在搭建好esp-matter后,编译light sample的时候报错
rck@ubuntu:~/ESP/esp-matter/examples/light$ idf.py build /home/rck/ESP/esp-idf/tools/check_python_dependencies.py:12: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html import pkg_resources Executing action: all (aliases: build) Running ninja in directory /home/rck/ESP/esp-matter/examples/light/build Executing "ninja all"... [1/1] cd /home/rck/ESP/esp-matter/examples/light/bu...tter/examples/light/build/bootloader/bootloader.binBootloader binary size 0x4ee0 bytes. 0x7120 bytes (59%) free. [20/225] Performing build step for 'chip_gn'FAILED: esp-idf/chip/chip_gn-prefix/src/chip_gn-stamp/chip_gn-build esp-idf/chip/lib/libCHIP.a cd /home/rck/ESP/esp-matter/examples/light/build/esp-idf/chip && ninja esp32 [16/740] ACTION //third_party/connectedhomeip/src/c...party/connectedhomeip/config/esp32/toolchain:esp32)FAILED: gen/third_party/connectedhomeip/src/controller/data_model/app/PluginApplicationCallbacks.h gen/third_party/connectedhomeip/src/controller/data_model/app/callback-stub.cpp python ../../../../../connectedhomeip/connectedhomeip/config/esp32/third_party/connectedhomeip/third_party/pigweed/repo/pw_build/py/pw_build/python_runner.py --gn-root ../../../../../connectedhomeip/connectedhomeip/config/esp32/ --current-path ../../../../../connectedhomeip/connectedhomeip/config/esp32/third_party/connectedhomeip/src/controller/data_model --default-toolchain=//third_party/connectedhomeip/config/esp32/toolchain:esp32 --current-toolchain=//third_party/connectedhomeip/config/esp32/toolchain:esp32 --capture-output --python-dep-list-files gen/third_party/connectedhomeip/src/controller/data_model/data_model_codegen_codegen_metadata_path_list.txt -- ../../../../../connectedhomeip/connectedhomeip/config/esp32/third_party/connectedhomeip/scripts/codegen.py --generator cpp-app --output-dir gen/third_party/connectedhomeip/src/controller/data_model --expected-outputs gen/third_party/connectedhomeip/src/controller/data_model/data_model_codegen.expected.outputs ../../../../../connectedhomeip/connectedhomeip/config/esp32/third_party/connectedhomeip/src/controller/data_model/controller-clusters.matter Traceback (most recent call last): File "../../../../../connectedhomeip/connectedhomeip/config/esp32/third_party/connectedhomeip/scripts/codegen.py", line 28, in from matter_idl.matter_idl_parser import CreateParser ModuleNotFoundError: No module named 'matter_idl' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "../../../../../connectedhomeip/connectedhomeip/config/esp32/third_party/connectedhomeip/scripts/codegen.py", line 32, in from matter_idl.matter_idl_parser import CreateParser File "/home/rck/ESP/esp-matter/connectedhomeip/connectedhomeip/config/esp32/third_party/connectedhomeip/scripts/py_matter_idl/matter_idl/matter_idl_parser.py", line 9, in from lark import Lark ModuleNotFoundError: No module named 'lark' [18/740] ACTION //third_party/connectedhomeip/src/l...party/connectedhomeip/config/esp32/toolchain:esp32)ninja: build stopped: subcommand failed. [22/225] Building C object esp-idf/fatfs/CMakeFiles/__idf_fatfs.dir/src/ffunicode.c.objninja: build stopped: subcommand failed. ninja failed with exit code 1, output of the command is in the /home/rck/ESP/esp-matter/examples/light/build/log/idf_py_stderr_output_48287 and /home/rck/ESP/esp-matter/examples/light/build/log/idf_py_stdout_output_48287 |
2个回答
ModuleNotFoundError: No module named 'matter_idl' 根据提示,是这些 python 包没有正确安装,安装后再尝试编译。 |
根据您提供的错误信息,这个问题主要是由于`pkg_resources`模块已经被弃用。为了解决这个问题,请按照以下步骤操作:
1. 首先,确保您已经安装了正确版本的Python。ESP-IDF推荐使用Python 3.7。如果您的Python版本不是3.7,请考虑升级或创建一个虚拟环境来安装Python 3.7。 2. 更新`setuptools`和`wheel`包。这两个包是Python包管理的一部分,更新它们可能会解决一些问题。在终端中运行以下命令: ``` pip install --upgrade setuptools wheel ``` 3. 如果问题仍然存在,您可以尝试删除`~/.espressif`目录下的`tools`文件夹。这个文件夹包含了ESP-IDF的一些辅助工具,删除它们后,当您下次运行`idf.py`命令时,它们将被重新下载。在终端中运行以下命令: ``` rm -rf ~/.espressif/tools ``` 4. 重新运行`idf.py build`命令,看看问题是否得到解决。 ``` cd ~/ESP/esp-matter/examples/light idf.py build ``` |
只有小组成员才能发言,加入小组>>
933 浏览 0 评论
1653 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1284 浏览 1 评论
1218 浏览 1 评论
4959 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1249浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2329浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2524浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 17:16 , Processed in 0.735805 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
380
