esp-idf branch: release/v4.3 commit:06ce378142f91b90f6c0673fa9363e526664eada
example: bluetooth/bluedroid/ble/gatt_client 我的修改: 在esp_gap_cb中ESP_GAP_BLE_SCAN_START_COMPLETE_EVT事件 添加了resp adv中解析蓝牙设备名称的代码,其他无改动Code: Select all case ESP_GAP_BLE_SCAN_RESULT_EVT: { esp_ble_gap_cb_param_t *scan_result = (esp_ble_gap_cb_param_t *)param; switch (scan_result->scan_rst.search_evt) { case ESP_GAP_SEARCH_INQ_RES_EVT: ESP_LOGI(GATTC_TAG, "----------Device Found-----mac addr-----"); esp_log_buffer_hex(GATTC_TAG, scan_result->scan_rst.bda, 6); ESP_LOGI(GATTC_TAG, "searched Adv Data Len %d, Scan Response Len %d", scan_result->scan_rst.adv_data_len, scan_result->scan_rst.scan_rsp_len); adv_name = esp_ble_resolve_adv_data(scan_result->scan_rst.ble_adv, ESP_BLE_AD_TYPE_NAME_CMPL, &adv_name_len); ESP_LOGI(GATTC_TAG, "searched Device Name Len %d", adv_name_len); ESP_LOGI(GATTC_TAG, "ble name:"); esp_log_buffer_char(GATTC_TAG, adv_name, adv_name_len);#if CONFIG_EXAMPLE_DUMP_ADV_DATA_AND_SCAN_RESP if (scan_result->scan_rst.adv_data_len > 0) { ESP_LOGI(GATTC_TAG, "adv data:"); esp_log_buffer_hex(GATTC_TAG, &scan_result->scan_rst.ble_adv[0], scan_result->scan_rst.adv_data_len); } if (scan_result->scan_rst.scan_rsp_len > 0) { ESP_LOGI(GATTC_TAG, "scan resp:"); esp_log_buffer_hex(GATTC_TAG, &scan_result->scan_rst.ble_adv[scan_result->scan_rst.adv_data_len], scan_result->scan_rst.scan_rsp_len); /* add by aaa*/ adv_name = esp_ble_resolve_adv_data(&scan_result->scan_rst.ble_adv[scan_result->scan_rst.adv_data_len], ESP_BLE_AD_TYPE_NAME_CMPL, &adv_name_len); ESP_LOGI(GATTC_TAG, "11searched Device Name Len %d", adv_name_len); ESP_LOGI(GATTC_TAG, "11ble name:"); esp_log_buffer_char(GATTC_TAG, adv_name, adv_name_len); /* end add by aaa*/ }#endif ESP_LOGI(GATTC_TAG, "n"); if (adv_name != NULL) { if (strlen(remote_device_name) == adv_name_len && strncmp((char *)adv_name, remote_device_name, adv_name_len) == 0) { ESP_LOGI(GATTC_TAG, "searched device %sn", remote_device_name); if (connect == false) { connect = true; ESP_LOGI(GATTC_TAG, "connect to the remote device.1n"); uint8_t ret = esp_ble_gap_stop_scanning(); ESP_LOGI(GATTC_TAG, "esp_ble_gap_stop_scanning ret = %dn",ret); //esp_ble_gattc_open(gl_profile_tab[PROFILE_A_APP_ID].gattc_if, scan_result->scan_rst.bda, scan_result->scan_rst.ble_addr_type, true); } } } ESP_LOGI(GATTC_TAG, "vz end ESP_GAP_BLE_SCAN_RESULT_EVTn"); break; |
1个回答
在ESP-IDF中,使用Bluedroid的GATT客户端时,如果遇到`esp_ble_gap_stop_scanning`接口不返回,可能是由以下原因导致的:
1. **任务调度问题**:ESP-IDF是基于FreeRTOS的,如果在调用`esp_ble_gap_stop_scanning`时,当前任务没有足够的优先级或者CPU时间,可能会导致该接口无法及时返回。 2. **回调函数阻塞**:如果在`ESP_GAP_BLE_SCAN_START_COMPLETE_EVT`事件的回调函数中添加了解析蓝牙设备名称的代码,如果这部分代码执行时间过长,可能会导致整个扫描停止的过程被阻塞。 3. **ESP-IDF版本问题**:你提到的ESP-IDF版本是`release/v4.3`,这个版本可能存在一些已知或未知的bug,导致`esp_ble_gap_stop_scanning`接口无法正常返回。 为了解决这个问题,你可以尝试以下方法: 1. **优化回调函数**:检查`ESP_GAP_BLE_SCAN_START_COMPLETE_EVT`事件的回调函数,确保解析蓝牙设备名称的代码不会阻塞太长时间。如果可能,将这部分代码移动到另一个任务中执行。 2. **调整任务优先级**:检查当前任务的优先级,确保它足够高,以便在调用`esp_ble_gap_stop_scanning`时能够及时获得CPU时间。 3. **更新ESP-IDF版本**:尝试升级到较新的ESP-IDF版本,例如`release/v4.4`,看看问题是否得到解决。 4. **检查代码逻辑**:仔细检查你的代码逻辑,确保没有其他潜在的问题导致`esp_ble_gap_stop_scanning`接口无法返回。 5. **查看日志**:使用ESP-IDF的日志系统,查看在调用`esp_ble_gap_stop_scanning`时是否有任何错误或警告信息,这可能会帮助你找到问题的原因。 |
只有小组成员才能发言,加入小组>>
470 浏览 0 评论
991 浏览 0 评论
1709 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1368 浏览 1 评论
1254 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1288浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2386浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2575浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-13 20:48 , Processed in 0.704434 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
416
