主控平台是stm157 linux5.4, 目前加载系统自带的hci_uart.ko 加载固件的时候超时 wifi功能正常,但是有蓝牙设备出来。模组是cyw43438的模组。帮忙看下 .
谢谢。 [root@100:~]# cp -r bcm43438a1.hcd /lib/firmware/brcm/BCM43430A1.hcd [root@100:~]# ls -l /lib/firmware/brcm/BCM43430A1.hcd -rw------- 1 root root 33664 Feb 7 15:54 /lib/firmware/brcm/BCM43430A1.hcd [root@100:~]# [root@100:~]# [root@100:~]# echo 0 > /sys/class/rfkill/rfkill1/state [root@100:~]# [root@100:~]# [root@100:~]# echo 1 > /sys/class/rfkill/rfkill1/state [root@100:~]# [root@100:~]# [root@100:~]# [root@100:~]# insmod hci_uart.ko [ 242.383223] Bluetooth: HCI UART driver ver 2.3 [ 242.386241] Bluetooth: HCI UART protocol H4 registered [ 242.392495] Bluetooth: HCI UART protocol BCSP registered [ 242.396903] Bluetooth: HCI UART protocol LL registered [ 242.402009] Bluetooth: HCI UART protocol ATH3K registered [ 242.407350] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 242.419884] Bluetooth: HCI UART protocol Intel registered [ 242.431427] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator [ 242.434557] Bluetooth: HCI UART protocol Broadcom registered [ 242.448011] Bluetooth: HCI UART protocol QCA registered [ 242.451981] Bluetooth: HCI UART protocol AG6XX registered [ 242.459467] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator [ 242.461506] Bluetooth: HCI UART protocol Marvell registered [root@100ask:~]# [ 242.859958] Bluetooth: hci0: BCM: chip id 94 [ 242.863263] Bluetooth: hci0: BCM: features 0x2e [ 242.868568] Bluetooth: hci0: BCM43430A1 [ 242.871312] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000 [ 245.129207] Bluetooth: hci0: command 0x1a1a tx timeout [ 253.289132] Bluetooth: hci0: BCM: Patch command 1a1a failed (-110) [ 253.293861] Bluetooth: hci0: BCM: Patch failed (-110) [ 255.369133] Bluetooth: hci0: command 0x0c03 tx timeout [ 263.529199] Bluetooth: hci0: BCM: Reset failed (-110) [root@100ask:~]# [root@100ask:~]# hciconfig hci0: Type: Primary Bus: UART BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0 DOWN RX bytes:1411 acl:0 sco:0 events:163 errors:0 TX bytes:33820 acl:0 sco:0 commands:165 errors:0 |
1个回答
没有问题的, 必须同时修改为3M才会生效,brcmpatchram 这个工具不在我们这边维护了,所以不知道内部逻辑怎么修改了。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NRF54L15芯片开发安装路径对vscode不生效问题解析
2000 浏览 0 评论
在修改广播内容(如名称、UUID、广播数据等)时是否需要停用当前广播功能
1955 浏览 0 评论
nRF54芯片怎么烧录程序&nrfutil的安装使用
5719 浏览 0 评论
1158 浏览 0 评论
深入比较nRF52832和Nordic新的产品nRF54L15参数对比
5148 浏览 0 评论
/9
GMT+8, 2025-12-9 10:05 , Processed in 0.668967 second(s), Total 74, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3471
