MacOS 按照文档的步骤进行环境的配置, esp-matter执行./install.sh的时候报错:
Downloading and installing packages into local source directory: Setting up CIPD package manager...done (11.5s) Setting up Project actions........skipped (0.1s) Setting up Python environment.....[|] ERROR at /Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_build/facade.gni:187:7: Assertion failed. assert(_dep_is_in_link_dependencies, ^----- /Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_log:impl must be listed in the pw_build_LINK_DEPS build arg when the /Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_log:pw_log facade is in use. Please update your toolchain configuration. See /Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_log/BUILD.gn:47:1: whence it was called. pw_facade("pw_log") { ^-------------------- See //src/lib/support/BUILD.gn:351:5: which caused the file to be included. "$dir_pw_log:impl", ^----------------- ['gn', 'gen', '/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out', '--args=chip_crypto="boringssl" dir_pigweed="/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo"'] Traceback (most recent call last): File "/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 402, in install_packages subprocess.check_call( File "/usr/local/Cellar/python@3.12/3.12.3/Frameworks/Python.framework/Versions/3.12/lib/python3.12/subprocess.py", line 413, in check_call raise CalledProcessError(retcode, cmd) subprocess.CalledProcessError: Command '['gn', 'gen', '/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out', '--args=chip_crypto="boringssl" dir_pigweed="/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo"']' returned non-zero exit status 1. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 995, in sys.exit(main()) ^^^^^^ File "/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 987, in main return EnvSetup(**vars(parse())).setup() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 577, in setup result = step(spin) ^^^^^^^^^^ File "/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 766, in virtualenv if not virtualenv_setup.install( ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 443, in install install_packages(gn_target) File "/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 410, in install_packages raise subprocess.CalledProcessError( subprocess.CalledProcessError: Command '['gn', 'gen', '/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out', '--args=chip_crypto="boringssl" dir_pigweed="/Users/wangxiufeng/desktop/matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo"']' returned non-zero exit status 1. 请问是什么原因导致的,谢谢大佬 |
1个回答
从您提供的错误信息来看,这个问题可能是由于在执行`./install.sh`脚本时,某些依赖包没有正确安装或者配置导致的。为了解决这个问题,您可以尝试以下步骤:
1. **确保网络连接正常**:下载依赖包需要稳定的网络连接。请检查您的网络连接是否正常。 2. **清理之前的安装**:有时候,之前的安装可能会影响新的安装。您可以尝试删除`esp-matter`目录,然后重新克隆仓库: ``` rm -rf esp-matter git clone https://github.com/espressif/esp-matter.git ``` 3. **检查磁盘空间**:确保您的MacOS系统有足够的磁盘空间来安装所需的依赖包。 4. **手动安装依赖包**:如果自动安装脚本出现问题,您可以尝试手动安装所需的依赖包。根据错误信息,可能需要安装的依赖包包括: - Python - Ninja - CIPD 您可以使用以下命令安装这些依赖包: ```bash # 安装 Python brew install python # 安装 Ninja brew install ninja # 安装 CIPD git clone https://chromium.googlesource.com/chromium/tools/depot_tools.git export PATH="$PATH:/path/to/depot_tools" ``` 5. **检查权限**:确保您有足够的权限来执行`./install.sh`脚本。如果没有,您可以尝试使用`sudo`命令: ``` sudo ./install.sh ``` 6. **查看详细错误信息**:如果问题仍然存在,您可以尝试查看更详细的错误信息。在执行脚本时,添加`-x`选项可以显示详细的执行过程: ``` ./install.sh -x ``` |
只有小组成员才能发言,加入小组>>
503浏览 6评论
416浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
399浏览 5评论
401浏览 4评论
374浏览 4评论
GMT+8, 2024-10-19 21:40 , Processed in 0.672574 second(s), Total 49, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
