电子发烧友论坛|
1.执行指令
asm volatile( “rdcycle %0n” : “=r” (cycle) :: “memory”); 2.执行结果 cycle:0x000000044e7d41f0 cycle:0x000000044ea31450 cycle:0x000000044ec8e6ae cycle:0x000000044eeeb90c cycle:0x000000044f148b80 cycle:0x000000044f3a5dde cycle:0x000000044f603066 cycle:0x000000044f8602c6 cycle:0x000000044fabd524 cycle:0x000000044fd1a640 cycle:0x000000044ff7789e cycle:0x00000004501d4b12 cycle:0x0000000450431d70 cycle:0x000000045068eff6 cycle:0x00000004508ec256 cycle:0x0000000450b494b4 cycle:0x0000000450da6714 cycle:0x0000000451003972 cycle:0x0000000451260be4 cycle:0x00000004514bde46 cycle:0x000000045171af88 cycle:0x00000004519781e8 cycle:0x0000000451bd5446 cycle:0x0000000451e326a4 cycle:0x000000045208f904 cycle:0x00000004522ecb76 cycle:0x0000000452549dd6 cycle:0x00000004527a705e cycle:0x0000000452a042bc cycle:0x0000000452c6151a cycle:0x0000000452ebe77a cycle:0x000000045311b9d8 cycle:0x0000000453378b08 cycle:0x00000004535d5d68 cycle:0x0000000453832ff0 cycle:0x0000000453a9024e cycle:0x0000000453ced4ac cycle:0x0000000453f4a70c cycle:0x00000004541a796a cycle:0x0000000454404bde cycle:0x0000000454661e3c cycle:0x00000004548bf0c4 cycle:0x0000000454b1c1e0 cycle:0x0000000454d7943e cycle:0x0000000454fd669e cycle:0x00000004552338fc cycle:0x0000000455490b70 cycle:0x00000004556eddce cycle:0x000000045594b040 cycle:0x0000000455ba82a0 cycle:0x0000000455e054fe cycle:0x000000045606275e cycle:0x00000004562bf9bc cycle:0x000000045651cc30 |
1个回答
Rdcycle指令用于读取处理器的周期计数器,以获取处理器在执行指令时所经过的周期数。然而,在某些情况下,使用Rdcycle指令获取的数据可能不准确。以下是一些可能导致数据不准确的原因:
1. **指令执行时间差异**:不同的指令在执行时所需的周期数可能会有所不同。例如,一些指令可能需要更多的周期来完成,而其他指令可能需要较少的周期。这可能导致在使用Rdcycle指令测量不同指令的执行时间时出现不准确的结果。 2. **中断和异常**:在执行Rdcycle指令期间,如果处理器遇到中断或异常,可能会导致周期计数器的值发生变化。这可能会影响Rdcycle指令获取的数据的准确性。 3. **多线程和多核处理器**:在多线程或多核处理器环境中,不同的线程或核心可能会同时执行Rdcycle指令。这可能导致周期计数器的值在不同线程或核心之间发生冲突,从而影响数据的准确性。 4. **指令流水线**:现代处理器通常具有指令流水线,这意味着多个指令可能同时处于不同的执行阶段。在这种情况下,使用Rdcycle指令测量单个指令的执行时间可能会导致不准确的结果,因为周期计数器的值可能受到其他正在执行的指令的影响。 5. **编译器优化**:编译器可能会对代码进行优化,以提高执行效率。这可能导致编译后的代码与原始代码在执行时的周期计数有所不同,从而影响Rdcycle指令获取的数据的准确性。 6. **硬件和软件环境**:不同的硬件和软件环境可能会对Rdcycle指令的执行产生影响。例如,不同的处理器架构、操作系统和编译器可能会对周期计数器的值产生不同的影响。 7. **指令重排**:为了提高执行效率,处理器可能会对指令进行重排。这可能导致Rdcycle指令在执行时与其他指令的执行顺序发生变化,从而影响数据的准确性。 8. **缓存效应**:处理器的缓存可能会影响指令的执行时间。例如,如果一个指令需要从主内存中加载数据,那么它的执行时间可能会比预期的要长。这可能导致使用Rdcycle指令测量指令执行时间时出现不准确的结果。 为了提高Rdcycle指令获取数据的准确性,可以尝试以下方法: 1. 使用更精确的计时器,例如RDTSC(读取时间戳计数器)指令,该指令可以提供更高的时间分辨率。 2. 在测量指令执行时间时,确保在相同的硬件和软件环境下进行多次测量,并计算平均值。 3. 在测量指令执行时间之前,使用适当的内存屏障指令(如CPUID)来刷新处理器的指令流水线。 4. 在多线程或多核环境中,确保在不同的线程或核心上执行Rdcycle指令时,避免使用共享资源。 5. 考虑使用专门的性能分析工具,这些工具可以提供更准确的性能测量结果。 |
只有小组成员才能发言,加入小组>>
VisionFive2中openplc页面无法打开怎么解决?
1429 浏览 1 评论
第一次启动StarFive VisionFive 2, U-Boot总是报错,为什么?
1297 浏览 1 评论
VisionFive 2 生态进展双周报(1.1-1.31)
2398 浏览 0 评论
JH-7110现已支持AMP双系统(Linux + RT-Thread)
2121 浏览 0 评论
VisionFive 2 生态进展双周报(9.29-10.16)
1061 浏览 0 评论
872浏览 2评论
895浏览 2评论
在starvision2上移植FreeRTOS,objdump后发现static变量的地址是0,怎么解决?
383浏览 2评论
394浏览 2评论
SPI驱动模块init后probe函数并不会打印信息是哪里出了问题?
379浏览 2评论
/9
GMT+8, 2025-12-1 18:56 , Processed in 0.882746 second(s), Total 99, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1915
