用Eclipse环境创建一个STM32F407工程。编译时出现错误。c:/program files (x86)/gnu arm embedded toolchain/9 2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: C:UsersHuichengeclipse-workspaceExcise-F407F407STDLibraryProjectDebug/../STM32F4xx_StdPeriph_Driver/STM32F4xx_StdPeriph_Driver/src/stm32f4xx_gpio.c:188: undefined reference to assert_failed' c:/program files (x86)/gnu arm embedded toolchain/9 2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: C:UsersHuichengeclipse-workspaceExcise-F407F407STDLibraryProjectDebug/../STM32F4xx_StdPeriph_Driver/STM32F4xx_StdPeriph_Driver/src/stm32f4xx_gpio.c:189: undefined reference toassert_failed'c:/program files (x86)/gnu arm embedded toolchain/9 2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: C:UsersHuichengeclipse-workspaceExcise-F407F407STDLibraryProjectDebug/../STM32F4xx_StdPeriph_Driver/STM32F4xx_StdPeriph_Driver/src/stm32f4xx_gpio.c:190: undefined reference to assert_failed' c:/program files (x86)/gnu arm embedded toolchain/9 2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: C:UsersHuichengeclipse-workspaceExcise-F407F407STDLibraryProjectDebug/../STM32F4xx_StdPeriph_Driver/STM32F4xx_StdPeriph_Driver/src/stm32f4xx_gpio.c:208: undefined reference toassert_failed'c:/program files (x86)/gnu arm embedded toolchain/9 2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: ./STM32F4xx_StdPeriph_Driver/STM32F4xx_StdPeriph_Driver/src/stm32f4xx_gpio.o:C:UsersHuichengeclipse-workspaceExcise-F407F407STDLibraryProjectDebug/../STM32F4xx_StdPeriph_Driver/STM32F4xx_StdPeriph_Driver/src/stm32f4xx_gpio.c:215: more undefined references to `assert_failed' followcollect2.exe: error: ld returned 1 exit status。
检查stm32f4xx_gpio.c,stm32f4xx_gpio.h,.定义有。为什么报错 |
1个回答
这个错误是因为在编译过程中,链接器无法找到`assert_failed`函数的定义。
`assert_failed`函数是在STM32标准外设库中定义的一个回调函数,用于处理断言错误。当在程序中使用了`assert_param`宏时,如果断言失败,就会调用`assert_failed`函数。 解决方法是在工程中提供`assert_failed`函数的定义。你可以在你的工程中创建一个名为`stm32f4xx_assert.c`的源文件,并在其中进行函数的定义。示例代码如下: ```c #include "stm32f4xx_assert.h" void assert_failed(uint8_t* file, uint32_t line) { // 处理断言错误的逻辑 while(1) { } } ``` 然后将该文件添加到你的工程中,并确保编译器能够正确地找到它。 这样就可以解决`undefined reference to 'assert_failed'`错误了。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1364 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1359 浏览 1 评论
780 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
562 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1394 浏览 2 评论
1758浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
484浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
420浏览 3评论
414浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
389浏览 3评论
GMT+8, 2024-9-29 05:11 , Processed in 0.777314 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
