uint8_t txbuf[1000]="helloworldrn";
uint8_t rxbuf[1000]=""; ART_HandleTypeDef huart1; HAL_UART_Receive_DMA( huart1,rxbuf,sizeof(rxbuf)); 函数原型如下: /** * @brief Receives an amount of data in non blocking mode. * @param huart: pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @param pData: Pointer to data buffer * @param Size: Amount of data to be received * @note When the UART parity is enabled (PCE = 1) the data received contain the parity bit. * @retval HAL status */ HAL_StatusTypeDef HAL_UART_Receive_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size) { uint32_t *tmp; uint32_t tmp1 = 0; tmp1 = huart->State; if((tmp1 == HAL_UART_STATE_READY) || (tmp1 == HAL_UART_STATE_BUSY_TX)) { if((pData == NULL ) || (Size == 0)) { return HAL_ERROR; } /* Process Locked */ __HAL_LOCK(huart); huart->pRxBuffPtr = pData; huart->RxXferSize = Size; huart->ErrorCode = HAL_UART_ERROR_NONE; /* Check if a transmit process is ongoing or not */ if(huart->State == HAL_UART_STATE_BUSY_TX) { huart->State = HAL_UART_STATE_BUSY_TX_RX; } else { huart->State = HAL_UART_STATE_BUSY_RX; } /* Set the UART DMA transfer complete callback */ huart->hdmarx->XferCpltCallback = UART_DMAReceiveCplt; /* Set the UART DMA Half transfer complete callback */ huart->hdmarx->XferHalfCpltCallback = UART_DMARxHalfCplt; /* Set the DMA error callback */ huart->hdmarx->XferErrorCallback = UART_DMAError; /* Enable the DMA Stream */ tmp = (uint32_t*) pData; HAL_DMA_Start_IT(huart->hdmarx, (uint32_t) huart->Instance->DR, *(uint32_t*)tmp, Size); /* Enable the DMA transfer for the receiver request by setting the DMAR bit in the UART CR3 register */ huart->Instance->CR3 |= USART_CR3_DMAR; /* Process Unlocked */ __HAL_UNLOCK(huart); return HAL_OK; } else { return HAL_BUSY; } } |
1个回答
如果串口接收频率不高,不是可以使用串口自带的空中断,如果连续接收的,那就DMA收定长的数据,然后做好协议,拼接。
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1810 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1631 浏览 1 评论
1098 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
737 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1687 浏览 2 评论
1944浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
748浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
583浏览 3评论
604浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
565浏览 3评论
GMT+8, 2024-12-29 05:57 , Processed in 1.174069 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
