使用PDL2.0.2导入uart_printf的例程,在确认晶振起振的情况下,程序一直跑在SystemInit的while (!(FM_CRG->SCM_STR (1UL << 1)));中,应该如何解决这个问题?
FM_CRG->BSC_PSR = BSC_PSR_Val; /* set System Clock presacaler */ FM_CRG->APBC0_PSR = APBC0_PSR_Val; /* set APB0 presacaler */ FM_CRG->APBC1_PSR = APBC1_PSR_Val; /* set APB1 presacaler */ FM_CRG->APBC2_PSR = APBC2_PSR_Val; /* set APB2 presacaler */ FM_CRG->SWC_PSR = SWC_PSR_Val | (1UL << 7); /* set SW Watchdog presacaler */ FM_CRG->TTC_PSR = TTC_PSR_Val; /* set Trace Clock presacaler */ FM_CRG->CSW_TMR = CSW_TMR_Val; /* set oscillation stabilization wait time */ if (SCM_CTL_Val (1UL << 1)) { /* Main clock oscillator enabled ? */ FM_CRG->SCM_CTL |= (1UL << 1); /* enable main oscillator */ while (!(FM_CRG->SCM_STR (1UL << 1))); /* wait for Main clock oscillation stable */ } if (SCM_CTL_Val (1UL << 3)) { /* Sub clock oscillator enabled ? */ FM_CRG->SCM_CTL |= (1UL << 3); /* enable sub oscillator */ while (!(FM_CRG->SCM_STR (1UL << 3))); /* wait for Sub clock oscillation stable */ } FM_CRG->PSW_TMR = PSW_TMR_Val; /* set PLL stabilization wait time */ FM_CRG->PLL_CTL1 = PLL_CTL1_Val; /* set PLLM and PLLK */ FM_CRG->PLL_CTL2 = PLL_CTL2_Val; /* set PLLN */ if (SCM_CTL_Val (1UL << 4)) { /* PLL enabled ? */ if ((SCM_CTL_Val (1ul << 1u)) == 0u) // if main clock disable, use high-speed CR for PLL { FM_CRG->PSW_TMR_f.PINC = 1u; } FM_CRG->SCM_CTL |= (1UL << 4); /* enable PLL */ while (!(FM_CRG->SCM_STR (1UL << 4))); /* wait for PLL stable */ } 以下是system_fm3.h中宏的配置 #define CLOCK_SETUP CLOCK_SETTING_CMSIS // <<< Define clock setup macro here #define __CLKMO (8000000UL) // <<< External 4MHz Crystal #define __CLKSO (32768UL) // <<< External 32KHz Crystal #define __CLKHC (4000000UL) // Internal 4MHz CR Oscillator #define __CLKLC (100000UL) // Internal 100KHz CR Oscillator #define SCM_CTL_Val 0x00000052 // <<< Define SCM_CTL here #define BSC_PSR_Val 0x00000000 // <<< Define BSC_PSR here #define APBC0_PSR_Val 0x00000001 // <<< Define APBC0_PSR here #define APBC1_PSR_Val 0x00000082 // <<< Define APBC1_PSR here #define APBC2_PSR_Val 0x00000082 // <<< Define APBC2_PSR here #define SWC_PSR_Val 0x00000003 // <<< Define SWC_PSR here #define TTC_PSR_Val 0x00000000 // <<< Define TTC_PSR here #define CSW_TMR_Val 0x0000005C // <<< Define CSW_TMR here #define PSW_TMR_Val 0x00000000 // <<< Define PSW_TMR here #define PLL_CTL1_Val 0x00000001 // <<< Define PLL_CTL1 here. Now K=1, M=2 #define PLL_CTL2_Val 0x00000011 // <<< Define PLL_CTL2 here. Now N=18 #define __PLLK (((PLL_CTL1_Val >> 4) 0x0F) + 1) #define __PLLN (((PLL_CTL2_Val ) 0x3F) + 1) #define __PLLM (((PLL_CTL1_Val ) 0x0Ful) + 1ul) |
1个回答
从您提供的代码片段来看,程序一直停在SystemInit函数的while循环中,等待FM_CRG寄存器中的SCM_STR位(第1位)设置为1。导致该问题的可能原因有:
1. FM_CRG寄存器的设置错误 2. 外部晶振没有正确启动 3. 硬件故障 要解决这个问题,请按照以下步骤进行排查: 1. 检查FM_CRG寄存器的设置是否正确。确保BSC_PSR寄存器和APBC0_PSR寄存器的值正确地被写入。您可以参考PDL的文档来确认正确的寄存器值。 2. 确保外部晶振电路正确连接并启动。检查晶振引脚的连接是否正确,确保电路中的晶振元件工作正常。您可以使用示波器或其他工具来检查晶振的振荡情况。 3. 检查硬件是否存在任何故障。检查电源和地线连接是否良好,检查其他外部组件是否正确连接和工作。 如果您已经确认了以上步骤,并且仍然遇到问题,您可以尝试以下方法: 1. 确保您使用的PDL版本与您的硬件兼容。有时,不正确的软件配置可能会导致系统无法启动。 2. 根据您的硬件平台,查找其他开发人员或技术支持,以获得更多的帮助和建议。 3. 尝试使用其他的调试方法,如打印调试信息到串口或使用调试器等。这样,您可以更详细地了解程序中的执行情况,以确定问题所在。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
stm32f407+ksz8863rlli概率性ping不通
698 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-常见网络服务搭建之NFS服务搭建
374 浏览 0 评论
求助:辉芒微芯片 FDM B11GBMH 的信息及开发环境安装
375 浏览 0 评论
918 浏览 0 评论
嵌入式 学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之输入输出重定向
774 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11307 浏览 31 评论
浏览过的版块 |
GMT+8, 2024-9-29 07:04 , Processed in 0.665017 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
