电子发烧友论坛|
串口信息如下:
U-Boot SPL 2021.10 (Sep 26 2023 - 22:53:52 +0800) LPDDR4: 4G version: g8ad50857. Trying to boot from SPI OpenBI v1.2 / __ / | _ _ | | | | | __ ___ _ __ | ( | |) || | | | | | '_ / _ '_ ___ | _ < | | | || | |) | __/ | | |) | |) || | _/| ./ _|| ||/|/___| | | |_| Platform Name : StarFive VisionFive V2 Platform Features : medeleg Platform HART Count : 5 Platform IPI Device : aclint-mswi Platform timer Device : aclint-mtimer @ 4000000Hz Platform Console Device : uart8250 Platform HSM Device : — Platform PMU Device : — Platform Reboot Device : pm-reset Platform Shutdown Device : pm-reset Platform Suspend Device : — Firmware Base : 0x40000000 Firmware Size : 392 KB Firmware RW Offset : 0x40000 Runtime SBI Version : 1.0 Domain0 Name : root Domain0 Boot HART : 1 Domain0 HARTs : 0*,1*,2*,3*,4* Domain0 Region00 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: () Domain0 Region01 : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: () Domain0 Region02 : 0x0000000040040000-0x000000004007ffff M: (R,W) S/U: () Domain0 Region03 : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X) Domain0 Next Address : 0x0000000040200000 Domain0 Next Arg1 : 0x0000000042200000 Domain0 Next Mode : S-mode Domain0 SysReset : yes Domain0 SysSuspend : yes Boot HART ID : 1 Boot HART Domain : root Boot HART Priv Version : v1.11 Boot HART Base ISA : rv64imafdcbx Boot HART ISA Extensions : none Boot HART PMP Count : 8 Boot HART PMP Granularity : 4096 Boot HART PMP Address Bits: 34 Boot HART MHPM Count : 2 Boot HART MIDELEG : 0x0000000000000222 Boot HART MEDELEG : 0x000000000000b109 U-Boot 2021.10 (Sep 26 2023 - 22:53:52 +0800), Build: jenkins-github_visionfive2-18 CPU: rv64imacu_zba_zbb Model: StarFive VisionFive V2 DRAM: 4 GiB MMC: sdio0@16010000: 0, sdio1@16020000: 1 Loading Environment from SPIFlash… SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment StarFive EEPROM format v2 --------EEPROM INFO-------- Vendor : StarFive Technology Co., Ltd. Product full SN: VF7110B1-2310-D004E000-00001875 data version: 0x2 PCB revision: 0xb2 BOM revision: A Ethernet MAC0 address: 6c:cf:39:00:53:14 Ethernet MAC1 address: 6c:cf:39:00:53:15 --------EEPROM INFO-------- In: serial Out: serial Err: serial Model: StarFive VisionFive V2 Net: eth0: ethernet@16030000, eth1: ethernet@16040000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Try booting from MMC1 … Failed to load ‘vf2_uEnv.txt’ Warning: Input data exceeds 1048576 bytes - truncated Info: input data size = 1048578 = 0x100002 Error: “boot2” not defined Card did not respond to voltage select! : -110 starfive_pcie pcie@2B000000: Port link up. starfive_pcie pcie@2B000000: Starfive PCIe bus probed. PCI: Failed autoconfig bar 10 starfive_pcie pcie@2C000000: Port link down. starfive_pcie pcie@2C000000: Starfive PCIe bus probed. PCI: Failed autoconfig bar 10 Device 0: unknown device Device 0: unknown device Tring booting distro … switch to partitions #0, OK mmc1 is current device Try booting from MMC1 … Failed to load ‘/uEnv.txt’ Warning: defaulting to text format Warning: Input data exceeds 1048576 bytes - truncated Info: input data size = 1048578 = 0x100002 Failed to load ‘/dtbs/starfive/jh7110-visionfive-v2.dtb’ libfdt fdt_check_header(): FDT_ERR_BADMAGIC libfdt fdt_check_header(): FDT_ERR_BADMAGIC libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND fatwrite - write file into a dos filesystem Usage: fatwrite [ []] - write file ‘filename’ from the address ‘addr’ in RAM to ‘dev’ on ‘interface’ Retrieving file: /extlinux/extlinux.conf Failed to load ‘/extlinux/extlinux.conf’ Error reading config file Card did not respond to voltage select! : -110 Device 0: unknown device Device 0: unknown device StarFive # 以下内容为评论 设备都装了什么? 我看提示信息, PCI-E 识别失败后,就去启动 MMC1 设备了。MMC1 上面没有找到需要的文件后就启动失败了。MMC1 应该是 emmc 模块吧? MMC1 的 #0 分区被当作存储文件的设备。 mmc1是TF卡,镜像是openwrt 看看数据位置,反正提示是 uEnv.txt 和 extlinux/extlinux.conf 都有问题。 这两个都是在同一个分区里面。提示是在 0 分区里面找的。 PS:好像 VF2 有 TF 卡的兼容问题。有些卡读取不了数据。 |
1个回答
根据您提供的串口信息,可以看到 U-Boot SPL(Secondary Program Loader)正在尝试从 SPI 启动。请按照以下步骤解决启动失败的问题:
1. 检查 SD 卡 确保您的 SD 卡已插好并且可读写。可以尝试将 SD 卡插入另一个设备或计算机上,确保它可以正常工作。 2. 检查启动设置 确保您的启动设置正确。您可以使用命令 `printenv` 查看当前的 U-Boot 环境变量,并验证启动配置是否正确。 3. 检查 SPL 和 U-Boot 版本 确保您使用的 SPL 和 U-Boot 版本与您的硬件兼容。尝试将 SPL 和 U-Boot 更新为最新版本,可以从供应商或开发者的官方网站获取最新版本。 4. 检查设备树和启动脚本 确保您使用的设备树和启动脚本与您的硬件和操作系统匹配。确保设备树文件(.dtb)和启动脚本(.boot.scr 或 .ext3.scr)正确且位于正确的路径。 5. 检查启动设备顺序 如果 SPI 启动失败,可以尝试更改启动设备顺序。可以通过 `sf probe 0` 命令将 SPI 设备注册为 U-Boot 的启动设备,然后尝试从 SD 卡启动。 6. 检查启动日志 如果您还能获取更多的启动日志信息,可以查看它们以获取更多的线索和错误消息。尝试使用其他调试工具或方法获取更详细的启动日志。 以上步骤可能需要一定的技术知识和操作。如果您不确定如何进行操作,建议联系设备供应商或开发者进行进一步的支持和指导。 |
只有小组成员才能发言,加入小组>>
VisionFive2中openplc页面无法打开怎么解决?
1430 浏览 1 评论
第一次启动StarFive VisionFive 2, U-Boot总是报错,为什么?
1299 浏览 1 评论
VisionFive 2 生态进展双周报(1.1-1.31)
2399 浏览 0 评论
JH-7110现已支持AMP双系统(Linux + RT-Thread)
2121 浏览 0 评论
VisionFive 2 生态进展双周报(9.29-10.16)
1062 浏览 0 评论
872浏览 2评论
899浏览 2评论
在starvision2上移植FreeRTOS,objdump后发现static变量的地址是0,怎么解决?
384浏览 2评论
394浏览 2评论
SPI驱动模块init后probe函数并不会打印信息是哪里出了问题?
380浏览 2评论
/9
GMT+8, 2025-12-2 13:51 , Processed in 0.824460 second(s), Total 68, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
877
