在测试STM32F302RB的ADC功能的时候遇到了问题: 用tiM15 更新事件作为 TRGO源 触发ADC2转换,DMA2_Channel_1 连续模式传输ADC2的数据,开DMA2_TC1中断,发现只进一次TC中断后就再也不进TC1中断了。 通过后续测试发现如果只用TIM15触发ADC转换,不开DMA 正常, 如果不用TIM15,用软件触发ADC转换,开DMA,正常 。 同时 用TIM15触发ADC、开DMA则出问题。
ADC初始化如下: ADC_DeInit(ADC2); RCC_ADCCLKConfig(RCC_ADC12PLLCLK_Div6); //72M/6=12M ADC_StructInit( ADC_InitStructure); ADC_VoltageRegulatorCmd(ADC2, ENABLE); delay_us(10); ADC_SelectCalibrationMode(ADC2, ADC_CalibrationMode_Single); ADC_StartCalibration(ADC2); while(ADC_GetCalibrationStatus(ADC2) != RESET ); calibration_value = ADC_GetCalibrationValue(ADC2); ADC_CommonInitStructure.ADC_Mode=ADC_Mode_Independent; ADC_CommonInitStructure.ADC_Clock=ADC_Clock_AsynClkMode;//ADC_Clock_SynClkModeDiv4; //ʹÓÃͬ²½Ê±ÖÓ ADC_CommonInitStructure.ADC_DMAAccessMode=ADC_DMAAccessMode_1; //12/10bitDMAģʽʹÄÜ ADC_CommonInitStructure.ADC_DMAMode=ADC_DMAMode_Circular; //Á¬Ðøģʽ ADC_CommonInitStructure.ADC_TwoSamplingDelay=0; //Á½´Î²ÉÑùÑÓʱ ADC_CommonInit(ADC2, ADC_CommonInitStructure); ADC_InitStructure.ADC_ContinuousConvMode=ADC_ContinuousConvMode_Disable;//ADC_ContinuousConvMode_Enable;; ADC_InitStructure.ADC_AutoInjMode=ADC_AutoInjec_Disable; ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right; ADC_InitStructure.ADC_ExternalTrigConvEvent = ADC_ExternalTrigConvEvent_14;//ADC_ExternalTrigConvEvent_0;//ADC_ExternalTrigConvEvent_0; ADC_InitStructure.ADC_ExternalTrigEventEdge=ADC_ExternalTrigEventEdge_RisingEdge;//ADC_ExternalTrigEventEdge_None; ADC_InitStructure.ADC_NbrOfRegChannel=2; ADC_InitStructure.ADC_OverrunMode=ADC_OverrunMode_Disable; ADC_InitStructure.ADC_Resolution=ADC_Resolution_12b; ADC_Init(ADC2, ADC_InitStructure); ADC_RegularChannelConfig(ADC2, ADC_Channel_5, 1, ADC_SampleTime_4Cycles5); ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 2, ADC_SampleTime_4Cycles5); DMA_DeInit(DMA2_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)( ADC2->DR); DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADCBuffer; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //´ÓÍâÉè¶Á DMA_InitStructure.DMA_BufferSize = 2; //16 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //Á¬Ðø´«Êä DMA_InitStructure.DMA_Priority = DMA_Priority_Low; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA2_Channel1, DMA_InitStructure); DMA_ITConfig(DMA2_Channel1,DMA2_IT_TC1,ENABLE); NVIC_InitStructure.NVIC_IRQChannel=DMA2_Channel1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1; NVIC_InitStructure.NVIC_IRQChannelSubPriority=1; NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE; NVIC_Init( NVIC_InitStructure); ADC_ITConfig(ADC2,ADC_IT_EOC,ENABLE); NVIC_InitStructure.NVIC_IRQChannel=ADC1_2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0; NVIC_InitStructure.NVIC_IRQChannelSubPriority=0; NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE; NVIC_Init( NVIC_InitStructure); DMA_Cmd(DMA2_Channel1, ENABLE); ADC_DMACmd(ADC2, ENABLE); ADC_Cmd(ADC2, ENABLE); while(!ADC_GetFlagStatus(ADC2, ADC_FLAG_RDY)); ADC_StartConversion(ADC2); 中断如下: void DMA2_Channel1_IRQHandler(void) { if(DMA_GetITStatus(DMA2_IT_TC1) != RESET) { DMA_ClearITPendingBit(DMA2_IT_TC1); } } TIM15初始化如下: TIM_DeInit(TIM15); RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM15, ENABLE );//TIM1ʱÖÓʹÄÜ PrescalerValue = (uint16_t)( 7200 )- 1; //Fcnt=1M TIM_TimeBaseStructure.TIM_Period = 10000; // 500usת»»Ò»´Î TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_RepetitionCounter=0; TIM_TimeBaseInit(TIM15, TIM_TimeBaseStructure); TIM_PrescalerConfig(TIM15, PrescalerValue, TIM_PSCReloadMode_Immediate); TIM_SelectOutputTrigger(TIM15,TIM_TRGOSource_Update); TIM_ITConfig(TIM15,TIM_IT_Update, ENABLE); NVIC_InitStructure.NVIC_IRQChannel = TIM1_BRK_TIM15_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init( NVIC_InitStructure); TIM_Cmd(TIM15, ENABLE); 我是使用TIM15 更新作为TRGO事件触发ADC2转换, TIM15 1秒钟更新一次,开 ADC EOC中断的debug的时候 是1秒钟进一次中断,然后使能DMA后就并开DMA中断后就只进一次中断了, 后续我又测试500ms软件触发一次ADC转换,并且开DMA,DMA中断符合预期结果。 然后我同时使用TIM15,DMA则 只进一次DMA中断。 我后续又修改了DMA_BUF_SIZE 改成8,以此来排除ADC初始化的那一次软件使能ADC转换, 就是要发生8次 ADC->EOC 才算一次 DMA_TC,结果还是只有一次DMA中断。 |
1个回答
根据您提供的信息,您在使用STM32F302RB的ADC功能时遇到了问题。您尝试使用TIM15更新事件作为TRGO源触发ADC2转换,并通过DMA2_Channel_1连续模式传输ADC2的数据。但是,您发现在开DMA2_TC1中断后,只进入了一次TC中断,之后就不再进入TC1中断了。您还提到,如果只用TIM15触发ADC转换而不开启DMA,或者不使用TIM15而使用软件触发ADC转换并开启DMA,这两种情况下都是正常的。
为了解决这个问题,我们可以按照以下步骤进行排查: 1. 确保TIM15和ADC2的时钟已经正确配置。检查RCC_ADCCLKConfig和RCC_APB2PeriphClockCmd函数的设置。 2. 检查TIM15的配置,确保更新事件能够正确触发ADC2转换。这包括设置TIM15的时钟源、预分频器、自动重载寄存器等。 3. 检查ADC2的配置,确保它能够正确响应TIM15的触发信号。这包括设置ADC2的触发源为外部事件(TIM15更新事件),以及配置ADC2的采样时间和分辨率等。 4. 检查DMA2_Channel_1的配置,确保它能够正确地从ADC2读取数据并传输到目标内存地址。这包括设置DMA的源地址、目标地址、数据宽度、传输方向等。 5. 检查DMA2_TC1中断的配置,确保中断能够正确触发。这包括设置DMA的中断优先级、中断使能等。 6. 在中断服务程序中,检查是否有任何可能导致中断退出的条件。例如,确保在中断服务程序中没有错误地禁用了DMA或ADC。 7. 使用调试器或仿真器逐步执行代码,观察TIM15、ADC2和DMA2_Channel_1的状态,以便找到可能的问题所在。 8. 如果以上步骤都无法解决问题,可以尝试查阅STM32F302的参考手册,看看是否有关于TIM15触发ADC转换和DMA传输的特定注意事项或限制。 通过以上步骤,您应该能够找到导致问题的原因,并采取相应的措施解决。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1754 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1613 浏览 1 评论
1053 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
721 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1667 浏览 2 评论
1931浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
716浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
562浏览 3评论
587浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
546浏览 3评论
GMT+8, 2024-12-19 15:39 , Processed in 0.778677 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
