电子发烧友论坛|
/* */ /* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technoledge Corp. // Website: http://www.nuvoton.com // E-Mail : MicroC-8bit@nuvoton.com // Date : Apr/21/2016 //*********************************************************************************************************** //*********************************************************************************************************** // File Function: N76E003 APROM program DATAFLASH as EEPROM way //*********************************************************************************************************** #include #include "N76E003.h" #include "Common.h" #include "Delay.h" #include "SFR_Macro.h" #include "Function_Define.h" bit BIT_TMP; //------------------------------------------------------------------------- UINT8 read_APROM_BYTE(UINT16 code *u16_addr) { UINT8 rdata; rdata = *u16_addr>>8; return rdata; } //------------------------------------------------------------------------- /***************************************************************************************************************** write_DATAFLASH_BYTE : user can copy all this subroutine into project, then call this function in main. ******************************************************************************************************************/ void write_DATAFLASH_BYTE(UINT16 u16_addr,UINT8 u8_data) { UINT8 looptmp=0,u8_addrl_r; unsigned char code *cd_longaddr; unsigned char xdata *xd_tmp; //Check page start address u8_addrl_r = u16_addr; if (u8_addrl_r<0x80) { u8_addrl_r = 0; } else { u8_addrl_r = 0x80; } //Save APROM data to XRAM xd_tmp = 0x80; cd_longaddr = (u16_addr&0xff00)+u8_addrl_r; while (xd_tmp !=0x100) { *xd_tmp = *cd_longaddr; looptmp++; xd_tmp++; cd_longaddr++; } // Modify customer data in XRAM u8_addrl_r = u16_addr; if (u8_addrl_r<0x80) { xd_tmp = u8_addrl_r+0x80; } else { xd_tmp = u8_addrl_r+0; } *xd_tmp = u8_data; //Erase APROM DATAFLASH page IAPAL = u16_addr; IAPAH = u16_addr>>8; IAPFD = 0xFF; set_IAPEN; set_APUEN; IAPCN = 0x22; set_IAPGO; //Save changed RAM data to APROM DATAFLASH u8_addrl_r = u16_addr; if (u8_addrl_r<0x80) { u8_addrl_r =0; } else { u8_addrl_r = 0x80; } xd_tmp = 0x80; IAPAL = u8_addrl_r; IAPAH = u16_addr>>8; set_IAPEN; set_APUEN; IAPCN = 0x21; while (xd_tmp !=0xFF) { IAPFD = *xd_tmp; set_IAPGO; IAPAL++; xd_tmp++; } clr_APUEN; clr_IAPEN; } /******************************************************************************************************************/ void main (void) { UINT8 datatemp; /* -------------------------------------------------------------------------*/ /* Dataflash use APROM area */ /* APROM 0x3800~0x38FF demo as dataflash */ /* Please use Memory window key in C:0x3800 to check earse result */ /* -------------------------------------------------------------------------*/ //call write byte write_DATAFLASH_BYTE (0x3881,0x55); write_DATAFLASH_BYTE (0x3882,0x56); write_DATAFLASH_BYTE (0x3855,0xaa); write_DATAFLASH_BYTE (0x3856,0x66); //call read byte datatemp = read_APROM_BYTE(0x3882); while(1); } //----------------------------------------------------------------------------------------------------------- |
1个回答
sp; *//*---------------------------------------------------------------------------------------------------------*/由于芯片存储空间的限制,N76E003芯片没有独立的EEPROM存储空间,但是它提供了APROM数据闪存作为EEPROM使用的方法。在N76E003中,APROM数据闪存被划分为6个大小相同的数据段,每个段大小为2048字节。在这些数据段中,可以选择一个用于EEPROM模拟的存储空间。使用该空间时,需要注意以下几点:1.存储空间选择:首先需要在系统初始化代码中选择一个空闲的APROM数据段来作为EEPROM。 2.写操作时需要先进行擦除:在写操作之前必须将要写入的地址所在的flash扇区擦除。擦除的大小为扇区(2KB)。 3.写操作的限制:EEPROM模拟空间的写操作需要用专用的函数执行(EE_WRITE_BYTE、EE_READ_BYTE、EE_ERASE...)。每次写操作最大数据量为一个字节。 4.读操作的限制:读操作时不能用相应的APROM代码段(用于EEPROM模拟的那个)的代码段地址进行存储器操作,否则会导致系统中断并进入死机状态。
只有小组成员才能发言,加入小组>>
1915 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4772 浏览 0 评论
4254 浏览 9 评论
3843 浏览 16 评论
4417 浏览 1 评论
4240浏览 3评论
2402浏览 0评论
3421浏览 0评论
1182浏览 0评论
2871浏览 0评论
/9
GMT+8, 2025-12-10 18:44 , Processed in 0.798557 second(s), Total 44, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
371
