想请教各路大神,关于官方提供的ISP代码中,我进入APROM后,While的循环只跑一次,就回到程序入口了,是怎么回呢?
配置中,看门狗已经关闭。 ******************************************************************************* #include #include "N76E003.h" #include "Typedef.h" #include "Define.h" #include "SFR_Macro.h" #include "UART0_transfer.h" #include "Function_define.h" #include "ISP_USER.h" sfr RCTRIM0 = 0x84; sfr RCTRIM1 = 0x85; unsigned char hircmap0,hircmap1; unsigned int trimvalue16bit; unsigned char temp0; unsigned char idata temp1 _at_ 0x90; unsigned char xdata temp2; unsigned char PID_highB,PID_lowB,CONF0,CONF1,CONF2,CONF4; unsigned char recv_CONF0,recv_CONF1,recv_CONF2,recv_CONF4; /*user define*/ unsigned char countx =0; void READ_ID_CONFIG(void) { set_IAPEN; IAPCN = BYTE_READ_ID; IAPAL = 0x00; IAPAH = 0x00; TA=0xAA; //trigger IAP TA=0x55; IAPTRG |= SET_BIT0; PID_lowB = IAPFD; IAPAL = 0x01; TA=0xAA; //trigger IAP TA=0x55; IAPTRG |= SET_BIT0; PID_highB = IAPFD; IAPCN = BYTE_READ_CONFIG; IAPAL = 0x00; IAPAH = 0x00; TA=0xAA; //trigger IAP TA=0x55; IAPTRG |= SET_BIT0; CONF0 = IAPFD; IAPAL = 0x01; TA=0xAA; //trigger IAP TA=0x55; IAPTRG |= SET_BIT0; CONF1 = IAPFD; IAPAL = 0x02; TA=0xAA; //trigger IAP TA=0x55; IAPTRG |= SET_BIT0; CONF2 = IAPFD; IAPAL = 0x04; TA=0xAA; //trigger IAP TA=0x55; IAPTRG |= SET_BIT0; CONF4 = IAPFD; clr_IAPEN; } void Package_checksum(void) { g_checksum=0; for(count=0;count<64;count++) { g_checksum =g_checksum+ uart_rcvbuf[count]; } uart_txbuf[0]=g_checksum&0xff; uart_txbuf[1]=(g_checksum>>8)&0xff; uart_txbuf[4]=uart_rcvbuf[4]+1; uart_txbuf[5]=uart_rcvbuf[5]; if(uart_txbuf[4]==0x00) uart_txbuf[5]++; } void MODIFY_HIRC_16588(void) { if ((PCON|CLR_BIT4)==0xFF) { set_IAPEN; IAPAL = 0x30; IAPAH = 0x00; IAPCN = READ_UID; set_IAPGO; hircmap0 = IAPFD; IAPAL = 0x31; IAPAH = 0x00; set_IAPGO; hircmap1 = IAPFD; clr_IAPEN; hircmap1 = hircmap1&0x01; trimvalue16bit = ((hircmap0<<1)+(hircmap1&0x01)); trimvalue16bit = trimvalue16bit - 15; hircmap1 = trimvalue16bit&0x01; hircmap0 = trimvalue16bit>>1; set_SFRPAGE; TA=0XAA; TA=0X55; RCTRIM0 = hircmap0; TA=0XAA; TA=0X55; RCTRIM1 = hircmap1; PCON&=CLR_BIT4; } } /************************************************************************************************************ * Main function ************************************************************************************************************/ void main (void) { //initial GPIO for quasi mode. // P0M1 = 0x00; // P0M2 = 0x00; // P1M1 = 0x00; // P1M2 = 0x00; // P2M1 = 0x00; // P2M2 = 0x00; // P3M1 = 0x00; // P3M2 = 0x00; MODIFY_HIRC_16588(); //uart initial READ_ID_CONFIG(); UART0_ini_115200(); TM0_ini(); g_timer0Over=0; g_timer0Counter=5000; g_progarmflag=0; while(1) { if(bUartDataReady == TRUE) { EA=0; //DISABLE ALL INTERRUPT if(g_progarmflag==1) { for(count=8;count<64;count++) { IAPCN = BYTE_PROGRAM_AP; //program byte IAPAL = flash_address&0xff; IAPAH = (flash_address>>8)&0xff; IAPFD=uart_rcvbuf[count]; TA=0xAA; //trigger IAP TA=0x55; IAPTRG |= SET_BIT0 ; IAPCN = BYTE_READ_AP; //program byte verify TA=0xAA; //trigger IAP TA=0x55; IAPTRG |= SET_BIT0 ; if(IAPFD!=uart_rcvbuf[count]) { while(1); } if (CHPCON==0x43) //if error flag set, program error stop ISP { while(1); } g_totalchecksum=g_totalchecksum+uart_rcvbuf[count]; flash_address++; if(flash_address==AP_size) { g_progarmflag=0; goto END_2; } } END_2: Package_checksum(); uart_txbuf[8]=g_totalchecksum&0xff; uart_txbuf[9]=(g_totalchecksum>>8)&0xff; Send_64byte_To_UART0(); } switch(uart_rcvbuf[0]) { case CMD_CONNECT: case CMD_SYNC_PACKNO: { Package_checksum(); Send_64byte_To_UART0(); g_timer0Counter=0; //clear timer 0 for no reset g_timer0Over=0; break; } case CMD_GET_FWVER: { Package_checksum(); uart_txbuf[8]=FW_VERSION; Send_64byte_To_UART0(); break; } case CMD_RUN_APROM: { goto _APROM; break; } //please tool must define devices value case CMD_GET_DEVICEID: { Package_checksum(); uart_txbuf[8]=PID_lowB; uart_txbuf[9]=PID_highB; uart_txbuf[10]=0x00; uart_txbuf[11]=0x00; Send_64byte_To_UART0(); break; } case CMD_ERASE_ALL: { set_IAPEN; set_APUEN; IAPFD = 0xFF; //Erase must set IAPFD = 0xFF IAPCN = PAGE_ERASE_AP; for(flash_address=0x0000;flash_address>8)&0xff; IAPFD=uart_rcvbuf[count]; //trigger IAP TA=0xAA; TA=0x55; IAPTRG |= SET_BIT0 ; IAPCN = BYTE_READ_AP; //program byte verify //trigger IAP TA=0xAA; TA=0x55; IAPTRG |= SET_BIT0 ; if(IAPFD!=uart_rcvbuf[count]) while(1); if (CHPCON==0x43) //if error flag set, program error stop ISP while(1); g_totalchecksum=g_totalchecksum+uart_rcvbuf[count]; flash_address++; if(flash_address==AP_size) { g_progarmflag=0; goto END_1; } } END_1: Package_checksum(); uart_txbuf[8]=g_totalchecksum&0xff; uart_txbuf[9]=(g_totalchecksum>>8)&0xff; Send_64byte_To_UART0(); break; } } bUartDataReady = FALSE; bufhead = 0; EA=1; } //For connect timer out if(g_timer0Over==1) { goto _APROM; } //for uart time out or buffer error if(g_timer1Over==1) { if((bufhead<64)&&(bufhead>0)||(bufhead>64)) { bufhead=0; } } } _APROM: TA = 0xAA; TA = 0x55; CHPCON = 0x00; //set boot from AP TA = 0xAA; TA = 0x55; CHPCON = 0x80; //software reset enable /* Trap the CPU */ P00_Quasi_Mode; while(1) { set_P00; clr_P00; } } |
1个回答
在ISP进入APROM后,代码会跳转到APROM的起始地址处,执行一次程序并结束,然后重新跳转回程序入口,这是正常的操作。因此,循环只执行了一次。如果想让代码一直执行,可以在APROM中加入一个死循环,或者调用一个无限循环的函数。另外,需要检查ISP的配置是否正确,以及APROM中的代码是否可运行。
只有小组成员才能发言,加入小组>>
488 浏览 0 评论
1028 浏览 1 评论
2410 浏览 5 评论
2731 浏览 9 评论
移植了freeRTOS到STMf103之后显示没有定义的原因?
2549 浏览 6 评论
使用eim外接fpga可是端口一点反应都没有有没有大哥指点一下啊
585浏览 9评论
587浏览 7评论
请教大神怎样去解决iMX6Q在linux3.0.35内核上做AP失败的问题呢
695浏览 6评论
563浏览 5评论
602浏览 5评论
GMT+8, 2024-9-28 22:51 , Processed in 1.025324 second(s), Total 80, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
