扫一扫,分享给好友
#include
#include //#include "51hei.H" #define uchar unsigned char #define uint unsigned int ***it DQ = P1^7; //Êý¾Ý¿Údefine interface ***it dula = P2^6; //ÊýÂë¹Ü¶ÎÑ¡ ***it wela = P2^7; //ÊýÂë¹Üλѡ bit flag; //ζÈÕý¸º ***it jdq=P2^2; uint temp; //ζÈÖµ variable of temperature unsigned char code table[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d, 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//²»´øСÊýµã unsigned char code table1[] = {0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};//´øСÊýµã void delay(unsigned char i) { while(--i); } void pdelay(unsigned char i) { while(--i); P0=0xFF; //ÏûÒþ wela=1; wela=0; } void Init_Ds18b20(void) //DS18B20³õʼ»¯send reset and initialization command { DQ = 1; //DQ¸´Î»,²»ÒªÒ²¿ÉÐС£ delay(1); //ÉÔ×öÑÓʱ DQ = 0; //µ¥Æ¬»úÀµÍ×ÜÏß delay(250); //¾«È·ÑÓʱ£¬Î¬³ÖÖÁÉÙ480us DQ = 1; //ÊÍ·Å×ÜÏߣ¬¼´À¸ßÁË×ÜÏß delay(100); //´Ë´¦ÑÓʱÓÐ×ã¹»,È·±£ÄÜÈÃDS18B20·¢³ö´æÔÚÂö³å¡£ } uchar Read_One_Byte() //¶ÁÈ¡Ò»¸ö×Ö½ÚµÄÊý¾Ýread a byte date //¶ÁÊý¾Ýʱ,Êý¾ÝÒÔ×Ö½ÚµÄ×îµÍÓÐЧλÏÈ´Ó×ÜÏßÒƳö { uchar i = 0; uchar dat = 0; for(i=8;i>0;i--) { DQ = 0; //½«×ÜÏßÀµÍ£¬ÒªÔÚ1usÖ®ºóÊÍ·Å×ÜÏß //µ¥Æ¬»úÒªÔÚ´ËϽµÑغóµÄ15usÄÚ¶ÁÊý¾Ý²Å»áÓÐЧ¡£ _nop_(); //ÖÁÉÙά³ÖÁË1us,±íʾ¶ÁʱÐò¿ªÊ¼ dat >>= 1; //ÈôÓ×ÜÏßÉ϶Áµ½µÄλÊý¾Ý£¬ÒÀ´Î´Ó¸ßλÒƶ¯µ½µÍλ¡£ DQ = 1; //ÊÍ·Å×ÜÏߣ¬´ËºóDS18B20»á¿ØÖÆ×ÜÏß,°ÑÊý¾Ý´«Êäµ½×ÜÏßÉÏ delay(1); //ÑÓʱ7us,´Ë´¦²ÎÕÕÍƼöµÄ¶ÁʱÐòͼ£¬¾¡Á¿°Ñ¿ØÖÆÆ÷²ÉÑùʱ¼ä·Åµ½¶ÁʱÐòºóµÄ15usÄÚµÄ×îºó²¿·Ö if(DQ) //¿ØÖÆÆ÷½øÐвÉÑù { dat |= 0x80; //Èô×ÜÏßΪ1,¼´DQΪ1,ÄǾͰÑdatµÄ×î¸ßλÖÃ1;ÈôΪ0,Ôò²»½øÐд¦Àí,±£³ÖΪ0 } delay(10); //´ËÑÓʱ²»ÄÜÉÙ£¬È·±£¶ÁʱÐòµÄ³¤¶È60us¡£ } return (dat); } void Write_One_Byte(uchar dat) { uchar i = 0; for(i=8;i>0;i--) { DQ = 0; //ÀµÍ×ÜÏß _nop_(); //ÖÁÉÙά³ÖÁË1us,±íʾдʱÐò(°üÀ¨Ð´0ʱÐò»òд1ʱÐò)¿ªÊ¼ DQ = dat&0x01; //´Ó×Ö½ÚµÄ×îµÍλ¿ªÊ¼´«Êä //Ö¸ÁîdatµÄ×îµÍλ¸³Óè¸ø×ÜÏß,±ØÐëÔÚÀµÍ×ÜÏߺóµÄ15usÄÚ, //ÒòΪ15usºóDS18B20»á¶Ô×ÜÏß²ÉÑù¡£ delay(10); //±ØÐëÈÃдʱÐò³ÖÐøÖÁÉÙ60us DQ = 1; //дÍêºó,±ØÐëÊÍ·Å×ÜÏß, dat >>= 1; delay(1); } } uint Get_Tmp() //»ñȡζÈget the temperature { float tt; uchar a,b; Init_Ds18b20(); //³õʼ»¯ Write_One_Byte(0xcc); //ºöÂÔROMÖ¸Áî Write_One_Byte(0x44); //ζÈת»»Ö¸Áî Init_Ds18b20(); //³õʼ»¯ Write_One_Byte(0xcc); //ºöÂÔROMÖ¸Áî Write_One_Byte(0xbe); //¶ÁÔÝ´æÆ÷Ö¸Áî a = Read_One_Byte(); //¶ÁÈ¡µ½µÄµÚÒ»¸ö×Ö½ÚΪζÈLSB b = Read_One_Byte(); if(b&&0xf0) //¶ÁÈ¡µ½µÄµÚÒ»¸ö×Ö½ÚΪζÈMSB { flag=0; temp = b; //ÏȰѸ߰ËλÓÐЧÊý¾Ý¸³ÓÚtemp temp <<= 8; //°ÑÒÔÉÏ8λÊý¾Ý´ÓtempµÍ°ËλÒƵ½¸ß°Ëλ temp = temp|a; //Á½×ֽںϳÉÒ»¸öÕûÐͱäÁ¿ tt = temp*0.0625; //µÃµ½Õæʵʮ½øÖÆζÈÖµ //ÒòΪDS18B20¿ÉÒÔ¾«È·µ½0.0625¶È //ËùÒÔ¶Á»ØÊý¾ÝµÄ×îµÍλ´ú±íµÄÊÇ0.0625¶È temp = tt*10+0.5; //·Å´óÊ®±¶ //ÕâÑù×öµÄÄ¿µÄ½«Ð¡ÊýµãºóµÚһλҲת»»Îª¿ÉÏÔʾÊý×Ö } else { flag=1; temp = b; //ÏȰѸ߰ËλÓÐЧÊý¾Ý¸³ÓÚtemp temp <<= 8; //°ÑÒÔÉÏ8λÊý¾Ý´ÓtempµÍ°ËλÒƵ½¸ß°Ëλ temp = temp|a; temp=~temp; //Á½×ֽںϳÉÒ»¸öÕûÐͱäÁ¿ tt = temp*0.0625; //µÃµ½Õæʵʮ½øÖÆζÈÖµ //ÒòΪDS18B20¿ÉÒÔ¾«È·µ½0.0625¶È //ËùÒÔ¶Á»ØÊý¾ÝµÄ×îµÍλ´ú±íµÄÊÇ0.0625¶È temp = tt*10+0.5; //·Å´óÊ®±¶ } //ÕâÑù×öµÄÄ¿µÄ½«Ð¡ÊýµãºóµÚһλҲת»»Îª¿ÉÏÔʾÊý×Ö return temp; } void Display(uint temp) //ÏÔʾ³ÌÐò { uchar A1,A2,A3; A1 = temp/100; //°Ùλ A2 = temp%100/10; //ʮλ A3 = temp%10; //¸öλ P0 = table[A1]; //ÏÔʾ°Ùλ dula = 1; //´ò¿ª¶ÎÑ¡,¶ÔÓ¦74573µÄËø´æλ,¸ßµçƽ²»Ëø´æ dula = 0; P0 = 0xFd; wela = 1; //´ò¿ªÎ»Ñ¡ wela = 0; pdelay(80); P0 = table1[A2]; //ÏÔʾʮλ,ʹÓõÄÊÇÓÐСÊýµãµÄÊý×é(ÒòΪtempÖµÀ©´óÁË10±¶,ËäÈ»ÊÇʮλ,ʵ¼ÊΪ¸öλ) dula = 1; dula = 0; P0 = 0xFb; wela = 1; wela = 0; pdelay(80); P0 = table[A3]; //ÏÔʾ¸öλ dula = 1; dula = 0; P0 = 0xF7; wela = 1; wela = 0; pdelay(80); if(flag==1) { P0=0x40; dula=1; dula=0; P0=0xfe; wela=1; wela=0; pdelay(80); } } void main() { uint temp1=0; uint temp0=300; //guandz(); while(1) { Display(Get_Tmp()); temp1=Get_Tmp(); if(temp1==temp0) { jdq=0; // delay(100); } } } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-使用AHT20进行环境监测之AHT20传感器介绍
510 浏览 0 评论
792 浏览 0 评论
833 浏览 1 评论
基于瑞萨FPB-RA4E2智能床头灯项目——1编译环境搭建与点亮驱动ws2812全彩LED
797 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-LCD显示图片编程示例之介绍mmap
1244 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11815 浏览 31 评论
GMT+8, 2024-11-28 18:23 , Processed in 0.665418 second(s), Total 68, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
