电子发烧友论坛|
我克隆了 ESP-Matter 的照明应用示例https://github.com/project-chip/connect ... -app/esp32。
然后我在组件下添加了几个库并确保 CMakeLists.txt,然后运行下面的 idf.py 命令 idf.py create-manifest --component= idf.py reconfigure 但是,当我编译时出现找不到库的错误 main/include/display.hh:1:10: fatal error: SPI.h: No such file or directory #include "SPI.h" 即使是我通过“ESP-IDF:添加 Arduino ESP32 作为 ESP-IDF 组件”命令添加的 Arduino 库也无法找到并出现上述错误。我错过了什么? 这是 ESP Doctor 命令的输出 ---------------------------------------------- ESP-IDF Extension for Visual Studio Code report --------------------------------------------- OS darwin x64 22.3.0 System environment variable IDF_PYTHON_ENV_PATH System environment variable PATH System environment variable PYTHON undefined Visual Studio Code version 1.77.0 Visual Studio Code language en Visual Studio Code shell /bin/zsh ESP-IDF Extension version 1.6.1 Workspace folder ---------------------------------------------------- Extension configuration settings ------------------------------------------------------ ESP-ADF Path (idf.espAdfPath) ${env:ADF_PATH} ESP-IDF Path (idf.espIdfPath) ESP-MDF Path (idf.espMdfPath) ${env:MDF_PATH} ESP-Matter Path (idf.espMatterPath) ${env:ESP_MATTER_PATH} Custom extra paths (idf.customExtraPaths) Custom extra vars (idf.customExtraVars) OPENOCD_SCRIPTS: Virtual env Python Path (idf.pythonBinPath) Serial port (idf.port) /dev/cu.usbserial-01D18139 OpenOCD Configs (idf.openOcdConfigs) interface/ftdi/esp32_devkitj_v1.cfg,board/esp32-wrover.cfg ESP-IDF Tools Path (idf.toolsPath) Git Path (idf.gitPath) /usr/bin/git -------------------------------------------------------- Configurations access ------------------------------------------------------------- Access to ESP-ADF Path (idf.espAdfPath) false Access to ESP-IDF Path (idf.espIdfPath) true Access to ESP-MDF Path (idf.espMdfPath) false Access to ESP-Matter Path (idf.espMatterPath) false Access to ESP-IDF Custom extra paths Access to Access to Access to Access to Access to Access to Access to Access to Access to Virtual env Python Path (idf.pythonBinPath) true Access to CMake in environment PATH true Access to Ninja in environment PATH true Access to ESP-IDF Tools Path (idf.toolsPath) true -------------------------------------------------------- Configurations has spaces ------------------------------------------------------------- Spaces in system environment Path false Spaces in ESP-ADF Path (idf.espAdfPath) false Spaces in ESP-IDF Path (idf.espIdfPath) false Spaces in ESP-MDF Path (idf.espMdfPath) false Spaces in ESP-Matter Path (idf.espMatterPath) false Spaces in ESP-IDF Custom extra paths Spaces in Spaces in Spaces in Spaces in Spaces in Spaces in Spaces in Spaces in Spaces in Virtual env Python Path (idf.pythonBinPath) false Spaces in ESP-IDF Tools Path (idf.toolsPath) false ----------------------------------------------------------- Executables Versions ----------------------------------------------------------- Git version 2.39.2 ESP-IDF version 4.4.2 Python version 3.7.3 Python's pip version 23.0.1 -------------------------------------------------- Project configuration settings ---------------------------------------------------------- -------------------------------------------------- Python packages in idf.pythonBinPath ---------------------------------------------------- bitstring version: 4.0.1 Brotli version: 1.0.9 CacheControl version: 0.12.11 certifi version: 2022.12.7 cffi version: 1.15.1 charset-normalizer version: 3.0.1 click version: 8.0.4 colorama version: 0.4.6 construct version: 2.10.54 contextlib2 version: 21.6.0 cryptography version: 39.0.1 ecdsa version: 0.18.0 Flask version: 0.12.5 Flask-Compress version: 1.13 Flask-SocketIO version: 2.9.6 future version: 0.18.2 gcovr version: 6.0 gdbgui version: 0.13.2.0 gevent version: 1.5.0 greenlet version: 2.0.2 idf-component-manager version: 1.2.2 idna version: 3.4 importlib-metadata version: 6.0.0 itsdangerous version: 2.0.1 Jinja2 version: 3.0.1 kconfiglib version: 13.7.1 lark version: 1.1.2 lockfile version: 0.12.2 lxml version: 4.9.2 MarkupSafe version: 2.1.2 msgpack version: 1.0.4 packaging version: 23.0 pip version: 23.0.1 psutil version: 5.9.4 pycparser version: 2.21 pyelftools version: 0.29 pygdbmi version: 0.9.0.2 Pygments version: 2.14.0 pyparsing version: 2.3.1 pyserial version: 3.5 python-engineio version: 3.14.2 python-socketio version: 4.6.1 PyYAML version: 6.0 reedsolo version: 1.5.4 requests version: 2.28.2 requests-file version: 1.5.1 requests-toolbelt version: 0.10.1 schema version: 0.7.5 setuptools version: 67.6.1 six version: 1.16.0 stringcase version: 1.2.0 tqdm version: 4.64.1 typing_extensions version: 4.5.0 urllib3 version: 1.26.14 websocket-client version: 1.5.1 Werkzeug version: 0.16.1 wheel version: 0.38.4 xmlrunner version: 1.7.7 zipp version: 3.14.0 ---------------------------------------------------- Check ESP-IDF python requirements.txt ------------------------------------------------- Check ESP-IDF Python packages Python requirements from ---------------------------------------------------- Check extension requirements.txt ------------------------------------------------------ Check Extension Python packages Python requirements from ---------------------------------------------------- Check ESP-IDF debug adapter requirements.txt ------------------------------------------ Check Debug AdapterPython packages Python requirements from ----------------------------------------------------------- Latest error ----------------------------------------------------------------- Latest error at Unknown error in ESP-IDF doctor command -------------------------------------------------------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1208浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-2 01:21 , Processed in 0.692055 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
381
