触觉智能PurplePiOH 3566 OpenHarmony3.2R 64位运行docker 18.03.1
特别说明:本文档参考的是RK3568 OpenHarmony运行KubeEdge , 在此感谢相关开发者。
1.环境信息
1.PurplePiOH 3566(3.2Release)
2.sd卡一张
3.Linux内核:5.10
4.Docker:18.03.1
2.准备支持Docker容器的OpenHarmony内核
1.检测PurplePiOH 3566 OpenHarmony3.2release内核对docker的支持
2.在编译命令./build.sh --product-name purple_pi_oh --ccache
编译arm64位系统,屏幕为MIPI屏的情况下
- 进入out/kernel/src_tmp/linux-5.10下执行
scripts/extract-ikconfig boot_linux.img > /home/.config
生成boot_linux.img内核镜像的配置文件,配置文件此时输入到了/home/.config
4.添加Docker运行需要的目录'run', 'var', 'opt', 'usr'。修改build/ohos/images/build_image.py
5.修改/base/security/selinux/sepolicy/base/system/file_contexts
/run u:object_r:rootfs:s0
/var u:object_r:rootfs:s0
/opt u:object_r:rootfs:s0
/usr u:object_r:rootfs:s0
/lib u:object_r:rootfs:s0
3.编译烧录镜像
hdc shell reboot loader
4.安装docker容器引擎组件
1.在/etc/下创建cgroups.json(可以使用busybox),cgroups.json内容
"Cgroups": [
"UID": "system",
"GID": "system",
"Mode": "0755",
"Controller": "blkio",
"Path": "/dev/blkio"
"UID": "system",
"GID": "system",
"Mode": "0755",
"Controller": "cpu",
"Path": "/dev/cpu"
"Mode": "0555",
"Path": "/dev/cpuacct",
"Controller": "cpuacct"
"UID": "system",
"GID": "system",
"Mode": "0755",
"Controller": "cpuset",
"Path": "/dev/cpuset"
"UID": "system",
"GID": "system",
"Mode": "0755",
"Controller": "memory",
"Path": "/dev/memcg"
"UID": "system",
"GID": "system",
"Mode": "0755",
"Controller": "schedtune",
"Path": "/dev/stune"
"GID": "system",
"UID": "system",
"Mode": "0755",
"Controller": "devices",
"Path": "/dev/devices"
"GID": "system",
"UID": "system",
"Mode": "0755",
"Controller": "freezer",
"Path": "/dev/freezer"
"GID": "system",
"UID": "system",
"Mode": "0755",
"Controller": "hugetlb",
"Path": "/dev/hugetlb"
"GID": "system",
"UID": "system",
"Mode": "0755",
"Controller": "net_cls",
"Path": "/dev/net_cls"
"GID": "system",
"UID": "system",
"Mode": "0755",
"Controller": "net_prio",
"Path": "/dev/net_prio"
"GID": "system",
"UID": "system",
"Mode": "0755",
"Controller": "perf_event",
"Path": "/dev/perf_event"
"GID": "system",
"UID": "system",
"Mode": "0755",
"Controller": "pids",
"Path": "/dev/pids"
"GID": "system",
"UID": "system",
"Mode": "0755",
"Controller": "rdma",
"Path": "/dev/rdma"
"Cgroups2": {
"UID": "root",
"GID": "root",
"Mode": "0600",
"Path": "/dev/cg2_bpf"
2.安装docker静态二进制文件
https://download.docker.com/linux/static/stable/aarch64/
若为32位选择armhf版。
tar zxvf 到/system/bin下
cd /system/bin/docker/
chmod 777 docker
chmod 777 docker-containerd-ctr
chmod 777 docker-init
chmod 777 docker-runc
chmod 777 docker-containerd-shim
chmod 777 docker-proxy
chmod 777 dockerd
export PATH=$PATH:/system/bin/
export PATH=$PATH:/system/bin/docker/
5.格式化sd卡为f2fs文件系统
hdc shell mount -o rw,remount -t auto /
- docker overlay filesystem推荐backing filesystem是未加密的f2fs。而RK3568的data分区是加密的ext4,可以通过micro sd card卡扩展RK3568的存储将sd card格式化为f2fs解决此问题。
- 准备一个sd卡,插入到DAYU200板子上
blkid
df -h
umount /dev/block/vol-179-97
mkfs.f2fs /dev/block/vol-179-97
6.通过有线或者无线连接网络
将开发板连接网络
ifconfig
ifconfig -a
echo "1" > /proc/sys/net/ipv4/ip_forward
7.docker环境准备
# 创建docker运行需要的目录
mkdir /system/etc/docker
mkdir /data/var
mkdir /data/run
mkdir /data/tmp
mkdir /data/opt
mkdir /data/etc
mkdir /data/etc/docker
mkdir /data/usr
mkdir /mnt/f2fs
# 挂载刚刚已经被f2fs格式化的sd卡设备,可以用blkid查看到具体的名称
mount /dev/block/vol-179-97 /mnt/f2fs/
# 创建一个1GB大小的tmpfs文件系统,并将其挂载到"/sys/fs/cgroup"目录下,以供cgroup机制使用。
mount tmpfs /sys/fs/cgroup -t tmpfs -o size=1G
mkdir /sys/fs/cgroup/blkio
mkdir /sys/fs/cgroup/cpu
mkdir /sys/fs/cgroup/cpuacct
mkdir /sys/fs/cgroup/cpuset
mkdir /sys/fs/cgroup/devices
mkdir /sys/fs/cgroup/freezer
mkdir /sys/fs/cgroup/hugetlb
mkdir /sys/fs/cgroup/memory
mkdir /sys/fs/cgroup/net_cls
mkdir /sys/fs/cgroup/net_prio
mkdir /sys/fs/cgroup/perf_event
mkdir /sys/fs/cgroup/pids
mkdir /sys/fs/cgroup/rdma
mkdir /sys/fs/cgroup/schedtune
mkdir /sys/fs/cgroup/systemd
mount --bind /data/etc/docker /etc/docker
mount --bind /data/var /var
mount --bind /data/run /run
mount --bind /data/tmp /tmp
mount --bind /data/opt /opt
mount --bind /data/usr /usr
mount -t cgroup -o none,name=systemd cgroup /sys/fs/cgroup/systemd
mount -t cgroup -o blkio,nodev,noexec,nosuid cgroup /sys/fs/cgroup/blkio
mount -t cgroup -o cpu,nodev,noexec,nosuid cgroup /sys/fs/cgroup/cpu
mount -t cgroup -o cpuacct,nodev,noexec,nosuid cgroup /sys/fs/cgroup/cpuacct
mount -t cgroup -o cpuset,nodev,noexec,nosuid cgroup /sys/fs/cgroup/cpuset
mount -t cgroup -o devices,nodev,noexec,nosuid cgroup /sys/fs/cgroup/devices
mount -t cgroup -o freezer,nodev,noexec,nosuid cgroup /sys/fs/cgroup/freezer
mount -t cgroup -o hugetlb,nodev,noexec,nosuid cgroup /sys/fs/cgroup/hugetlb
mount -t cgroup -o memory,nodev,noexec,nosuid cgroup /sys/fs/cgroup/memory
mount -t cgroup -o net_cls,nodev,noexec,nosuid cgroup /sys/fs/cgroup/net_cls
mount -t cgroup -o net_prio,nodev,noexec,nosuid cgroup /sys/fs/cgroup/net_prio
mount -t cgroup -o perf_event,nodev,noexec,nosuid cgroup /sys/fs/cgroup/perf_event
mount -t cgroup -o pids,nodev,noexec,nosuid cgroup /sys/fs/cgroup/pids
mount -t cgroup -o rdma,nodev,noexec,nosuid cgroup /sys/fs/cgroup/rdma
mount -t cgroup -o schedtune,nodev,noexec,nosuid cgroup /sys/fs/cgroup/schedtune
# 设置DNS名称服务器和docker image注册表
echo "{\"registry-mirrors\":[\"https://docker.mirrors.ustc.edu.cn\"],\"experimental\":false,\"storage-driver\": \"overlay2\",\"data-root\": \"/mnt/f2fs\"}" > /etc/docker/daemon.json
# 临时关闭 SELinux 安全模式
setenforce 0
8.运行docker
dockerd -D -H tcp://0.0.0.0:2375 -H unix:///var/run/docker.sock &
9.验证docker运行状态
docker run hello-world
docker version
docker info
docker ps -a
docker images
hdc shell
mkdir /mnt/f2fs
blkid
df -h
挂载sd卡到/mnt/f2fs/
chmod 777 docker
chmod 777 dockerd
setenforce 0
dockerd -D -H tcp:
