRAM memory test OK I (592) cpu_start: Pro cpu start user code I (592) cpu_start: cpu freq: 240000000 Hz I (592) cpu_start: Application information: I (595) cpu_start: Project name: chinese_tts I (601) cpu_start: App version: 1 I (605) cpu_start: Compile time: Apr 15 2024 12:54:42 I (611) cpu_start: ELF file SHA256: 9b472b7e79614053... I (617) cpu_start: ESP-IDF: v5.1.1 I (622) cpu_start: Min chip rev: v0.0 I (627) cpu_start: Max chip rev: v0.99 I (632) cpu_start: Chip rev: v0.2 I (636) heap_init: Initializing. RAM available for dynamic allocation: I (643) heap_init: At 3FC9CFC8 len 0004C748 (305 KiB): DRAM I (650) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM I (656) heap_init: At 600FE010 len 00001FD8 (7 KiB): RTCRAM I (663) esp_psram: Adding pool of 8192K of PSRAM memory to heap allocator I (671) spi_flash: detected chip: gd I (674) spi_flash: flash io: qio I (678) sleep: Configure to isolate all GPIO pins in sleep state I (685) sleep: Enable automatic switching of GPIO sleep configuration I (692) app_start: Starting scheduler on CPU0 I (697) app_start: Starting scheduler on CPU1 I (697) main_task: Started on CPU0 I (707) esp_psram: Reserving pool of 32K of internal memory for DMA/internal allocations I (717) main_task: Calling app_main() E (717) I2C_If: Fail to write to dev 80 E (727) I2C_If: Fail to write to dev 80 E (727) I2C_If: Fail to write to dev 80 E (737) I2C_If: Fail to write to dev 80 E (737) I2C_If: Fail to write to dev 80 E (737) I2C_If: Fail to write to dev 80 E (747) I2C_If: Fail to write to dev 80 E (747) I2C_If: Fail to write to dev 80 E (757) I2C_If: Fail to write to dev 80 E (757) ES7210: Write register fail E (767) ES7210: Open fail I (767) I2S_IF: channel mode 0 bits:32/32 channel:2 mask:3 I (777) I2S_IF: STD Mode 0 bits:32/32 channel:2 sample_rate:16000 mask:3 I (777) Adev_Codec: Open codec device OK E (787) I2C_If: Fail to write to dev 30 E (787) I2C_If: Fail to write to dev 30 E (797) I2C_If: Fail to write to dev 30 E (797) I2C_If: Fail to write to dev 30 E (807) I2C_If: Fail to write to dev 30 E (807) I2C_If: Fail to write to dev 30 E (817) I2C_If: Fail to write to dev 30 E (817) I2C_If: Fail to write to dev 30 E (817) I2C_If: Fail to write to dev 30 E (827) I2C_If: Fail to write to dev 30 E (827) I2C_If: Fail to write to dev 30 E (837) I2C_If: Fail to read from dev 30 I (837) ES8311: Work in Slave mode E (847) I2C_If: Fail to write to dev 30 E (847) I2C_If: Fail to write to dev 30 E (857) I2C_If: Fail to read from dev 30 E (857) I2C_If: Fail to write to dev 30 E (867) I2C_If: Fail to write to dev 30 E (867) I2C_If: Fail to write to dev 30 E (867) I2C_If: Fail to write to dev 30 E (877) I2C_If: Fail to write to dev 30 E (877) ES8311: Open fail I (887) I2S_IF: channel mode 0 bits:16/16 channel:2 mask:1 I (887) I2S_IF: STD Mode 1 bits:16/16 channel:2 sample_rate:16000 mask:1 I (897) Adev_Codec: Open codec device OK ES7210和ES8311无法连接导致扬声器和麦克风都无法正常工作 |
1个回答
根据您提供的信息,您的ESP32-S3-Korvo-2 V3.0在运行chinese_tts时遇到了I2C写入和读取失败的问题,导致没有声音。以下是一些建议来解决这个问题:
1. 检查I2C连接:确保I2C设备(例如音频放大器或语音合成器)与ESP32-S3-Korvo-2 V3.0的I2C引脚正确连接。检查线路是否有断裂或接触不良。 2. 检查I2C地址:确保您在代码中使用的I2C设备地址与实际设备的地址匹配。如果地址不正确,设备将无法正常通信。 3. 检查电源:确保I2C设备和ESP32-S3-Korvo-2 V3.0都有足够的电源。如果电源不稳定或不足,可能导致通信失败。 4. 检查I2C速率:尝试更改I2C速率,以查看是否对通信有影响。有时,过高或过低的速率可能导致通信问题。 5. 检查代码:检查您的chinese_tts代码,确保I2C写入和读取操作正确无误。如果可能,请尝试使用其他示例代码或库来测试I2C通信。 6. 更新固件:确保您的ESP32-S3-Korvo-2 V3.0运行的是最新版本的固件。有时,固件更新可能包含修复I2C通信问题的错误。 7. 使用调试工具:使用ESP-IDF的调试工具(如GDB)来调试您的代码,查找可能导致I2C通信失败的原因。 8. 检查硬件:如果以上方法都无法解决问题,可能是ESP32-S3-Korvo-2 V3.0或I2C设备的硬件问题。尝试更换设备或联系制造商寻求技术支持。 通过以上步骤,您应该能够找到并解决I2C写入和读取失败的问题,使您的chinese_tts项目正常工作。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 06:34 , Processed in 0.797317 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
665
