环境:window11 vscode
版本库:v5.0-rc1*
问题:在编译usb的tusb_hid例程时,出现了下面的问题,请问需要怎么解决?
- PS C:Users15119espscannertusb_hid> idf.py menuconfig
- Executing action: menuconfig
- Running cmake in directory c:users15119espscannertusb_hidbuild
- Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DCCACHE_ENABLE=1 c:users15119espscannertusb_hid"...
- -- Found Git: C:/Users/15119/.espressif/tools/idf-git/2.30.1/cmd/git.exe (found version "2.30.1.windows.1")
- -- ccache will be used for faster recompilation
- -- The C compiler identification is GNU 11.2.0
- -- The CXX compiler identification is GNU 11.2.0
- -- The ASM compiler identification is GNU
- -- Found assembler: C:/Users/15119/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe
- -- Detecting C compiler ABI info
- -- Detecting C compiler ABI info - done
- -- Check for working C compiler: C:/Users/15119/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped
- -- Detecting C compile features
- -- Detecting C compile features - done
- -- Detecting CXX compiler ABI info
- -- Detecting CXX compiler ABI info - done
- -- Check for working CXX compiler: C:/Users/15119/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped
- -- Detecting CXX compile features
- -- Detecting CXX compile features - done
- -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
- -- Building ESP-IDF components for target esp32s3
- Solving dependencies requirements
- Updating lock file at C:/Users/15119/esp/scanner/tusb_hiddependencies.lock
- Processing 2 dependencies:
- [1/2] espressif/esp_tinyusb (0.0.1)
- CMake Error at C:/Users/15119/esp/esp-idf/tools/cmake/build.cmake:519 (message):
- Traceback (most recent call last):
- File "runpy.py", line 194, in _run_module_as_main
- File "runpy.py", line 87, in _run_code
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_managerprepare_components__main__.py", line 3, in
- main()
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_managerprepare_componentsprepare.py", line 126, in main
- args.func(args)
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_managerprepare_componentsprepare.py", line 39, in prepare_dep_dirs
- ComponentManager(args.project_dir).prepare_dep_dirs(
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_managercore.py", line 404, in prepare_dep_dirs
- downloaded_component_paths = download_project_dependencies(
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_managerdependencies.py", line 128, in download_project_dependencies
- download_paths = fetcher.download()
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_toolssourcesfetcher.py", line 51, in download
- return self.source.download(self.component, self.managed_path)
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_toolssourcesweb_service.py", line 173, in download
- unpack_archive(file_path, self.component_cache_path(component))
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_toolsarchive_tools.py", line 100, in unpack_archive
- handler(file, destination_directory)
- File "C:Users15119.espressifpython_envidf5.0_py3.8_envlibsite-packagesidf_component_toolsarchive_tools.py", line 76, in unpack_tar
- tar.extractall(destination_directory)
- File "tarfile.py", line 2028, in extractall
- File "tarfile.py", line 2069, in extract
- File "tarfile.py", line 2141, in _extract_member
- File "tarfile.py", line 2182, in makefile
- FileNotFoundError: [Errno 2] No such file or directory:
- 'C:\Users\15119\AppData\Local\Espressif\ComponentManager\Cache\service_74cc6623\espressif__esp_tinyusb_0.0.1_4fa75cb0739eddaf6aca1b57c4796387062f82eeb08435540792438beeb3316c\test\vendor\ceedling\docs\UnityAssertionsCheatSheetSuitableforPrintingandPossiblyFraming.pdf'
- Call Stack (most recent call first):
- C:/Users/15119/esp/esp-idf/tools/cmake/project.cmake:440 (idf_build_process)
- CMakeLists.txt:8 (project)
- -- Configuring incomplete, errors occurred!
- See also "C:/Users/15119/esp/scanner/tusb_hid/build/CMakeFiles/CMakeOutput.log".
- cmake failed with exit code 1
之后我尝试把idf_component.yml中的esp_tinyusb版本改为1.1.0之后,再编译,又出现了新的问题。
- ## IDF Component Manager Manifest File
- dependencies:
- espressif/esp_tinyusb: "1.1.0"
- idf: "^5.0"
- FileNotFoundError: [WinError 206] 文件名或扩展名太长。:
- 'C:\Users\15119\AppData\Local\Espressif\ComponentManager\Cache\service_74cc6623\espressif__tinyusb_0.14.2_820a2eef39c7ff0b810e859efd7035a4e5b9b44e77c49020a50ef0668fc941ae\test\unit-test\vendor\ceedling\plugins\fake_function_framework\examples\fff_example'
- -- Configuring incomplete, errors occurred!See also "C:/Users/15119/esp/scanner/tusb_hid/build/CMakeFiles/CMakeOutput.log".
1个回答
