使用vscode创建I2S_es7210_tdm的例程,在选择芯片时弹出如下错误,且导致工程无法正常编译;
[Error: non zero exit code 2 Adding "set-target"'s dependency "fullclean" to list of commands with default set of options. Executing action: fullclean Executing action: set-target Set Target to: esp32s3, new sdkconfig will be created. Running cmake in directory E:Projecti2s_es7210_tdmbuild Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=e:EnvESP.espressifpython_envidf5.2_py3.11_envScriptspython.exe -DESP_PLATFORM=1 -DIDF_TARGET=esp32s3 -DCCACHE_ENABLE=0 E:Projecti2s_es7210_tdm"... -- Existing sdkconfig 'E:/Project/i2s_es7210_tdm/sdkconfig' renamed to 'E:/Project/i2s_es7210_tdm/sdkconfig.old'. -- Found Git: E:/Env/ESP/.espressif/tools/idf-git/2.39.2/cmd/git.exe (found version "2.39.2.windows.1") -- The C compiler identification is GNU 13.2.0 -- The CXX compiler identification is GNU 13.2.0 -- The ASM compiler identification is GNU -- Found assembler: E:/Env/ESP/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32s3-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: E:/Env/ESP/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: E:/Env/ESP/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- git rev-parse returned 'fatal: not a git repository (or any of the parent directories): .git' -- Could not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32s3 Processing 2 dependencies: [1/2] espressif/es7210 (1.0.1) [2/2] idf (5.2.1) CMake Error at build/component_requires.temp.cmake:317 (__component_set_property): Syntax error in cmake code at E:/Project/i2s_es7210_tdm/build/component_requires.temp.cmake:317 when parsing string e:EnvESPv5.2.1esp-idf/examples/peripherals/i2s/common Invalid character escape 'E'. Call Stack (most recent call first): E:/Env/ESP/v5.2.1/esp-idf/tools/cmake/component.cmake:254 (include) E:/Env/ESP/v5.2.1/esp-idf/tools/cmake/build.cmake:578 (__component_get_requirements) E:/Env/ESP/v5.2.1/esp-idf/tools/cmake/project.cmake:605 (idf_build_process) CMakeLists.txt:6 (project) -- Configuring incomplete, errors occurred! See also "E:/Project/i2s_es7210_tdm/build/CMakeFiles/CMakeOutput.log". cmake failed with exit code 1, output of the command is in the E:Projecti2s_es7210_tdmbuildlogidf_py_stderr_output_15452 and E:Projecti2s_es7210_tdmbuildlogidf_py_stdout_output_15452 at ChildProcess. (distextension.js:2:1394091) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)] |
1个回答
根据您提供的错误信息,这个问题可能是由于以下几个原因导致的:
1. **芯片选择错误**:确保您在创建项目时选择了正确的芯片型号。在您的错误信息中,目标芯片被设置为 "esp32s3",但您的项目可能是针对其他型号的芯片。请检查您的项目设置,确保选择了正确的芯片型号。 2. **配置文件问题**:错误信息中提到 "new sdkconfig will be created",这可能意味着配置文件(sdkconfig)没有正确生成或存在问题。您可以尝试手动创建或更新配置文件,然后重新编译项目。 3. **CMake问题**:错误信息中提到 "Running cmake in directory E:Projecti2s_es7210_tdmbuild",这表明CMake可能没有正确执行。请确保您的CMake工具链文件(toolchain file)正确设置,并且与您的项目和芯片型号兼容。 4. **环境问题**:确保您的开发环境(如Python、CMake、ESPRESSIF-IDF等)已正确安装并配置。检查环境变量和路径设置,确保所有必要的工具和库都已正确安装。 5. **权限问题**:在某些情况下,权限问题可能导致编译失败。请确保您有足够的权限访问项目文件夹和相关文件。 解决步骤: 1. **检查芯片型号**:确保您选择了正确的芯片型号。 2. **检查配置文件**:手动创建或更新配置文件(sdkconfig),然后重新编译项目。 3. **检查CMake设置**:确保CMake工具链文件正确设置,并与您的项目和芯片型号兼容。 4. **检查开发环境**:确保所有必要的工具和库都已正确安装。 5. **检查权限**:确保您有足够的权限访问项目文件夹和相关文件。 6. **清理项目**:尝试清理项目(例如,删除build文件夹),然后重新编译。 7. **查看详细日志**:如果问题仍然存在,请查看更详细的编译日志,以便找到具体的错误信息和解决方案。 希望这些建议能帮助您解决问题。如果问题仍然存在,请提供更多详细信息,以便我们能更好地帮助您。 |
只有小组成员才能发言,加入小组>>
468 浏览 0 评论
984 浏览 0 评论
1707 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1364 浏览 1 评论
1253 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1286浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2378浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2565浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-12 07:20 , Processed in 2.573657 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1724
