-- Project sdkconfig file C:/Users/neill/OneDrive/桌面/test2/blink/sdkconfig
Traceback (most recent call last): File "C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/prepare_kconfig_files.py", line 102, in main() File "C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/prepare_kconfig_files.py", line 94, in main env.update(json.load(args.env_file)) File "json__init__.py", line 293, in load UnicodeDecodeError: 'cp950' codec can't decode byte 0x8c in position 4121: illegal multibyte sequence Traceback (most recent call last): File "C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/confgen.py", line 607, in main() File "C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/confgen.py", line 255, in main env = json.load(args.env_file) File "json__init__.py", line 293, in load UnicodeDecodeError: 'cp950' codec can't decode byte 0x8c in position 4121: illegal multibyte sequence CMake Error at C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/cmake/kconfig.cmake:176 (message): Failed to run confgen.py (c:/Espressif/python_env/idf5.0_py3.8_env/Scripts/python.exe;C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/confgen.py;--list-separator=semicolon;--kconfig;C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/Kconfig;--sdkconfig-rename;C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/sdkconfig.rename;--config;C:/Users/neill/OneDrive/桌面/test2/blink/sdkconfig;--env-file;C:/Users/neill/OneDrive/桌面/test2/blink/build/config.env). Error 1 Call Stack (most recent call first): C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/cmake/build.cmake:590 (__kconfig_generate_config) C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/cmake/project.cmake:440 (idf_build_process) CMakeLists.txt:6 (project) -- Configuring incomplete, errors occurred! See also "C:/Users/neill/OneDrive/桌面/test2/blink/build/CMakeFiles/CMakeOutput.log". 5.0新版本ESP_IDF 全部都顯示正確安裝後,編譯例程後,會顯示 UnicodeDecodeError: 'cp950' codec can't decode byte 0x8c in position 4121: illegal multibyte sequence 在其他電腦的4.4.3版本下沒有這個問題 有人知道解答嗎? |
只有小组成员才能发言,加入小组>>
453 浏览 0 评论
975 浏览 0 评论
1700 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1357 浏览 1 评论
1248 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1272浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
939浏览 3评论
2371浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2556浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1066浏览 2评论
/9
GMT+8, 2025-12-9 07:18 , Processed in 0.634049 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
453
