电子发烧友论坛|
尝试过各种img,包括debian Image 55/69,sdcard.img。
通过tftp升级SPL/UBOOT,但是SD卡boot依然报错: dwmci_d: DATA ERROR!mmc_bre: Failed to read blocksdwmci_s: timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklenBOOT fail,Error is 0xffffffffUART下,执行mmc info Card did not respond to voltage select! : -110TF卡是SanDisk Ultra 64GB Class 10 UHS Class A-1。 是否应该考虑换一个卡? 更新: 换了一个maxell的class 10 HC卡,同样还是无法找到SD卡。 --------EEPROM INFO--------In: serial@10000000Out: serial@10000000Err: serial@10000000Model: StarFive VisionFive V2Net: eth0: ethernet@16030000, eth1: ethernet@16040000unable to select a modeCard did not respond to voltage select! : -110bootmode flash device 0Card did not respond to voltage select! : -110Hit any key to stop autoboot: 0Card did not respond to voltage select! : -110Couldn't find partition mmc 0:3Can't set block deviceImporting environment from mmc0 ...## Warning: Input data exceeds 1048576 bytes - truncated## Info: input data size = 1048578 = 0x100002## Error: "boot2" not definedCard did not respond to voltage select! : -110产品信息: Product full SN: VF7110A1-2250-D008E000-00001054 data version: 0x2 PCB revision: 0xa1 BOM revision: A |
1个回答
官方的AVL中兼容的TF卡没有你用的这两种耶,你可以看下兼容的TF卡:https://doc-en.rvspace.org/JH7110/AVL/JH7110_DS/avl_list.html,另外要不选择QSPI或者eMMC启动试试?
只有小组成员才能发言,加入小组>>
VisionFive2中openplc页面无法打开怎么解决?
1429 浏览 1 评论
第一次启动StarFive VisionFive 2, U-Boot总是报错,为什么?
1297 浏览 1 评论
VisionFive 2 生态进展双周报(1.1-1.31)
2398 浏览 0 评论
JH-7110现已支持AMP双系统(Linux + RT-Thread)
2121 浏览 0 评论
VisionFive 2 生态进展双周报(9.29-10.16)
1061 浏览 0 评论
872浏览 2评论
895浏览 2评论
在starvision2上移植FreeRTOS,objdump后发现static变量的地址是0,怎么解决?
383浏览 2评论
394浏览 2评论
SPI驱动模块init后probe函数并不会打印信息是哪里出了问题?
379浏览 2评论
/9
GMT+8, 2025-12-1 19:20 , Processed in 0.678032 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
767
