电子发烧友论坛|
用的新唐m483芯片,想对700k左右的信号通过pwm触发进行eadc采样通过pdma输出,后续用来做带通滤波和傅里叶变化。
求大佬指点,adc的采样率部分如何设置才能满足700k信号采集的需要,看到官方文档中提到最高采样率可以达到5.14M,。 #include #include "NuMicro.h" #include "arm_math.h" #define PLL_CLOCK 192000000 #define ADC_SAMPLE_RATE 6 #define SAMPLE_NUM 512 #define NUM_ADC_CHANNELS 1 #define PDMA_CH 2 int16_t adcValues[SAMPLE_NUM] = {0}; float32_t fft_out[SAMPLE_NUM]; uint32_t ifft_flag = 0; uint32_t i; float32_t DSPCaltime; uint32_t g_u32SampleModuleNum = 0; float32_t output[SAMPLE_NUM]; float32_t temp_output[SAMPLE_NUM]; float32_t amplitudes[SAMPLE_NUM/2]; float32_t frequencies[SAMPLE_NUM/2]; volatile uint32_t AdcInput; float32_t AdcInput_float; uint32_t status; float32_t *inputF32, *outputF32; float32_t firStateF32[SAMPLE_NUM+5]; arm_rfft_fast_instance_f32 S; arm_fir_instance_f32 iir_inst; volatile uint32_t g_u32AdcIntFlag; volatile uint32_t g_u32AdcIntFlag, g_u32COVNUMFlag = 0; volatile uint32_t g_u32IsTestOver = 0; void SYS_Init(void) { PF->MODE = ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk); CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk); CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk); CLK_SetCoreClock(PLL_CLOCK); CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2); CLK_EnableModuleClock(UART0_MODULE); CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1)); CLK_EnableModuleClock(EPWM0_MODULE); CLK_SetModuleClock(EPWM0_MODULE, CLK_CLKSEL2_EPWM0SEL_PCLK0, 0); CLK_EnableModuleClock(EADC_MODULE); CLK_SetModuleClock(EADC_MODULE, 0, CLK_CLKDIV0_EADC(8)); CLK_EnableModuleClock(PDMA_MODULE); SYS->GPB_MFPH = ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk); SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD); PB->MODE = ~(GPIO_MODE_MODE6_Msk | GPIO_MODE_MODE7_Msk); SYS->GPB_MFPL = ~(SYS_GPB_MFPL_PB6MFP_Msk | SYS_GPB_MFPL_PB7MFP_Msk); SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB6MFP_EADC0_CH6 | SYS_GPB_MFPL_PB7MFP_EADC0_CH7); GPIO_DISABLE_DIGITAL_PATH(PB, BIT7|BIT6); SYS->GPB_MFPL = (SYS->GPB_MFPL (~SYS_GPB_MFPL_PB5MFP_Msk)); SYS->GPB_MFPL |= SYS_GPB_MFPL_PB5MFP_EPWM0_CH0; } void UART0_Init() { UART_Open(UART0, 115200); } void EPWM0_Init() { uint16_t TimeBASE=1000; EPWM_ConfigOutputChannel(EPWM0, 0, TimeBASE, 50); EPWM_Start(EPWM0, EPWM_CH_0_MASK); EPWM_EnableADCTrigger(EPWM0,0,EPWM_TRG_ADC_EVEN_COMPARE_DOWN); EPWM_SET_OUTPUT_LEVEL(EPWM0, BIT0, EPWM_OUTPUT_HIGH, EPWM_OUTPUT_LOW, EPWM_OUTPUT_NOTHING, EPWM_OUTPUT_NOTHING); EPWM_EnableOutput(EPWM0, BIT0); } void PDMA_Init() { PDMA_Open(PDMA,BIT2); PDMA_SetTransferCnt(PDMA,PDMA_CH, PDMA_WIDTH_16, SAMPLE_NUM); PDMA_SetTransferAddr(PDMA,PDMA_CH, (uint32_t) EADC->DAT[g_u32SampleModuleNum], PDMA_SAR_FIX, (uint32_t)adcValues, PDMA_DAR_INC); PDMA_SetTransferMode(PDMA,PDMA_CH, PDMA_EADC0_RX, FALSE, 0); PDMA_SetBurstType(PDMA,PDMA_CH, PDMA_REQ_SINGLE, PDMA_BURST_4); PDMA_EnableInt(PDMA,PDMA_CH, PDMA_INT_TRANS_DONE); NVIC_EnableIRQ(PDMA_IRQn); } void ReloadPDMA() { PDMA_SetTransferCnt(PDMA,PDMA_CH, PDMA_WIDTH_16, SAMPLE_NUM); PDMA_SetTransferMode(PDMA,PDMA_CH, PDMA_EADC0_RX, FALSE, 0); } void PDMA_IRQHandler(void) { status = PDMA_GET_INT_STATUS(PDMA); if(status PDMA_INTSTS_ABTIF_Msk) { if(PDMA_GET_ABORT_STS(PDMA) PDMA_ABTSTS_ABTIF2_Msk) g_u32IsTestOver = 2; PDMA_CLR_ABORT_FLAG(PDMA,PDMA_ABTSTS_ABTIF2_Msk); } else if(status PDMA_INTSTS_TDIF_Msk) { if(PDMA_GET_TD_STS(PDMA) PDMA_TDSTS_TDIF2_Msk) g_u32IsTestOver = 1; PDMA_CLR_TD_FLAG(PDMA,PDMA_TDSTS_TDIF2_Msk); } else printf("unknown interrupt !!n"); } void GetAdcData() { EADC_Open(EADC, EADC_CTL_DIFFEN_SINGLE_END); EADC_ConfigSampleModule(EADC, g_u32SampleModuleNum, EADC_EPWM0TG0_TRIGGER,2); if (SYS->CSERVER SYS_CSERVER_VERSION_Msk) /* M480LD */ EADC_ENABLE_SAMPLE_MODULE_PDMA(EADC, 1< |
只有小组成员才能发言,加入小组>>
179浏览 2评论
为什么DSP(数字信号处理)需要Q格式?q31、q15、q7 和 f32 是什么意思呢?
323浏览 2评论
请问NuMicro® Cortex-M0/M4系列可以提供哪些USB器件示例代码?
230浏览 2评论
芯片进入空闲或关机模式后,窗口看门狗定时器 (WWDT) 是否会继续工作呀?
175浏览 2评论
请问Nu-Link 驱动程序可以同时安装在 Keil RVMDK UV4 和 UV5 上吗?
211浏览 2评论
/9
GMT+8, 2025-12-1 22:03 , Processed in 0.591672 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
650
