电子发烧友论坛|
如果用STM8S的一个IO口检测一个脉冲电平,用在电话机上面,比方说是GPIO3用来检测脉冲电平变化后,MCU将接通电话的GPIO1置高,接通电话。当挂断电话后,GPIO3脉冲再次变化,GPIO1置低,电话挂断。那我的做法是用tiM1的中断检测脉冲,但是当脉冲再次变化时我该怎么做?timer1.c
#include "timer1.h" #include #include static u32 TimingDelay; //timer1_capture define u32 TIM1ClockFreq = 25;//15Hz u32 LSIClockFreq = 0; u16 ICValue1 =0, ICValue2 =0; //标志位放在TIM1中断中 volatile u8 pulse_change_flag = 0;//脉冲变化标志位,1:接通 2:挂断 0:重置 // void Tim1_Init(void) { TIM1_TimeBaseInit(16,TIM1_COUNTERMODE_UP,1000,0);//16分频,向上计数,计数完了触发中断,如果想 //再 1MS 触发中断,则计数器应该计数 1000 次,1MHZ/1000=1KHZ,正好就是 1ms。 TIM1_ARRPreloadConfig(ENABLE);//使能自动重装 TIM1_ITConfig(TIM1_IT_UPDATE , ENABLE);//数据更新中断 TIM1_Cmd(ENABLE);//开定时器 } void TimingDelay_Decrement(void) { if (TimingDelay != 0x00) { TimingDelay--; } } void delay_ms(u32 nTime) { TimingDelay = nTime; while(TimingDelay != 0); } /* *brief:timer1_capture输入捕获 */ void timer1_capture(void) { /* Capture only every 8 events!!! */ /* Enable capture of TI1 */ /* TIM1_Channel = TIM1_CHANNEL_1 TIM1_ICPolarity = TIM1_ICPOLARITY_FALLING TIM1_ICSelection = TIM1_ICSELECTION_DIRECTTI TIM1_ICPrescaler = TIM1_ICPSC_DIV8 TIM1_ICFilter = 0x0 */ //IC:Input Capture,下降沿优先 TIM1_ICInit( TIM1_CHANNEL_1, TIM1_ICPOLARITY_FALLING, TIM1_ICSELECTION_DIRECTTI, TIM1_ICPSC_DIV8, 0x0); /* Enable CC1 interrupt */ TIM1_ITConfig(TIM1_IT_CC1, ENABLE); //TIMER1 中断配置 //TIM1 IT 里面用脉冲变化的标志位 pulse_change_flag = 1;//接通 // /* Enable TIM1 */ TIM1_Cmd(ENABLE); /* Clear CC1 Flag*/ TIM1_ClearFlag(TIM1_FLAG_CC1); /* Connect LSI to CCO pin PC4作为输出 */ GPIO_Init(GPIOC, GPIO_PIN_4, GPIO_MODE_OUT_PP_LOW_FAST); CLK_CCOConfig(CLK_OUTPUT_LSI);//时钟参数配置 CLK_CCOCmd(ENABLE);//Configure Clock Output(CCO)使能 /* wait a capture on CC1 */ while((TIM1->SR1 TIM1_FLAG_CC1) != TIM1_FLAG_CC1); /* Get CCR1 value*/ ICValue1 = TIM1_GetCapture1(); TIM1_ClearFlag(TIM1_FLAG_CC1); /* wait a capture on cc1 */ //Configure Clock 1 while((TIM1->SR1 TIM1_FLAG_CC1) != TIM1_FLAG_CC1); /* Get CCR1 value*/ ICValue2 = TIM1_GetCapture1();//Input Capture TIM1_ClearFlag(TIM1_FLAG_CC1); /* Compute LSI clock frequency */ LSIClockFreq = (8 * TIM1ClockFreq) / (ICValue2 - ICValue1); } |
1个回答
这个用定时器中断不太合适吧 定时器中断捕获主要用在高速检测外部信号的数量,或者测试外部信号的宽度
你这个情况直接使用IO口中断检测外部信号就可以 中断触发方式使用上升沿和下降沿触发,在中断函数中判断电平状态,就可以确定是上升沿还是下降沿,之后根据情况处理就行 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4140 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2753 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14984 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3092浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1898浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2070浏览 3评论
1981浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2171浏览 3评论
/9
GMT+8, 2025-12-3 06:58 , Processed in 1.055292 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
861
