电子发烧友论坛|
报错信息:
[DRC NSTD-1] Unspecified I/O Standard: 223 out of 223 logical ports use I/O standard (IOSTANDARD) value ‘DEFAULT’, instead of a user assigned specific value. This may cause I/O contention or incompatibility with the board power or connectivity affecting performance, signal integrity or in extreme cases cause damage to the device or the components to which it is connected. To correct this violation, specify all I/O standards. This design will fail to generate a bitstream unless all logical ports have a user specified I/O standard value defined. To allow bitstream creation with unspecified I/O standard values (not recommended), use this command: set_property SEVERITY {Warning} [get_drc_checks NSTD-1]. NOTE: When using the Vivado Runs infrastructure (e.g. launch_runs Tcl command), add this command to a .tcl file and add that file as a pre-hook for write_bitstream step for the implementation run. Problem ports: io_pads_gpioA_i_ival[31:0], io_pads_gpioA_o_oe[31:0], io_pads_gpioA_o_oval[31:0], io_pads_gpioB_i_ival[31:0], io_pads_gpioB_o_oe[31:0], io_pads_gpioB_o_oval[31:0], hfextclk, hfxoscen, io_pads_aon_erst_n_i_ival, io_pads_aon_pmu_dwakeup_n_i_ival, io_pads_aon_pmu_padrst_o_oval, io_pads_aon_pmu_vddpaden_o_oval, io_pads_bootrom_n_i_ival, io_pads_dbgmode0_n_i_ival, io_pads_dbgmode1_n_i_ival… and (the first 15 of 37 listed). 如果我用芯来提供的开发板mcu_200t,这里应该如何配置 |
只有小组成员才能发言,加入小组>>
在软件SDK中选择不同的下载模式时,是哪个部件更改了QSPI0中寄存器的值?
703 浏览 2 评论
cmt_instret_ena的使能为什么要排除branch等指令造成流水线冲刷的情况?
848 浏览 1 评论
e203 rom启动仅仅是引导到itcm执行指令吗?flash启动就是加载指令到itcm中吗?
980 浏览 1 评论
/9
GMT+8, 2025-12-12 15:31 , Processed in 0.691615 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1087
