电子发烧友论坛|
大家好。我在STM8S105K4T6上有一个可行的pwm代码,现在我把它粘贴到STM8S003k3 fnd它将无法正常工作。
& sharpdefine CCR1_Val((u16)2047)//配置通道1脉冲宽度蓝色 & sharpdefine CCR2_Val((u16)2047)//配置通道2脉冲宽度 static void TIM1_Config(void) { TIM1_DeInit(); / *时基配置* / / * TIM1_Period = 4095 TIM1_Prescaler = 0 TIM1_CounterMode = TIM1_COUNTERMODE_UP TIM1_RepetitionCounter = 0 * / TIM1_TimeBaseInit(0,TIM1_COUNTERMODE_UP,4095,0); / *通道1,2,3和4在PWM模式下配置* / / * TIM1_OCMode = TIM1_OCMODE_PWM2 TIM1_OutputState = TIM1_OUTPUTSTATE_ENABLE TIM1_OutputNState = TIM1_OUTPUTNSTATE_ENABLE TIM1_Pulse = CCR1_Val TIM1_OCPolarity = TIM1_OCPOLARITY_LOW TIM1_OCNPolarity = TIM1_OCNPOLARITY_HIGH TIM1_OCIdleState = TIM1_OCIDLESTATE_SET TIM1_OCNIdleState = TIM1_OCIDLESTATE_RESET * / / * TIM1_Pulse = CCR2_Val * / TIM1_OC2Init(TIM1_OCMODE_PWM2,TIM1_OUTPUTSTATE_ENABLE,TIM1_OUTPUTNSTATE_ENABLE,CCR2_Val, TIM1_OCPOLARITY_LOW,TIM1_OCNPOLARITY_HIGH,TIM1_OCIDLESTATE_SET, TIM1_OCNIDLESTATE_RESET); / * TIM1_Pulse = CCR4_Val * / TIM1_OC4Init(TIM1_OCMODE_PWM2,TIM1_OUTPUTSTATE_ENABLE,CCR1_Val,TIM1_OCPOLARITY_LOW, TIM1_OCIDLESTATE_SET); / * TIM1计数器启用* / TIM1_Cmd(ENABLE); / * TIM1主输出使能* / TIM1_CtrlPWMOutputs(ENABLE); } 任何人都可以告诉我这里有什么问题。 #stm8s003k3-TIM1-PWM-问题 以上来自于谷歌翻译 以下为原文 Hello every one. I have a workable code of pwm on STM8S105K4T6 and now I paste it in STM8S003k3 fnd it won't work. &sharpdefine CCR1_Val ((u16)2047) // Configure channel 1 Pulse Width Blue &sharpdefine CCR2_Val ((u16)2047) // Configure channel 2 Pulse Width static void TIM1_Config(void) { TIM1_DeInit(); /* Time Base configuration */ /* TIM1_Period = 4095 TIM1_Prescaler = 0 TIM1_CounterMode = TIM1_COUNTERMODE_UP TIM1_RepetitionCounter = 0 */ TIM1_TimeBaseInit(0, TIM1_COUNTERMODE_UP, 4095, 0); /* Channel 1, 2,3 and 4 Configuration in PWM mode */ /* TIM1_OCMode = TIM1_OCMODE_PWM2 TIM1_OutputState = TIM1_OUTPUTSTATE_ENABLE TIM1_OutputNState = TIM1_OUTPUTNSTATE_ENABLE TIM1_Pulse = CCR1_Val TIM1_OCPolarity = TIM1_OCPOLARITY_LOW TIM1_OCNPolarity = TIM1_OCNPOLARITY_HIGH TIM1_OCIdleState = TIM1_OCIDLESTATE_SET TIM1_OCNIdleState = TIM1_OCIDLESTATE_RESET */ /*TIM1_Pulse = CCR2_Val*/ TIM1_OC2Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_ENABLE, CCR2_Val, TIM1_OCPOLARITY_LOW, TIM1_OCNPOLARITY_HIGH, TIM1_OCIDLESTATE_SET, TIM1_OCNIDLESTATE_RESET); /*TIM1_Pulse = CCR4_Val*/ TIM1_OC4Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, CCR1_Val, TIM1_OCPOLARITY_LOW, TIM1_OCIDLESTATE_SET); /* TIM1 counter enable */ TIM1_Cmd(ENABLE); /* TIM1 Main Output Enable */ TIM1_CtrlPWMOutputs(ENABLE); } Can any one tell me what is wrong here. #stm8s003k3-tim1-pwm-problem |
1个回答
对不起,我的错误代码很好。我只是忘记重新映射Timer 1 -channel 4 [AFR6]我的状态指示器所在的位置
以上来自于谷歌翻译 以下为原文 Sorry my fault code is fine. I just forget remap Timer 1 -channel 4[AFR6] where my status led is |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 07:55 , Processed in 0.634463 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1066
